Topic "Server does not support this operation?!"
rpali
I'm having a bit of trouble. When I use WinSCP and try to transfer a file to my server, I get this error:
The server does not support the operation.
Error code: 8
Error message from server (en): Operation not supported
Request code: 3
It's just a straight copy. Nothing fancy. I can do this with other non-secure FTP clients with no trouble, and I also can do it securely with Filezilla, though I vastly (and I mean *vastly*) prefer WinSCP.
Has anyone come across these errors before?
Can you post a full error message (not only the details)? Or even a log file?
What follows is the log for only the attempted copy operation as well as the logging that occurred after I selected abort on the error dialogue that appeared. I know I do have privs for this directory as I uploaded the files that are already there, though with a different FTP client. That transfer was not secure if it matters.
Here's the log:
Copying 1 files/directories to remote directory "/public_html/"
PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
TM: M; ClAr: No; ExclM(No):
AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
File: "D:\000 harry.txt"
Copying "D:\000 harry.txt" to remote directory started.
Ascii transfer mode selected.
Opening remote file.
Type: SSH_FXP_OPEN, Size: 56, Number: 8707
Type: SSH_FXP_STATUS, Size: 34, Number: 8452
Discarding reserved response
Type: SSH_FXP_STATUS, Size: 42, Number: 8707
Status/error code: 8, Message: 8707, Server: Operation not supported, Language: en
Type: SSH_FXP_LSTAT, Size: 39, Number: 8967
Type: SSH_FXP_STATUS, Size: 44, Number: 8967
Status/error code: 2, Message: 8967, Server: No such file or directory, Language: en
(ETerminal) The server does not support the operation.
Error code: 8
Request code: 3
Asking user:
Cannot create remote file '/public_html/000 harry.txt'. ("The server does not support the operation.
Error code: 8
Request code: 3")
(EScpSkipFile) Cannot create remote file '/public_html/000 harry.txt'.
Error code: 8
Request code: 3
Listing directory "/public_html".
Type: SSH_FXP_OPENDIR, Size: 21, Number: 9227
Type: SSH_FXP_HANDLE, Size: 13, Number: 9227
Type: SSH_FXP_READDIR, Size: 13, Number: 9484
Type: SSH_FXP_NAME, Size: 1038, Number: 9484
Type: SSH_FXP_READDIR, Size: 13, Number: 9740
Type: SSH_FXP_STATUS, Size: 44, Number: 9740
Status/error code: 1
Type: SSH_FXP_CLOSE, Size: 13, Number: 9988
Detected incoming data while idle
Can you post a full log file (I'm interested in an initialization part). Also what is your server software?
rpali
I absolutely appreciate your help!
The server is Apache 2.0.46
Following is the entire log, from logging in to clicking 'Abort' on the error message. The only thing I've done is change my user name to 'XXXXXX' in the log. Here it is:
WinSCP Version 3.8.0 (Build 312) (OS 5.1.2600 Service Pack 2)
Login time: February 8, 2006 11:36:13 PM
Session name: XXXXXX@ftp12.pmachinehosting.com
Host name: ftp12.pmachinehosting.com (Port: 22)
User name: XXXXXX (Password: Yes, Key file: No)
Transfer Protocol: SFTP (SCP)
SSH protocol version: 2; Compression: No
Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
SSH Bugs: -,-,-,-,-,-,-,-
SFTP Bugs: -,-,-
Proxy: none
Return code variable: Autodetect; Lookup user groups: Yes
Shell: default, EOL: 0
Local directory: default, Remote directory: home, Update: No, Cache: Yes
Cache directory changes: Yes, Permanent: Yes
Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
Looking up host "ftp12.pmachinehosting.com"
Connecting to 66.220.23.233 port 22
Server version: SSH-2.0-VShell_2_5_0_204 VShell
We claim version: SSH-2.0-WinSCP_release_3.8
Using SSH protocol version 2
Doing Diffie-Hellman group exchange
Doing Diffie-Hellman key exchange
Host key fingerprint is:
ssh-dss 1024 f2:b8:0a:fb:02:66:51:39:b9:74:f5:8c:2d:f1:b5:df
Initialised AES-256 client->server encryption
Initialised HMAC-SHA1 client->server MAC algorithm
Initialised AES-256 server->client encryption
Initialised HMAC-SHA1 server->client MAC algorithm
Using username "XXXXXX".
