Topic "using synchronize option in script and do not want to delete"
I am using a script at the command line and its working great for sychronizations. My question that i cannot find an option for is this:
When synchronizing from remote to local, is there a way not to delete a file locally if it does not appear in remote but appears in local? or should i not use the synchronize command?
here is my script:
# Issue winscp3 /console /script="fll path to script/config file"
option batch on
# runs wincp in non-interactive mode
# Connect
open connection name
# options are remote local or both ( both is a true mirror with the newest timestamp winning.
synchronize remote D:\folder
option synchdelete off
that did it thanks!
