Topic "Change of Up-level Directory Permission?"
rodney
This may or may not be a bug? But I will post it here just in case.
INFO:
Running from version 3.8.0 (Build 312)
Trasfer protocol SCP
Norton Interface
SSH protocol version = SSH-2
SSH implementation = OpenSSH_3.5p1
Encryption algorithm = aes
Compression = Yes
File transfer protocol = SCP
Can change permissions = Yes
Can change owner/group = Yes
Can execute arbitrary command = Yes
Can create symlink/hardlink = Yes/Yes
Can lookup user groups = Yes
Can duplicate remote files = Yes
Additional protocol information:
Remote unix system information (uname -a):
Linux ???.com 2.6.11.6-RH1956 #3 SMP Tue Apr 12 08:12:03 CDT 2005 i686 i686 i386 GNU/Linux
PROBLEM #1:
When using the Termial Console to chown a number of folder/files in a domain directory (chown -Rf domain.domain .), its also change the upper directory as well too? In my case cause the main /public_html/ folder which using apache as the group name to no longer allow site viewing by the public!
PROBLEM #2:
When manally tranfering files from local to remote (drag/drop), upon comletion the remote isn't re-freshing itself? One is needing to do so manally.
Hope In have provide adequate info here.
Rodney
rodney wrote:
PROBLEM #1:
This is not about WinSCP. However I think that the dot in your commands makes the trouble. Use asterisk instead.
Quote:
PROBLEM #2:
Please give me more details. Where do you drag the files from? Where do you drop them? Do you use background transfer? Do you use drag&drop shell extension. What version of WinSCP, etc.
rodney
[quote="prikryl"]
rodney wrote:
PROBLEM #1:
prikryl wrote:
This is not about WinSCP. However I think that the dot in your commands makes the trouble. Use asterisk instead.!
Understood, Thank you.
Quote:
PROBLEM #2:
I tried both double clicking and dragging files from within your WinSCP local window to remote server's directory. Both background transfer and drag & drop shell extension is enabled. Version is 3.8.0 (Build 312).
Do you have the directory cache enabled? Without it the remote panel won't refresh when background transfer finishes.
