Topic "WinSCP hanging when copying files"
jdunne
Hi, when copying files from my machine with WinSCP to a remote machine, the program keeps hanging. task manager tells me it isnt respnding so i shut it down. It only happens when i am copying to this one machine in particular, no others.
Any suggestions?
Joop van buuren
After closing the program WinSCp3 still in memory with 100% cpu (version 3.8.1)
Any ideas ???
jdunne
it hangs while its copying the files, usually between 0 - 10%...
Please post a log file.
brent.saner@...
got the same problem.
[code:1:7e36dd752a]. 2006-05-19 21:52:39.203 --------------------------------------------------------------------------
. 2006-05-19 21:52:39.203 WinSCP Version 3.8.1 (Build 328) (OS 5.1.2600 Service Pack 2)
. 2006-05-19 21:52:39.203 Login time: Friday, May 19, 2006 21:52:39
. 2006-05-19 21:52:39.203 Session name: root@www.notebookarmy.org
. 2006-05-19 21:52:39.203 Host name: www.notebookarmy.org (Port: 22)
. 2006-05-19 21:52:39.203 User name: root (Password: Yes, Key file: No)
. 2006-05-19 21:52:39.203 Transfer Protocol: SFTP (SCP)
. 2006-05-19 21:52:39.203 SSH protocol version: 2; Compression: No
. 2006-05-19 21:52:39.203 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2006-05-19 21:52:39.203 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2006-05-19 21:52:39.203 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2006-05-19 21:52:39.203 SSH Bugs: -,-,-,-,-,-,-,-
. 2006-05-19 21:52:39.203 SFTP Bugs: -,-,-
. 2006-05-19 21:52:39.203 Proxy: none
. 2006-05-19 21:52:39.203 Return code variable: Autodetect; Lookup user groups: Yes
. 2006-05-19 21:52:39.203 Shell: default, EOL: 0
. 2006-05-19 21:52:39.203 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2006-05-19 21:52:39.203 Cache directory changes: Yes, Permanent: Yes
. 2006-05-19 21:52:39.203 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2006-05-19 21:52:39.203 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2006-05-19 21:52:39.296 Looking up host "www.notebookarmy.org"
. 2006-05-19 21:52:39.484 Connecting to 64.202.189.170 port 22
. 2006-05-19 21:53:00.453 Failed to connect to 64.202.189.170: Network error: Connection timed out
. 2006-05-19 21:53:00.468 Attempt to close connection due to fatal exception:
* 2006-05-19 21:53:00.484 Network error: Connection timed out
. 2006-05-19 21:53:00.500 Closing connection.
* 2006-05-19 21:53:00.515 (ESshFatal) Network error: Connection timed out
. 2006-05-19 21:53:48.531 --------------------------------------------------------------------------
. 2006-05-19 21:53:48.531 WinSCP Version 3.8.1 (Build 328) (OS 5.1.2600 Service Pack 2)
. 2006-05-19 21:53:48.531 Login time: Friday, May 19, 2006 21:53:48
. 2006-05-19 21:53:48.531 Session name: root@www.notebookarmy.org
. 2006-05-19 21:53:48.531 Host name: 69.249.134.20 (Port: 22)
. 2006-05-19 21:53:48.531 User name: root (Password: Yes, Key file: No)
. 2006-05-19 21:53:48.531 Transfer Protocol: SFTP (SCP)
. 2006-05-19 21:53:48.531 SSH protocol version: 2; Compression: No
. 2006-05-19 21:53:48.531 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2006-05-19 21:53:48.531 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2006-05-19 21:53:48.531 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2006-05-19 21:53:48.531 SSH Bugs: -,-,-,-,-,-,-,-
. 2006-05-19 21:53:48.531 SFTP Bugs: -,-,-
. 2006-05-19 21:53:48.531 Proxy: none
. 2006-05-19 21:53:48.531 Return code variable: Autodetect; Lookup user groups: Yes
. 2006-05-19 21:53:48.531 Shell: default, EOL: 0
. 2006-05-19 21:53:48.546 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2006-05-19 21:53:48.546 Cache directory changes: Yes, Permanent: Yes
