Topic "Relaunching 3.8 Beta Doesn't Save Last Exited Directory"
in WinSCP3 vers 3.8 build 312, I'm unable to save the last entered remote and local directories. It aleays defaults the unix home directory and mo local directory.
How is the last entered directory saved in 3.8 so each tme I login, i can return to the previously entered directory?
In version 3.8 their are two options for the directory change folder. Location Properties (Default) and Bookmarks.
If Location Properties is selected, the Windows and Unix directories default to the C:\docuemnts and your home unix directory. Selecting Bookmarks on the Open Directory menu solves the problem.
I didn't know what to look for on the help meun to find this.
I do not understand. Do you mean that if location profiles are the preferred mean of bookmark managing, you always get the home directories on login?
