Topic "New sessions?"
I install WinSCP 2.2. The first time I run the program. I setup a session as a default one. Now the problem is whatever I run the program again. it always open and login to the only server. But I can not find any place to add another session(another server). My god, is this program only used for one server connection?
BTW, the command "new session" simply open another window and connect to the same server without prompting any questions.
Help me.
CVV
Ditto that. I'm having the same problem, that's why I came here. I did find that I can log in as another user and get back to the begining without the dafault sight and if you change it from using registry to an ini file you could edit the ini, but that isn't a real good solution.
Help me.
Quote:
CVV
Just uninstall and reinstall WinSCP.
Don't use the default sessions if you have more than one server that you may need to connect to.
Carl Velez