. 2006-05-19 21:53:48.546 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2006-05-19 21:53:48.546 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2006-05-19 21:53:48.546 --------------------------------------------------------------------------
. 2006-05-19 21:53:48.546 Looking up host "69.249.134.20"
. 2006-05-19 21:53:48.546 Connecting to 69.249.134.20 port 22
. 2006-05-19 21:53:48.562 Waiting for the server to continue with the initialisation
. 2006-05-19 21:53:48.562 Looking for incoming data
. 2006-05-19 21:53:48.562 Select result is 1
. 2006-05-19 21:53:48.562 Server version: SSH-2.0-OpenSSH_4.2p1 Debian-5
. 2006-05-19 21:53:48.562 We claim version: SSH-2.0-WinSCP_release_3.8.1
. 2006-05-19 21:53:48.578 Using SSH protocol version 2
. 2006-05-19 21:53:48.578 Waiting for the server to continue with the initialisation
. 2006-05-19 21:53:48.578 Looking for incoming data
. 2006-05-19 21:53:48.578 Select result is 1
. 2006-05-19 21:53:48.578 Doing Diffie-Hellman group exchange
. 2006-05-19 21:53:50.468 Select result is 1
. 2006-05-19 21:53:50.468 Doing Diffie-Hellman key exchange
. 2006-05-19 21:53:50.765 Waiting for the server to continue with the initialisation
. 2006-05-19 21:53:50.765 Looking for incoming data
. 2006-05-19 21:53:54.640 Select result is 1
. 2006-05-19 21:53:54.984 Host key fingerprint is:
. 2006-05-19 21:53:54.984 ssh-rsa 2048 70:53:66:a7:77:a3:0a:63:96:82:aa:82:0c:30:71:46
. 2006-05-19 21:53:54.984 Initialised AES-256 client->server encryption
. 2006-05-19 21:53:54.984 Initialised HMAC-SHA1 client->server MAC algorithm
. 2006-05-19 21:53:54.984 Initialised AES-256 server->client encryption
. 2006-05-19 21:53:54.984 Initialised HMAC-SHA1 server->client MAC algorithm
. 2006-05-19 21:53:54.984 Waiting for the server to continue with the initialisation
. 2006-05-19 21:53:54.984 Looking for incoming data
. 2006-05-19 21:53:55.000 Select result is 1
! 2006-05-19 21:53:55.000 Using username "root".
. 2006-05-19 21:53:55.000 Waiting for the server to continue with the initialisation
. 2006-05-19 21:53:55.000 Looking for incoming data
. 2006-05-19 21:53:55.015 Select result is 1
. 2006-05-19 21:53:55.015 Session password prompt (root@69.249.134.20's password: )
. 2006-05-19 21:53:55.015 Using stored password.
! 2006-05-19 21:53:55.031 Authenticating with pre-entered password.
. 2006-05-19 21:53:55.031 Sent password
. 2006-05-19 21:53:55.031 Waiting for the server to continue with the initialisation
. 2006-05-19 21:53:55.031 Looking for incoming data
. 2006-05-19 21:53:55.031 Select result is 1
. 2006-05-19 21:53:55.031 Access granted
. 2006-05-19 21:53:55.031 Opened channel for session
. 2006-05-19 21:53:55.125 Select result is 1
. 2006-05-19 21:53:55.125 Started a shell/command
. 2006-05-19 21:53:55.125 --------------------------------------------------------------------------
. 2006-05-19 21:53:55.125 Using SFTP protocol.
. 2006-05-19 21:53:55.125 Doing startup conversation with host.
> 2006-05-19 21:53:55.140 Type: SSH_FXP_INIT, Size: 5, Number: -1
> 2006-05-19 21:53:55.140 01,00,00,00,05,
. 2006-05-19 21:53:55.140 Sent 9 bytes
. 2006-05-19 21:53:55.140 There are 0 bytes remaining in the send buffer
. 2006-05-19 21:53:55.140 Waiting for another 4 bytes
. 2006-05-19 21:53:55.140 Looking for incoming data
. 2006-05-19 21:53:55.156 Select result is 1
. 2006-05-19 21:53:55.156 Received 4 bytes
. 2006-05-19 21:53:55.156 Received 5 bytes
< 2006-05-19 21:53:55.156 Type: SSH_FXP_VERSION, Size: 5, Number: -1
< 2006-05-19 21:53:55.156 02,00,00,00,03,
. 2006-05-19 21:53:55.156 SFTP version 3 negotiated.
