Topic "One-Way Synchronization, and Deleting"
nriggs
I like the synchronization capabilities of WinSCP, but Im looking for one extra feature: Is it possible for me to have it synchronize files from the local to remote location, and delete the local file once the transmission is complete?
I do not see a use case for this. Can you tell me why your need that, I may find another solution for you.
mayhem
Hi Prikryl,
I too am looking for a function like this, Im using another program which generates various files into a local directory.
I hoing maybe I ca use your program to run an a scheduled script say every hour to transfer all files starting with names example* to a remote SFTP, once its transfered them to delete from the local machine.
Please can you advise if this sounds like somthing I could do ?
Many Thanks
OK, this can be implemented. But it is not synchronisation. It's just uplod of the files, isn't it?
nriggs
Yea, Synchronization isn't the right word I guess. But I basically need a way to move any files that fall into a specified folder to the remote location. The Synchronization options allowed me many of the optoins I needed: to monitor a folder and upload it when a new file landed if there were only a check box to delete the originally files upon completion.
Also, Is there a way to start WinSCP (via command line perhaps) and have it lunch directly into the Synchronization functionality. Or will I have to manually start it every time the computer restarts?
Use /synchronize flag. See documentation.
sapas
I need "move" functionality from script too.
The original move (mv) command works only on remote side and can't use '*' in file list.
User "nriggs" says "One-Way Synchronization, and Deleting" and this is a good approximation of this problem.
I want to use this feature to transfer EDI files from my customer.
'mv' can use * in file list.
Anyway deleting files after download is already implemented. It will be included into the next major version.
Waiting anxiously support for this feature!!! Thanks for such a great tool!
Have you implemented it as a new command, or as an option for the get command?
An option for the get command.
I have added topic on deleting files after synchronization to FAQ.
