Topic "Direkt scp to destination directory"
Coyote
is it possible to copy directly from a unix server to a windows directory without using a temp-dir in which the file is temporarily stored and copied again? (It wastes a lot of space and time...)
Coyote
Justin
Plus, it doesn't delete the temp directory, so this is a security problem.
Please read FAQ.
Shouldn't it delete the files after it copies them, instead of leaving them in the temp folder?
Yes it should. It does not for you?
Note: Files are deleted few minutes after transfer is finished. This is because I cannot detect when Windows finishes coping files from temp directory to destination directory. If you close WinSCP too early, files remain in temp folder. Otherwise thay should be deleted.
