Topic "Issue with Changing Directories on remote box"
TriGeek
I can connect to my remote linux no problem. However, I get this error when trying to switch directories on that remote box...and the weird thing is that its with different directores.
Can't recall changing anything on the linux box..everything was fine up until last weekend when I installed a Linksys 1-port router in front of the connection coming into the linux box. Even then, I setup port forwarding (22) to point to the IP of the linux machine.
Any insight would be greatly appreciated.
TriGeek
Error Msg:
"Host hasn't answered for 15 seconds."
"Wait for another 15 seconds? Pressing 'Abort' button will close session."
"Warning: Aborting this operation will close connection!"
Here is what the log file says:
Authentication successful
. Started session
. Doing startup conversation with host (shell).
> echo "WinSCP: this is end-of-file:0"
< WinSCP: this is end-of-file:0
. Detecting variable containing return code of last command.
. Trying "$status".
> echo "$status" ; echo "WinSCP: this is end-of-file:0"
. Trying "$?".
> echo "$?" ; echo "WinSCP: this is end-of-file:0"
< 0
. Return code variable "$?" selected.
. Looking up current user groups.
> groups ; echo "WinSCP: this is end-of-file:$?"
< root bin daemon sys adm disk wheel
. Following groups found:
. root
. bin
. daemon
. sys
. adm
. disk
. wheel
. Clearing all aliases.
> unalias "echo" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 5: unalias: echo: not found
< WinSCP: this is end-of-file:1
> unalias "pwd" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 6: unalias: pwd: not found
> unalias "cd" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 7: unalias: cd: not found
> unalias "ls" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 8: unalias: ls: not found
> unalias "groups" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 9: unalias: groups: not found
> unalias "scp" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 10: unalias: scp: not found
> unalias "rm" ; echo "WinSCP: this is end-of-file:$?"
> unalias "mv" ; echo "WinSCP: this is end-of-file:$?"
> unalias "mkdir" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 13: unalias: mkdir: not found
> unalias "chmod" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 14: unalias: chmod: not found
> unalias "chgrp" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 15: unalias: chgrp: not found
> unalias "chown" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 16: unalias: chown: not found
> unalias "unset" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 17: unalias: unset: not found
> unalias "unalias" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 18: unalias: unalias: not found
> unalias "alias" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 19: unalias: alias: not found
> unalias "%s" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 20: unalias: %s: not found
. Clearing national user variables.
> unset "LANG" ; echo "WinSCP: this is end-of-file:$?"
> unset "LANGUAGE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_CTYPE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_COLLATE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_MONETARY" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_NUMERIC" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_TIME" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_MESSAGES" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_ALL" ; echo "WinSCP: this is end-of-file:$?"
> unset "HUMAN_BLOCKS" ; echo "WinSCP: this is end-of-file:$?"
. Changing directory to "/var/www/html/roskopp".
> cd "/var/www/html/roskopp" ; echo "WinSCP: this is end-of-file:$?"
. Waiting for data timed out, asking user what to do.
. Asking user:
. Host hasn't answered for 15 seconds.
. Wait for another 15 seconds? Pressing 'Abort' button will close session. ()
. Attempt to close connection due to fatal exception:
* Terminated by user.
. Closing connection.
* (ESshFatal) Error getting name of current remote directory.
Are you sure that directory "/var/www/html/roskopp" exists?
