Topic "list bookmarks for one click access"
billatarcat
Can you display all your bookmarks in the GUI for one click access. Also, can you have a 'nickname' for each bookmark instead of a, sometimes, long url.
Thanks, WinSCP is a fiiiiiine product.
Bill
I do not understand.
You can switch to location profiles.
trapd
You can display the bookmarks dialog by double-clicking the blue bar where the current path is displayed. Not exactly 'single click' but easier than going through the menus. Smile
Well, there's also toolbar button for it.
seanr
FWIW, I'm a particularly big fan of how FlashFXP handles bookmarks. Haven't used WinSCP yet so I don't know if it already does the same, but clicking the bookmarks icon in FlashFXP gets you a popup menu listing all of the bookmarks and you can set bookmarks that will change both the local and remote folders at the same time. For me that's critical, because I manage several sites on a single server and need to change between them several times throughout the day so having to do each side separately would waste a lot of time. Basically, what I'd just about kill for is SCP built into FlashFXP or a client with an identical interface - I've never been happy with any of the other interfaces out there.
WinSCP supports this too. It's called "Location profiles".
