Topic "Command Line destination specification"
RickW
I'm trying to do a copy of a file using scp, from the command line, so it can be run from within PHP. How do I specify the destination location, so that the script is not prompted? Maybe I didn't specify my search very well, but I couldn't find an answer for this in the forum or documentation....
Type "help put" into console.
Pedro
Trying to set up a "drag & drop" icon for a non-technical user to be able to back up some files from their desktop. Is there a way to do this without them being prompted for ANY information?
I have a drag & drop icon set up, it does copy the files just as I want but it pops up the "Copy" dialog box every time and they have to hit the "Copy" button without changing anything.
Suggestions?
If you use /upload parameter, that if should be enough to add /defaults parameter too.