. 2006-05-19 21:53:55.156 We believe the server has signed timestamps bug
. 2006-05-19 21:53:55.156 We will use UTF-8 strings for status messages only
. 2006-05-19 21:53:55.156 Limiting packet size to OpenSSH limit of 262148 bytes
. 2006-05-19 21:53:55.156 Getting current directory name.
. 2006-05-19 21:53:55.156 Getting real path for '.'
> 2006-05-19 21:53:55.156 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
> 2006-05-19 21:53:55.156 10,00,00,00,10,00,00,00,01,2E,
. 2006-05-19 21:53:55.156 Sent 14 bytes
. 2006-05-19 21:53:55.156 There are 0 bytes remaining in the send buffer
. 2006-05-19 21:53:55.156 Waiting for another 4 bytes
. 2006-05-19 21:53:55.156 Looking for incoming data
. 2006-05-19 21:53:55.156 Received 31 bytes
< 2006-05-19 21:53:55.156 Type: SSH_FXP_NAME, Size: 31, Number: 16
< 2006-05-19 21:53:55.156 68,00,00,00,10,00,00,00,01,00,00,00,05,2F,72,6F,6F,74,00,00,00,05,2F,72,6F,
< 2006-05-19 21:53:55.156 6F,74,00,00,00,00,
. 2006-05-19 21:53:55.156 Real path is '/root'
. 2006-05-19 21:53:55.156 Listing directory "/root".
> 2006-05-19 21:53:55.156 Type: SSH_FXP_OPENDIR, Size: 14, Number: 267
> 2006-05-19 21:53:55.156 0B,00,00,01,0B,00,00,00,05,2F,72,6F,6F,74,
. 2006-05-19 21:53:55.156 Sent 18 bytes
. 2006-05-19 21:53:55.156 Received 13 bytes
< 2006-05-19 21:53:55.156 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
< 2006-05-19 21:53:55.156 66,00,00,01,0B,00,00,00,04,00,00,00,00,
> 2006-05-19 21:53:55.156 Type: SSH_FXP_READDIR, Size: 13, Number: 524
> 2006-05-19 21:53:55.156 0C,00,00,02,0C,00,00,00,04,00,00,00,00,
. 2006-05-19 21:53:55.156 Sent 17 bytes
. 2006-05-19 21:53:55.171 Select result is 1
. 2006-05-19 21:53:55.171 Waiting for another 4 bytes
. 2006-05-19 21:53:55.171 Looking for incoming data
. 2006-05-19 21:53:55.171 Received 4 bytes
. 2006-05-19 21:53:55.171 Received 6021 bytes
< 2006-05-19 21:53:55.171 Type: SSH_FXP_NAME, Size: 6021, Number: 524
< 2006-05-19 21:53:55.187 68,00,00,02,0C,00,00,00,34,00,00,00,01,2E,00,00,00,39,64,72,77,78,72,2D,78,
< 2006-05-19 21:53:55.187 72,2D,78,20,20,20,33,33,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,
< 2006-05-19 21:53:55.187 20,20,20,20,20,20,32,30,34,38,20,4D,61,79,20,20,32,20,31,35,3A,32,32,20,2E,
< 2006-05-19 21:53:55.187 00,00,00,0F,00,00,00,00,00,00,08,00,00,00,00,00,00,00,00,00,00,00,41,ED,44,
< 2006-05-19 21:53:55.187 6E,76,B6,44,57,B1,5D,00,00,00,02,2E,2E,00,00,00,3A,64,72,77,78,72,2D,78,72,
< 2006-05-19 21:53:55.187 2D,78,20,20,20,32,33,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,
< 2006-05-19 21:53:55.187 20,20,20,20,20,31,30,32,34,20,4D,61,79,20,31,39,20,31,39,3A,30,30,20,2E,2E,
< 2006-05-19 21:53:55.187 00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,ED,44,
< 2006-05-19 21:53:55.187 6E,75,3E,44,6E,4D,F4,00,00,00,08,2E,70,72,6F,66,69,6C,65,00,00,00,40,2D,72,
< 2006-05-19 21:53:55.187 77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,
< 2006-05-19 21:53:55.187 6F,74,20,20,20,20,20,20,20,20,20,20,31,31,30,20,4E,6F,76,20,31,30,20,20,32,
