hide synchronize options/buttons from user
Erik
I am looking for a way to delete or better to hide the synchronize option / button from the user, as I dont want them to use this option in any case.
Could you help me with this?
Is there any parameter i could use to start WINSCP without this function, or it is possible to achieve this by changing specific Windows registry lines?
Thanks a lot for your suggestions!
Erik Icaza
Re: hide synchronize options/buttons from user
What for? The function doesn't do anything you cannot do with other functions.
Erik
It happens once: a non-IT-worker pushed instead of the refresh button the synchronize button, and we lost a lot of files on the remote host.
It is in fact not important if the synchronize button still remains there, but we want to disable his functionality.
I cannot make options to hide buttons, just because someone presses them time to time accidentally. I hope you can understand it.
Sure, i understand it.
Isn't it also possible to achieve this by using the Windows registry?
That's what I've meant. I've never thought about GUI option at all.
