Topic "automatic resume is not working"
aperje
I am uploading large files (400 MB +) to a server. It happens twice to fivetimes within the transfer of a file that the connection drops.
Then a message pops up offering me the possibility to reconnect. I push that button and it works. Until next time.
This should go automatic but it does not. Where is the problem.
Always I choose background transfer. I did not check the transfer confirmation checkbox. I activatet the automatic resume after 5 sec. for files larger than 100 kB.
I use the latest ver. 3.81.
Maybe you can give me a hint.
Thank you in advance.
What does happen "next time"?
Sorry for my English, I am German.
With " until Next time " I mean until it breaks again and the message pops up again.
My problem is that it resumes not automatic. I have to press the connect button.
Just one more question. Is it possible, that the automatic just does not work in background operation.
I had a 800 MB transfer running in foreground without any breaks.
May be Smile I'll test it.
I've done many tests and it definitelly works. At least for me. As long as you have automatic reconnect enabled and confirmations disabled for background transfers, you should not be prompted not a once.