< 2006-05-19 21:53:55.187 30,30,34,20,2E,70,72,6F,66,69,6C,65,00,00,00,0F,00,00,00,00,00,00,00,6E,00,
< 2006-05-19 21:53:55.187 00,00,00,00,00,00,00,00,00,81,A4,44,6E,75,27,41,92,3D,5B,00,00,00,07,2E,62,
< 2006-05-19 21:53:55.187 61,73,68,72,63,00,00,00,3F,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,
< 2006-05-19 21:53:55.187 72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,34,31,
< 2006-05-19 21:53:55.187 32,20,44,65,63,20,31,35,20,20,32,30,30,34,20,2E,62,61,73,68,72,63,00,00,00,
< 2006-05-19 21:53:55.187 0F,00,00,00,00,00,00,01,9C,00,00,00,00,00,00,00,00,00,00,81,A4,44,6E,76,B6,
< 2006-05-19 21:53:55.187 41,C0,C0,67,00,00,00,09,2E,61,70,74,69,74,75,64,65,00,00,00,41,64,72,77,78,
< 2006-05-19 21:53:55.187 2D,2D,2D,2D,2D,2D,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,
< 2006-05-19 21:53:55.187 20,20,20,20,20,20,20,20,20,31,30,32,34,20,4D,61,72,20,31,36,20,31,32,3A,30,
< 2006-05-19 21:53:55.187 37,20,2E,61,70,74,69,74,75,64,65,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,
< 2006-05-19 21:53:55.187 00,00,00,00,00,00,00,00,41,C0,44,5F,BE,0E,44,19,9B,38,00,00,00,07,2E,67,6E,
< 2006-05-19 21:53:55.187 6F,6D,65,32,00,00,00,3F,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,31,30,20,72,
< 2006-05-19 21:53:55.187 6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,31,30,32,34,
< 2006-05-19 21:53:55.187 20,4D,61,79,20,20,32,20,31,34,3A,33,31,20,2E,67,6E,6F,6D,65,32,00,00,00,0F,
< 2006-05-19 21:53:55.187 00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,C0,44,5F,BE,0E,44,
< 2006-05-19 21:53:55.187 57,A5,8B,00,00,00,06,2E,67,63,6F,6E,66,00,00,00,3E,64,72,77,78,2D,2D,2D,2D,
< 2006-05-19 21:53:55.187 2D,2D,20,20,20,20,34,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,
< 2006-05-19 21:53:55.187 20,20,20,20,20,31,30,32,34,20,4D,61,79,20,20,32,20,31,34,3A,35,33,20,2E,67,
< 2006-05-19 21:53:55.187 63,6F,6E,66,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,
< 2006-05-19 21:53:55.187 00,41,C0,44,5F,BE,0E,44,57,AA,A5,00,00,00,07,2E,67,63,6F,6E,66,64,00,00,00,
< 2006-05-19 21:53:55.187 3F,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,
< 2006-05-19 21:53:55.187 20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,31,30,32,34,20,4D,61,79,20,31,39,
< 2006-05-19 21:53:55.187 20,31,38,3A,33,37,20,2E,67,63,6F,6E,66,64,00,00,00,0F,00,00,00,00,00,00,04,
< 2006-05-19 21:53:55.187 00,00,00,00,00,00,00,00,00,00,00,41,C0,44,5F,BE,0E,44,6E,48,A9,00,00,00,0F,
< 2006-05-19 21:53:55.187 2E,67,6E,6F,6D,65,32,5F,70,72,69,76,61,74,65,00,00,00,47,64,72,77,78,2D,2D,
< 2006-05-19 21:53:55.187 2D,2D,2D,2D,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,
< 2006-05-19 21:53:55.187 20,20,20,20,20,20,20,31,30,32,34,20,4D,61,72,20,31,36,20,31,32,3A,34,34,20,
< 2006-05-19 21:53:55.187 2E,67,6E,6F,6D,65,32,5F,70,72,69,76,61,74,65,00,00,00,0F,00,00,00,00,00,00,
< 2006-05-19 21:53:55.187 04,00,00,00,00,00,00,00,00,00,00,00,41,C0,44,5F,BE,0E,44,19,A4,0F,00,00,00,
