Topic "Batch script hanging"
JohnsonJohnPat
I am calling winscp3 in a batch script with the /command parameter
The script is often hanging. I added the "option batch on" and "option confirm on"
The script ran successfully from the comand line. But when scheduled. hangs about 1 of 6 times. Is there a log file produced?
Thanks.
John Johnson
hp Consulting and Integration
Use /log switch (available since 3.8 only).
Is there anything else I can do to force winscp to exit?
Are there common reasons that it would hang?
The batch script ran friday 12 straight times then it hung. I will get the new version into production as soon as possible.
Can you see anything from the log file?
hmir
Hi, We are also having the same problem. We have version 3.7.6 installed on Windows 2000 box. We have scheduled the script to run every 15 minutes. Some times, it hangs, 1-2 times in a two day period. I don't mind the hang as long as there is a way to kill it from within a script after certain wait interval. (Does any one know how ?) Right now the hung process causes the CPU usage to be 100% which is a very big problem.
Is new 3.8 beta version going to address this ! Thanks.
It is a production system and I have to do change control. Hope to have this soon and will produce log file. Below is the commmand I am using
"c:\program files\winscp3\winscp3.com" user@server /command "option batch on" "option confirm off " "cd /prod/home/store/app/landing" "put D:\data\takeoff\FF-Exported230120066.csv" "close" "exit"
The script executes two sequention commands similar to the above to two different servers.
I would like to know on which command it hangs. At least Smile
We have been unable to get the beta version installed due to company policy.
Is there anything else we could look at changing to make this exit gracefully. It is hanging using 100% of one CPU. Works some of the time.
Could it be having problems with zero byte files?
is there something other than "close" "exit" we should do?
IS there an other method to produce log results in the current release version?
JohnsonJohnPat
We started leaving a console session open logged on with the service account that runs the batch job. It has not hung since we started doing this. Is there something that winscp that is not available running as a batch/service?
We have "Access to console" enabled for the service.
John Johnson
I'm not aware of that.
