Topic "Can I limit bandwidth when running in /console mode"
I do not see a switch in the documentation that will allow me to limit the upload speed as exists in the GUI. I would like to run a batch sync in the background at a slow enough speed so that it does not affect my online speed. In other words, as a cable modem user, I have a limited amount of upload capacity to the internet and winscp is so efficient that it can use it all and, therefore, I would like to limit it on my windows xp machine.
Added to TODO list.
prikryl wrote:
Added to TODO list.
Thank you.
Has this been done yet?
No.
Has the feature been added yet?
Yes. This request is tracked here.
does is a far plugin support bandwidth limit?
Yes, since 1.6.1.
Shiv
Hi, Can I use the 'unlimited' like in the GUI instead of a kibps? Meaning I would like the application to utilize the maximum bandwidth available.
Regards,
Shiv
Use empty value or 0. Though unlimited is the default. So you may not need to do anything.
Thank you very much this helps!
