Topic "error when copying multiple large files"
luvstolindy
I get the following error when I try copying multiple large files from a Unix machine. THis is using version 3.7.6 of WinSCP.
"Copying files from remote side failed.
Bad message (badly formatted packet or protocol incompatibility)
Error code: 5
Error message from server: Bad message
Request code: 5"
This happens about the time the first file copy finishes. The file sizes are close to 2 Gbytes.
As a side note, when I would use the Windows 2000 ftp command to try and ftp these files, and using the mget option for ftp-ing multiple files, ftp would quit after the first file, giving an error message saying that the ftp had timed out.
I never realized that ftp was such a difficult thing!! I've never had such problems on the Unix side of things.
Todd
What server do you use?
hans
hi, I have exactly the same.
the other side is a centos 4.3 server with open ssh.
I used winscp version 3.8.2 ( build 330)
several times I saw the same thing. Exactly at the same position 2,1GB.
I logged in and used scp as default (and not sft with fallback to scp) and it worked.
