Topic "Command Line Inteface Question"
Tom Williams
When I am running long shell scripts on the server, I see a prompt that the server has not communicated back in 15 seconds with an option to abort or wait another 15 seconds.
Question 1
If I just ignore this prompt, will my script continue to completion and the shell will exit on its own?
Question 2
If the answer to number 1 is No, how to I prevent this prompt from showing? When I set Batch Mode On the script auto exits on the first prompt which is bad..
I'm using the December posting of WinSCP.
Regards,
Tom
Yes it should.
You can set longer timeout on login dialog.
Simon Tse
prikryl wrote:
Yes it should.
I set a 999 timeout on the login dialog. But that doesn't actually save it does it? I have to save the 999 timeout to a specific session it seems like.
When I run the batch script to connect to a server, it still says timeout after 15 seconds. How can I set the default timeout to be higher so that the command line batch script for winscp can have a long timeout as well?
See Set defaults button on stored sessions tab of login dialog.
