Topic "how can i include private key in the open command"
hputumbaka@...
I would like open a new session using the private key
ex: open username:password@domainname.com
I dont see an option to include private key in the above command, I would like to automate the script I do not want to use GUI. I would appreciate if some can reply me. thank you.
You have several options:
using the private key option, how do you call the script file?
what is the syntax or is this even possible?
How do I get and put files out there using private key option?
In the latest version you have one more option, to use -privatekey switch with "open" command.
why
why! i using in script .txt
open sftp://<user>@<host> -privatekey=<privatekey Name>.ppk
it's error : Too many parameters for command 'open'.
You are probably using an old version of WinSCP. The parameter is supported since 4.1.x only.
i am using winscp 4.2.7, and I still get the same error message.
i am using winscp 4.2.7, and I still get the same error message. Could any one advise what is the correct command? what shall I do?
Post an example of the command you are using.
pradip
Error
Pradip Kumar Nayak
i am using winscp version 4.2.8.
when i excute the attached script file i got an error message
[Too many parameters for command 'open'].
Please help me to excute the script.
Thank you in advance.
Regards,
Pradip
test.txt (284 Bytes) [Download]
Description: (none)
Pleaase read FAQ:
http://winscp.net/eng/docs/faq_script_switch
!!!!!!!!!!!finaly found somebody who can help !!!!!!!!!!!!!!!! thanks
