Topic "When I change windows, the WinSCP window is small & frozen"
cunparis
I just installed WinSCP, I've used it in the past on other computers. When I change to another window and come back, the window is the smallest it can possibly be (just the title bar) and I can't get it back. I have to right click on the task bar to close it and then relaunch it. I've tried both the 3.8 beta and the last official version and I get the same result. Obviously it's unusable for me like this but since no one else has reported this (I couldn't find it with the search) I'm wondering what could be going on with my system (Windows XP). Any ideas would be appreciated.
Michael
This is known problem, not resolved yet.
I seem to have a problem with WinSCP3. Since I resized a lot of images.
When I login instead of the file screen I now get a My Document tab at the
bottom of the screen which will not maximise. When I try to close it the
program does not respond.
I fixed it by reinstalling and deleating General configuration, Stored sessions, cached hot keys, configuration ini files, random seed file, temp folders when it suggest it
What version do you use? This should not happen with 3.8 anymore.
From Anonymous aka Benz
I've been using 3.7.6. Same problem has happened twice. I'll use 3.8 from now on thanks.
