Topic "Saving multiple sites into List"
Goodson12
What I would like to be able to do it send out a specific file to a number of different sites with the click of a button. What would need to happen, I think, is that it winSCP would connect to one site load the file then close that connection and then open the next site, and so on. I would also like it to put that file in a specific location on that site. Is this possible? If not are there any good programs that do allow you to do this?
WinSCP supports scripting. You can write an script to do what you need.
I was wondering if there was already something like this as a plugin maybe.
# Automatically answer all prompts negatively not to stall
# the script on errors
option batch on
# Connect using a password
open xxxx:xxxxx@192.168.0.23
close
# Exit WinSCP
I get the response EAccess Violation
what does that mean?
It is a bug. If you are using 3.8, please downgrade to 3.7.6/
