Topic "Cannot initialize SFTP protocol. Is the host running a SFTP"
dovid
I'm having problems logging in for the first time:
The log is:
. 2006-02-09 13:59:00.828 Looking up host "99.99.99.99"
. 2006-02-09 13:59:00.828 Connecting to 99.99.99.99 port 22
. 2006-02-09 13:59:00.937 Server version: SSH-1.99-OpenSSH_3.6.1p2
. 2006-02-09 13:59:00.937 We claim version: SSH-2.0-WinSCP_release_3.8
. 2006-02-09 13:59:00.937 Using SSH protocol version 2
. 2006-02-09 13:59:01.000 Doing Diffie-Hellman group exchange
. 2006-02-09 13:59:01.156 Doing Diffie-Hellman key exchange
. 2006-02-09 13:59:02.000 Host key fingerprint is:
. 2006-02-09 13:59:02.000 ssh-rsa 1024 30:ef:42:c8:2f:ea:80:03:be:60:c0:f9:0a:b1:5c:d1
. 2006-02-09 13:59:02.000 Initialised AES-256 client->server encryption
. 2006-02-09 13:59:02.000 Initialised HMAC-SHA1 client->server MAC algorithm
. 2006-02-09 13:59:02.000 Initialised AES-256 server->client encryption
. 2006-02-09 13:59:02.000 Initialised HMAC-SHA1 server->client MAC algorithm
! 2006-02-09 13:59:02.140 Using username "userid".
. 2006-02-09 13:59:02.265 Keyboard-interactive authentication refused
. 2006-02-09 13:59:02.265 Session password prompt (userid@99.99.99.99's password: )
. 2006-02-09 13:59:02.265 Asking user for password.
. 2006-02-09 13:59:18.031 Sent password
. 2006-02-09 13:59:18.109 Access granted
. 2006-02-09 13:59:18.156 Opened channel for session
. 2006-02-09 13:59:18.218 Started a shell/command
. 2006-02-09 13:59:18.218 Server sent command exit status 1
. 2006-02-09 13:59:18.218 --------------------------------------------------------------------------
. 2006-02-09 13:59:18.218 Using SFTP protocol.
. 2006-02-09 13:59:18.218 Doing startup conversation with host.
> 2006-02-09 13:59:18.218 Type: SSH_FXP_INIT, Size: 5, Number: -1
. 2006-02-09 13:59:18.281 All channels closed. Disconnecting
. 2006-02-09 13:59:18.281 Server closed network connection
* 2006-02-09 13:59:18.281 (ESshFatal) Cannot initialize SFTP protocol. Is the host running a SFTP server?
* 2006-02-09 13:59:18.281 Connection has been unexpectedly closed. Server sent command exit status 1.
Any help is appreciated.
regards
David J.
Try other SFTP client. If you still cannot connect, it's server-side problem.
dovid
Just tried with just SFTP.
Got the same error.
It does connect to the server.
What do u think could be the problem on the server.
Thanks for your help.
dj
You may not have shell access. Or the SSH server cannot find/start the SFTP server.
Please read documentation for common reasons of getting this error and some resolution hints.
affinity
My son has an scponlyc "shell" login on one of my servers.
He started to get this error:
"Cannot initialize SFTP protocol. Is the host running a SFTP server?"
He was trying to connect using WinSCP ....
The problem was that the chroot home directory wasn't owned by root, so the login failed. I fixed this and made sure his group could write to the directory, but it is now owned by root.
trick
LOL!!!
If the mistake is not on your site, its maybe on the other
weisenheimer :p
kevymerry
I received same message, I realized my password was about to expire. I reset password, and then was able to connect.
Meir
Hi all,
I have the same error in my server.
In the first time I get the error message, In the second time I get the access.
I'm using with this connection MySecureShell to be able to lock the user in his HOMEDIR.
Some one have a clue about this error?
bbk
I change in "Session"-"File protocol" to "SCP"
and in "Enviroment"-"SCP/Shell"-"Shell" to "/bin/sh"
This is help me with OpenFiler Linux Distributive.
metal
Hello!
Please check the .profile, .bash_history, .bash_logout and .bashrc
They should have 755 permission - I changed these permission to 700 and started getting that same error.
metal wrote:
Hello!
Oh my gosh! Thanks a lot.
I've been wondering for a long time why I keep getting this message all of a sudden. Could have never figured that it would be a permission setting on a .bashrc file.
For details about error message "Cannot initialize SFTP protocol. Is the host running a SFTP server?" see:
http://winscp.net/eng/docs/message_cannot_initialize_sftp_protocol
Change the ForceCommand line in /etc/ssh/sshd_config to:
"ForceCommand internal-sftp"
I copied the old versions of rssh_chroot_helper and sftp-server in to the chroot folder /usr/libexec and this sorted the issue out.
David Docekal
This helped!
Thanks a lot
kevinleahy
for me the problem was that i was echoing text to the screen in .bashrc.
as soon as i removed this it worked.
IvanSP
I was getting this error because my password expired. I reseted my password using Putty and worked.
Thanks for sharing this.
You would actually find this resolution, if you follow link to "Server unexpectedly closed network connection" from:
Mystical2k
This helped!
Thanks a lot
For me too after days of trying out different file configs! Awesome!
Charles87
Anonymous wrote:
metal wrote:
Hello!
This worked for me too! THanks for the tip!
noviceintech
I got this error but then change my SFTP version down from 5 to 3 then it worked...
NoviceInTech
I got this error but then changed my SFTP version down from 5 to 3 then it worked...
Thanks for your report. What SFTP server are you connecting to?
ITHo
Hey Guys I Have got a problem with SFTP... if im just use bitvise and proxyfire its not workin but i use Tunnel its workin so how can i make this cause SFTP channel clsed by server if i use just bitvise and proxyfire... im try for use bluestcak cause i dont have idea for use tunneling fr blustack...
thx before... Smile
thx before... Smile
Sorry, your post does not include enough information.
Please read how to troubleshoot problems with WinSCP. If it turns out that you are not able to help yourself, read how to ask for support or report bugs efficiently, so others can help you.
Also please start a new thread for your problem.
Raju Balpande
Hi all,
I faced this error, it was due to my password was expired, When I tried to login to terminal console using putty it asked me to reset the password. After resetting password I am able to log in using WinSCP.
Raju Balpande.
Can you connect with any other SFTP client? Did you contact a server administrator?
lakshman
This works for me excellent
Posted: 19 Jan 2011 08:47
PostWinSCP: File protocol & Shell
[Reply with quote]
