Topic "using call to produce dynamic file names"
sales@rwb.com.au
Hi all,
I'm using a script that uses `call` to dump a database:
call mysqldump mydb | gzip > /tmp/mydb.sql.gz
this works just fine. But, what I would like is to call the file with a date/time tagged with it. e.g
call mysqldump mydb | gzip > /tmp/mydb_23-04-06_11-23am.sql.gz
of course the 23-04-06_11-23am part needs to be automated.
I can do this by calling a shell script e.g call foo.sh but I was wondering if there were any linux shell gurus who might be able to help me do it straight from the winscp call syntax.
Something like:
option batch on
option transfer binary
call datevar=date '+ %d_%m_%y__%H-%M'
call mysqldump mydb | gzip > /tmp/mydb_$datevar.sql.gz
get /tmp/mydb_$datevar.sql.gz c:\backupfolder\
close
ANOTHER alternative would be to always dump it as the same name in /tmp then do a
`call rename samename namewithdynamicdate
then get it. But alas I can't do this other than in a .sh file , so a solution here is just as sufficient.
thanks
sam
I'm not a linux guru Smile but you can try following:
call mysqldump mydb | gzip > /tmp/mydb_`date '+ %d_%m_%y__%H-%M'`.sql.gz
sales@rwb.com.au
mysqldump test | gzip > /tmp/mydb_`date '+ %d_%m_%y__%H-%M'`.sql.gz
bash: /tmp/mydb_`date '+ %d_%m_%y__%H-%M'`.sql.gz: ambiguous redirect
Well, it works for me, at least on command-line. I haven't tried that via "call".
