Topic "WinSCP with VanDyke's VShell SShd for Windows"
czrx
at first: great tool!.
But: At connecting with VanDyke's VShell-Server (its a Widnows SSHd), WinSCP stops loginsequence with following errormessage:
"Can't detect command return code."
But PuTTY's "PSFTP.EXE" works fine. Any suggestions?
mfg czrx
Please post log file.
czrx
Ok, the problem has changed. I've found some configuration commendations for WinSCP with VShell in this Forum and ... . there is a different error Sad:
See log:
. WinSCP Version 2.2.0 (Build 122)
. Login time: Freitag, 4. April 2003 17:31:48
. Session name: *******@**********
. Host name: ********** (Port: 22)
. User name: ******* (Password: Yes, Key file: No)
. SSH protocol version: 2; Compression: Yes
. SSH Bugs: A,A,A,A,A,A,A,
. Proxy: none
. Return code variable: Autodetect; Lookup user groups: No
. Shell: /ssh/sh, EOL: 1
. Local directory: default, Remote directory: home, Update: No
. Clear aliases: Yes, Unset nat.vars: Yes
. Looking up host "**********"
. Connecting to *********** port 22
. Server version: SSH-2.0-VShell_2.03 VShell
. We claim version: SSH-2.0-PuTTY-Local: Jan 26 2003 11:53:20
. Host key fingerprint is:
. ssh-rsa 2048 54:5d:dc:54:4f:c8:6e:f5:3c:1f:0e:f8:03:58:b7:0a
. Initialised zlib (RFC1950) compression
. Initialised zlib (RFC1950) decompression
. Sent password
. Access granted
. Opened channel for session
. Unexpected response to shell/command request: packet type 95
* (ESshFatal) Unexpected response to shell/command request: packet type 95
Packet Type 95
Hope that helps.
mfg czrx
Are you sure that /bin/sh exists on your server?
czrx
Well, VShell is a Windows-SSHd. I found some config-suggestions in this board. They said: "/ssh/sh" for "Shell"-settings.
So, I am sure, "/bin/sh" or "/ssh/sh" doesnt exist. Smile
mfg czrx
I have no experiences with VShell, but for OpenSSH for Windows there "exists" /ssh/sh, although there is in fact no /ssh directory. It is virtually mapped to c:\program files\openssh\ssh. Please check this.
What happens if you don't enter /bin/sh on Shell tab?
As to the PSFTP: It does not use shell, so it can work even when WinSCP does not.
gluswul
any news on that?
here the log without shell or with any unixlike path: (cancels with "Can't detect command return code.")
. WinSCP Version 2.2.3 (Build 139)
. Login time: Donnerstag, 17. April 2003 22:48:31
. Session name: gluswul@hal9000
. Host name: hal9000 (Port: 22)
. User name: gluswul (Password: Yes, Key file: No)
. SSH protocol version: 1; Compression: No
. Proxy: none
. Shell: default, EOL: 0
. Looking up host "hal9000"
. Connecting to 192.168.0.192 port 22
. Server version: SSH-2.0-OpenSSH_3.5p1
. We claim version: SSH-2.0-PuTTY-Local: Apr 12 2003 19:00:49
. ssh-rsa 1024 e1:96:11:20:36:de:f9:48:ac:91:d1:52:4b:f6:5e:97
! Using username "gluswul".
. Keyboard-interactive authentication refused
. Sent password
. Access granted
. Started a shell/command
. Doing startup conversation with host (shell).
> echo "WinSCP: this is end-of-file:0"
! Could not chdir to home directory /home/gluswul: No such file or directory
< Microsoft Windows XP [Version 5.1.2600]
< (C) Copyright 1985-2001 Microsoft Corp.
< C:\Programme\OpenSSH>"WinSCP: this is end-of-file:0"
* (ECommand) Error skipping startup message.
. Closing connection.
my next try was to enter the "windows shell" cmd:
but "Connection has been unexpectedly closed."
. Login time: Donnerstag, 17. April 2003 22:43:50
. Session name: test
. Proxy: none
. Shell: c:\winnt\system32\cmd.exe, EOL: 0
. Sent password
. Access granted
! c:winntsystem32cmd.exe: not found
. Server sent command exit status 0
* (ESshFatal) Error skipping startup message.
seams to me like there are problems with the backslash
thanks for your support
gluswul[/code]
gluswul wrote:
any news on that?
Your problems is the same. In your case Windows command line (cmd.exe) is run, WinSCP needs UNIX emulation.
See documentation for details about "Error skipping startup message" error.
