Topic ""Ungltiger Zugriff auf den Speicher""
setti
Ich nutze Windows Server 2003 (Standard) fr x64.
Ich denke ma da gibts ein kleines Problem mit dem Speicherzugriff unter 64Bit <-> 32Bit.
Hoffe es kommt da ein BugFix fr raus.
Das Programm lsst sich so starten, merkt sich aber nicht, die Einstellungen fr Editoren usw.)
Dennoch KLASSE ARBEIT!
Genau das selbe Problem haben wir hier auch.
Hat denn jemand schon gehrt, dass an dem Problem gearbeitet wird? Ich wollte das Tool einsetzen und habe unter Win2003 64bit erstmal nur die genannten Fehlermeldungen.
pat
I get the message "Ungltiger Zugriff auf den Speicher" ("Invalid access to memory") under Win32 too - at every start. And the settings aren't stored (or restored). Independent of using INI or registry as storage for the configuration.
Does it happen if you remove german translation?
jack-pot
Hi
I'm not pat, but I had the same error on every start and exit. Although my settings were not affected.
Without "WinSCP3.de" (renamed), the error is gone. Very Happy
If you need some testing done by me, let me know.
Thorsten
What version of WinSCP are you using? Do you have up to date German translation? Does the error go away, if you keep the German translation, only changing the language to English (in previous session)?
jack-pot
Skip to --- for the solution...
I'm using version 3.8.1 (Build 328), clean install from
winscp381setupintl.exe.
WinSCP3.de is dated 2006-05-07 20:29
If I have WinSCP3.de in the winscp program folder, I get the error message on launch (and a german user interface).
Clicking the "Languages" button (NOT translated into german), I get another error message (Ungltiger...) and no language selection dialog.
Clicking again on "Languages" gives a dropdown list with only "mehr Sprachen..." as list item (which opens http://winscp.net/eng/translations.php).
So I can't change languages from inside winscp.
With both the german and danish language files present I get the same behavior as with only the german one (error on start, exit and "Languages" button).
With only the danish language file, I get no error message on start and exit, but a "Invalid access to memory" error on the first click on the "Languages" button and a _english_ user interface.
Argh. And after writing this all I was about to write something about my OS (XP-Prof SP2) and gear (Athlon64).
And I was thinking about the DEP setting (enabled for all exept for those I select).
And the solution is: put WinSCP into the DEP-exeption-list and the errors are gone Very Happy
So for others searching for a "Ungltiger Zugriff auf den Speicher"-cure:
go to Microsofts "How to Configure Memory Protection in Windows XP SP2": http://www.microsoft.com/technet/security/prodtech/windowsxp/depcnfxp.mspx
scroll down to "Enabling the DEP Exception List", follow the text and add WinSCP3.exe to the exception list.
A happy rest of the week for all
Thorsten
Thanks!
pat
same on my PC. I removed the german translation file and it works.
There is a secondary problem in the same issue. With the german translation file WinSCP was unable to store the preferences. Everytime I restart WiNSCP it starts with the same (ugly) settings. Now (without the german translation file) I can see more sensefull settings and automatic preference saving ant program termination works too.
My hint: Maybe you're using a translated specifier for some registry keys? This would explain, why I have "no" settings in the german version. And if translation is used just at loading the preferences, this would explain why the automatic saved settings are not found at next program start.
Maybe this helps. keep hackin'
mo
Thanks!! DEP really is the solution!
spuky
he is fully right, I can work on my vista 64 system with german translation. And also save settings.. as soon as I enabled DEP in opt out mode Winscp would bring up this error.. and won't use the allready made settings..
as soon as i opted it out of DEP it is working normal...
This problem was resolved already and will be fixed in the next release.
