Topic "move to ../"
Plopmeout@...
I was logged into a remote machine and selected to directories, I right clicked, selected move to... and typed in ../
I intended to move the two directories into the parent directory but the two directories just disappeared.
Can anyone tell me where they went?
Thanks.
Do not know. Can you reproduce the problem?
plopmeout
yes i can
plopmeout
now that i think about it i'll putty into it and do a find. i'll let you know if i locate the files i need.
plopmeout
it turns out it was something was slowing down the remote processor big time. it wasn't winscp's fault it was mostly user error. but thanks for the good support.
