Topic "problem with /script="
biscotti
Hi there,
I'm trying to get the /script option to work with my stored session and it keeps giving me a:
Cannot open file: <my_script_name>.txt
It all works when I issue the commands that I want manually but for some reason when I reference a script file I get the error above.
Any help would greatly be appreciated. Thanks.
Scott
Do you use full path?
Yea, when I do that it truncates the path in the same error message to:
Cannot open file: c:\Program
The full path is supposed to be: c:\Program Files\Winscp3\config.txt
When I put the path within quotes it will error the same, but with the full path of:
Cannot open file: c:\Program Files\Winscp3\config.txt
-Scott
Sorry, I have no idea what's wrong. It works for me. Have you tried using short path "c:\progra~1\winscp3\config.txt"?
No I hadn't tried that. I ended up going a different route and scripting a .bat file and hardcoding all the parameters and commands. Unfortunately, now I'm having a problem where my command that brings all the files in a directory over, doesn't bring over .doc files. Crud.
Scott
colfer
Quote any file names that contain spaces, I would say.
