Topic "Explorer's 'Send To' menu"
alltrotec
1st Thank's for your cool program.
It would be nice to browse the destignation system in the "Copy" dialog from explorer's 'Send To' menu, i.e. a "Browse"-Botton in the right of selectbox for designation history. The browse dialog may be like the Explorer's copy to.
Matthias
I'll consider this Smile
alltrotec
I'll wait for realization, if you do so.
Another suggestion: you may include "Upload with SSH or SCP" directly in Explorer's context menue.
Here the german registry keys:
Files ...:
[HKEY_CLASSES_ROOT\*\shell\Hochladen mit SSH oder SCP]
@="&Hochladen mit SSH oder SCP"
[HKEY_CLASSES_ROOT\*\shell\Hochladen mit SSH oder SCP\command]
@="\"D:\\Programme\\WinSCP3\\WinSCP3.exe\" /upload \"%1\""
Folders:
[HKEY_CLASSES_ROOT\Folder\shell\Hochladen mit SSH oder SCP]
[HKEY_CLASSES_ROOT\Folder\shell\Hochladen mit SSH oder SCP\command]
Matthias
I think that it better fits into "Send to" menu. Also it does not pollute the main menu, where already too many applications insert their hooks. Which in turn significantly increases time necessary to open the menu.
