Topic "Local Directory change error in script"
I've had a script working fine using the default local directory. However, when I add the command "lcd d:\<path1>" to my script I keep on getting "Error changing director to 'd:\<path1>'
The new directory is needed due to space errors.
Thanks.
Joe G.
I do not understand the following:
Due to the space on the local drive where WinSCP is running, the script needs to change to a different directory. When I add the line to the script to change the local directory, I get "Error in changing directory" message.
Thanks again.
Joe Gallenstein
You should be able to change the directory from WinSCP console as long as you are able to make it working directory from other applications. Are you?
Problem was due to restricted rights on the local directory the script was chaning to. Problem was corrected after permissions updated.
Thanks.
Joe
