| Author | Message |
Posted: 16 Apr 2003 00:31
My proxy is giving me a 403 error. Its a squid proxy .
what does this mean? the server is openSSH on Win XP client is on win2k behind a firewall. I set the proxy settings to the proper one. Thanks . -------------------------------------------------------------------------- . WinSCP Version 2.2.3 (Build 139) . Login time: Tuesday, April 15, 2003 7:24:03 PM . -------------------------------------------------------------------------- . Session name: XXXXX@167.184.29.26 . Host name: 167.184.29.26 (Port: 22) . User name: Eliyahu (Password: Yes, Key file: No) . SSH protocol version: 1; Compression: No . Agent forwarding: No; TIS/CryptoCard: No; KI: Yes . Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No . Ping interval: 0 sec (0 = off); Timeout: 15 sec . SSH Bugs: A,A,A,A,A,A,A, . Proxy: HTTP . HostName: proxy (Port: 8080); Username: XXXXX; Passwd: Yes . Return code variable: Autodetect; Lookup user groups: Yes . Shell: default, EOL: 0 . Local directory: default, Remote directory: home, Update: No . Clear aliases: Yes, Unset nat.vars: Yes . Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No . -------------------------------------------------------------------------- . Looking up host "167.184.29.26" . Connecting to 167.184.29.26 port 22 . Proxy error: 403 Forbidden * (ESshFatal) Proxy error: 403 Forbidden |
| Advertisements |
Posted: 16 Apr 2003 00:58
I tried the same settings with putty withr the same results
Posted: 16 Apr 2003 01:39
Looks like Squid is blocking it
I tried running etunnel and from etunnel logs it looks like its being blocked by the proxy. I guess I'm stuck. Here is what the proxy returned (from etunnel logs): <HTML><HEAD> <TITLE>ERROR: The requested URL could not be retrieved</TITLE> </HEAD><BODY> <H1>ERROR</H1> <H2>The requested URL could not be retrieved</H2> <HR> <P> While trying to retrieve the URL: <A HREF="xxxxxxxxx:22">xxxxxxxxxx:22</A> <P> The following error was encountered: <UL> <LI> <STRONG> Access Denied. </STRONG> <P> Access control configuration prevents your request from being allowed at this time. Please contact your service provider if you feel this is incorrect. </UL> <P>Your cache administrator is <A HREF="mailto:xxx@xxx">xxxx@xxxx</A>. <br clear="all"> <hr noshade size=1> Generated Wed, 16 Apr 2003 00:00:20 GMT by squid1.xx.xxx.com (Squid/2.4.STABLE1) </BODY></HTML> |
Posted: 31 Mar 2009 19:35
Anonymous wrote: I tried the same settings with putty withr the same results For proxy+ need Proxy Type=socks4 and port=1080 in putty proxy setting. Work fine! |
| Advertisements |
Site design by Black Gate
