Topic "Scripting of WINSCP oder "Command-line" Version?"
dab
I have to work with a scponly ssh-server, which works perfectly with WINSCP. But I have to do transfers from another application. How can I realize this???
First I thinked about use of pscp (beacause that some part of WINSCP is based on putty?) to do the transfers but i can't do "ls", "md" or "rm" with pscp and in WINSCP it works perfect!
Thanks for a short feedback.
Daniel
I'm not sure, but maybe PLINK (another application from PuTTY package) might do the work, just redirect list of commands to it. Let me know, if it does not work.
dab
Thanks, plink is working almost perfectly.
Possible I'm to stupied to use the -m option (batch-mode) but this is real plink question and has no more to do with winscp so it's a bit OT. But feel free to quote me a line about the following error: If I try to use batch-mode and my textfile look like this(as easy example):
pwd
pwd
I get the following error:
invalid characters in scp command!
here:
pwd
When i have only one command line then it works fine ...
try using a wildcard to match this file/directory
here:
pwd
I've never used PLINK. But I would suggest you to check, whether you have UNIX-style end-of-line character (LF = 10) in your input file.
