Topic "ASSERT and Abnormal program termination"
Arzie
Hi all
After I logged in to my webserver winscp displays:
- Error listening directory "/usr/home/mydir".
- Unexpected directory listing line "".
After I click OK winscp displays some files from my home directory.
I'm able to upload a file.
After the upload finishes 3 ASSERTS get fired.
- Assertion failed: Terminal->Files->IndexOf(ITEMFILE) >= 0, file C:\Martin\Projekty\WinSCP2\components\UnixDirView.cpp, line 297
[OK] - Click -
Abnormal program termination.
I get this error every time I log on and I was never able to get a complete directory listing.
Is this a known bug and planed to fix?
ciao
Arzie
Arzie
After some testing I found out what happend.
The problem is caused by a hidden symlink pointing to a directory which has a trailing newline character in its name.
Since the symlink is owed by root and I don't have root access I cannot solve the problem by myself.
To reproduce the problem you don't need a hidden symlink.
Just create a directory with a trailing newline inside of a test dirrctory and copy a file into the test directory.
The command
$perl -e "mkdir \"adir\n\";"
will create such a directory with a trailing newline.
ciao
Arzie
