Topic "synchronization checklist"
p0rr4d4
wow, the synchronization is great now. I've always used total commander to "administrate" synchronization actions but now i can finally migrate completelly to winscp, which i like more and is much much much faster when using sftp. I miss only a feature to delete files that are found only at one side of the sync directories.
It is possible to uncheck but then i have to look for the file in order to delete it.
anyway, WinSCP is very usefull, congratulations for this great software.
as always, sorry for the english
Set target directory the one where the files should be deleted and make sure that //Delete files// is checked. But maybe I do not understand your problem Smile
p0rr4d4
No, I mean in the "sychronization checklist" window. For example: I have local and remote directories synchronized. Lets say that after some work I delete some files locally because I dont need them anymore. If I synchronize the directories now, Winscp will try to copy the deleted files from remote directory... But I dont want to... I want to delete them from remote directory as well... So I miss an option to be able to delete files that are found only at one location (either local or remote) in the synchronization checklist window. Like in "Total commander", there are the actions "Delete left" and "Delete right" in the popup menu.
You need to set synchronization target to "remote". Apparently you have set it to "local".
