Topic "alias ls="ls -g" error"
shornste
If I set WinSCP to alias ls to ls -g it does not work. The reason seems to be that my shell (/usr/local/bin/tcsh) does not accept aliases with the = sign in them (i define my aliases as [alias ls 'ls -g"]) and from the logs it seems that WinSCP tries to alias ls by using the command [alias ls="ls -g"]
I have tried aliasing the command myself in my .cshrc file and it works fine. But unfortunately I also have rm, mv, cp aliased to[rm -i] etc. If I don't have winSCP remove all aliases then those commands cause deleting, copying and moving to fail.
Is there a way to edit what command winSCP issues when it is set to "alias ls to display group name?"
Thanks!
No it is not possible now Sad
Have you tried to specify /bin/bash on Shell tab of login dialog?
Yes, but that did not work. However, setting the shell to /usr/bin/ksh DID work.
Problem solved.
thanks!
Now that I can use it, I hope WinSCP was worth all the trouble!! Wink
Was it?
Problem solved.
thanks!
I tried all this stuff and it still doesn't work. Crying or Very sad
Guess I'm going to have to find something else.
