Topic "WinSCP 3.8 beta - Configuration Files location"
eebygum
In the What's New you mention:
"Synchronization delay for function Keep Remote Directory Up To Date is configurable (only directly in configuration files)."
Where are the configuration files ?.
Sorry I couldn't find anything in the documentation or any obvious places on the PC where these exist.
By default Windows registry are used. Check following key:
REGEDIT4
[HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\Interface]
"KeepUpToDateChangeDelay"=dword:000001f4
... or switch to an INI file.
eebygum
Thanks.
Should've looked there too.
I'm assuming the value is in milli-seconds.
Yes.
