Topic "Bug report"
pluggo
Problem:
WinSCP's menus don't seem to like multiple monitors. If you pull down a menu while WinSCP is on a secondary screen, the menu will be drawn on the closest edge of the primary screen.
Workaround:
Run WinSCP on your primary monitor or move the mouse to the primary monitor to click on menu items.
Version: 3.8.0 (Build 312)
Protocol: SFTPv3
Interface style: Explorer
Error message: none
Steps to reproduce: Hook up two monitors. Put the WinSCP window on one. Pull down a menu.
Log file: Not applicable
[/list]
Thanks. This is known problem. Hope to fix it in the net version.
