Topic "synchronization of small files"
rodrigomartinho
Every time i try to synchronize my personal folder with my Linux server using option "file size", Winscp thinks a lot of small files have diferent sizes when they actually don't have. I have deleted them and copied again so i could be sure of that.
Is there a way this doesn't happen?
What version? Can you try 3.8 beta? If it does not work, can you post (or email) screenshow of synchronisation checklist window?
rodrigomartinho
Thanks for your help.
I'm already using the new 3.8 beta (started using it in order to see if that wouldn't happen in this version), but the problem happens the same way the previous version.
How can I post an image?[/img]
Either upload it to some site and post a link or email it to me.
rodrigomartinho
[/img]
I guess you have "file size" set as compare criterion on the "synchronize" dialog, do you? And you have "ascii" transfer mode configured for .txt files, making its file size change on transfer, do you? See also documentation.