Session password prompt (XXXXXX@ftp12.pmachinehosting.com's password: )
Using stored password.
Sent password
Access granted
Opened channel for session
Started a shell/command
Using SFTP protocol.
Doing startup conversation with host.
Type: SSH_FXP_INIT, Size: 5, Number: -1
Type: SSH_FXP_VERSION, Size: 388, Number: -1
SFTP version 5 negotiated.
Unknown server extension newline@vandyke.com=0x000000010A
Server requests EOL sequence 0x0A.
Unknown server extension default-fs-attribs@vandyke.com=0x00000003000000012F00000000
Server support information:
Attribute mask: 800003A9, Attribute bits: 0, Open flags: 3F
Access mask: 0, Open block masks: 0, Block masks: 0, Max read size: 32768
Attribute extensions (0)
Extensions (3)
text-seek
version-select
vendor-id
Extensions (3)
text-seek
version-select
vendor-id
Server software: VShell 2.5.0 (build 204) (204) by VanDyke Software, Inc.
SFTP versions supported by the server: 3,4,5,6
Type: SSH_FXP_EXTENDED, Size: 61, Number: 7880
We will use UTF-8 strings when appropriate
Getting current directory name.
Getting real path for '.'
Type: SSH_FXP_REALPATH, Size: 10, Number: 7952
Type: SSH_FXP_STATUS, Size: 26, Number: 7880
Type: SSH_FXP_NAME, Size: 19, Number: 7952
Real path is '/'
Listing directory "/".
Type: SSH_FXP_OPENDIR, Size: 10, Number: 8203
Type: SSH_FXP_HANDLE, Size: 13, Number: 8203
Type: SSH_FXP_READDIR, Size: 13, Number: 8460
Type: SSH_FXP_NAME, Size: 610, Number: 8460
Type: SSH_FXP_READDIR, Size: 13, Number: 8716
Type: SSH_FXP_STATUS, Size: 44, Number: 8716
Type: SSH_FXP_CLOSE, Size: 13, Number: 8964
Startup conversation with host finished.
Type: SSH_FXP_OPEN, Size: 56, Number: 9219
Type: SSH_FXP_STATUS, Size: 34, Number: 8964
Type: SSH_FXP_STATUS, Size: 42, Number: 9219
Status/error code: 8, Message: 9219, Server: Operation not supported, Language: en
Type: SSH_FXP_LSTAT, Size: 39, Number: 9479
Type: SSH_FXP_STATUS, Size: 44, Number: 9479
Status/error code: 2, Message: 9479, Server: No such file or directory, Language: en
Error code: 8
Request code: 3
Asking user:
Error code: 8
Request code: 3")
Error code: 8
Request code: 3
Cached directory not reloaded.
Type: SSH_FXP_OPENDIR, Size: 10, Number: 9739
Type: SSH_FXP_HANDLE, Size: 13, Number: 9739
Type: SSH_FXP_READDIR, Size: 13, Number: 9996
Type: SSH_FXP_NAME, Size: 610, Number: 9996
Type: SSH_FXP_READDIR, Size: 13, Number: 10252
Type: SSH_FXP_STATUS, Size: 44, Number: 10252
Type: SSH_FXP_CLOSE, Size: 13, Number: 10500
Sorry I have no clue. I've never seen the problem before.
teredeby
Dunno if related, but I was with the same problem (but using scp in a MacOsX terminal) and it helped me: https://supportcenter.checkpoint.com/supportcenter/portal?eventSubmit_doGoviewsolutiondetails=&solutionid=sk38821
I just changed the directory to which I was trying to copy the file and poof! Magic.
