Topic "WinSCP minimizes after login"
zfajfr
I have a problem with WinSCP3 (3.7.6 Build 306) on WinXP SP2. The login screen starts properly but once I push the login button to to log into one of previously saved sessions, the program minimezes on the taskbar cannot be restored in any way. The CPU utilization peaks at 100% when most of the CPU time is consumed by WinSCP3.exe. The only thing I can do is to kill the application. WinSCP used to work on my computer at the beginning but now (I don't know for how long and what could have been the break point) it fails to work.
Can you anybody help?
Zdenek
I hope that this will be solved with the next release, comming out in few days. Meanwhile you may try to remove your configuration.
I am having the same problem. The only solution I have found is to use the tools and clean up my saved sessions. I have to recreate my sessions, but at least I can use the app
I believe that it should be enough to clean the configuration, not the sessions.
Thanks Martin.
Does anyone know if this bug will be fixed in the next version, and when the next version is coming out?
I hope so. The next version will be released in few days.