< 2006-05-19 21:53:55.187 0D,2E,62,61,73,68,5F,68,69,73,74,6F,72,79,00,00,00,45,2D,72,77,2D,2D,2D,2D,
< 2006-05-19 21:53:55.187 2D,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,
< 2006-05-19 21:53:55.187 20,20,20,20,20,20,35,38,32,32,20,4D,61,79,20,31,39,20,32,30,3A,30,33,20,2E,
< 2006-05-19 21:53:55.187 62,61,73,68,5F,68,69,73,74,6F,72,79,00,00,00,0F,00,00,00,00,00,00,16,BE,00,
< 2006-05-19 21:53:55.187 00,00,00,00,00,00,00,00,00,81,80,44,6E,5F,07,44,6E,5C,EA,00,00,00,09,2E,73,
< 2006-05-19 21:53:55.187 79,6E,61,70,74,69,63,00,00,00,41,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,
< 2006-05-19 21:53:55.187 33,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,31,
< 2006-05-19 21:53:55.187 30,32,34,20,4D,61,79,20,31,39,20,31,38,3A,33,34,20,2E,73,79,6E,61,70,74,69,
< 2006-05-19 21:53:55.187 63,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,C0,
< 2006-05-19 21:53:55.187 44,5F,BE,0E,44,6E,47,E7,00,00,00,0B,2E,58,61,75,74,68,6F,72,69,74,79,00,00,
< 2006-05-19 21:53:55.187 00,43,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,
< 2006-05-19 21:53:55.187 20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,32,31,37,20,4D,61,79,20,20,
< 2006-05-19 21:53:55.187 32,20,31,34,3A,35,33,20,2E,58,61,75,74,68,6F,72,69,74,79,00,00,00,0F,00,00,
< 2006-05-19 21:53:55.187 00,00,00,00,00,D9,00,00,00,00,00,00,00,00,00,00,81,80,44,6E,48,8D,44,57,AA,
< 2006-05-19 21:53:55.187 99,00,00,00,10,2E,78,73,65,73,73,69,6F,6E,2D,65,72,72,6F,72,73,00,00,00,48,
< 2006-05-19 21:53:55.187 2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,
< 2006-05-19 21:53:55.187 72,6F,6F,74,20,20,20,20,20,20,20,20,31,31,39,39,38,20,4D,61,79,20,20,38,20,
< 2006-05-19 21:53:55.187 31,37,3A,35,31,20,2E,78,73,65,73,73,69,6F,6E,2D,65,72,72,6F,72,73,00,00,00,
< 2006-05-19 21:53:55.187 0F,00,00,00,00,00,00,2E,DE,00,00,00,00,00,00,00,00,00,00,81,A4,44,6E,48,72,
< 2006-05-19 21:53:55.187 44,5F,BD,71,00,00,00,05,2E,64,6D,72,63,00,00,00,3D,2D,72,77,2D,2D,2D,2D,2D,
< 2006-05-19 21:53:55.187 2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,
< 2006-05-19 21:53:55.187 20,20,20,20,20,20,20,32,36,20,4D,61,72,20,31,37,20,30,30,3A,35,36,20,2E,64,
< 2006-05-19 21:53:55.187 6D,72,63,00,00,00,0F,00,00,00,00,00,00,00,1A,00,00,00,00,00,00,00,00,00,00,
< 2006-05-19 21:53:55.187 81,80,44,6E,48,72,44,1A,4F,8C,00,00,00,0E,2E,67,73,74,72,65,61,6D,65,72,2D,
< 2006-05-19 21:53:55.187 30,2E,38,00,00,00,46,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,32,20,72,6F,
< 2006-05-19 21:53:55.187 6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,31,30,32,34,20,
< 2006-05-19 21:53:55.187 4D,61,72,20,31,37,20,30,30,3A,35,36,20,2E,67,73,74,72,65,61,6D,65,72,2D,30,
< 2006-05-19 21:53:55.187 2E,38,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,
< 2006-05-19 21:53:55.187 ED,44,6D,9D,2D,44,1A,4F,97,00,00,00,09,2E,6D,65,74,61,63,69,74,79,00,00,00,
< 2006-05-19 21:53:55.187 41,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,33,20,72,6F,6F,74,20,20,20,20,
< 2006-05-19 21:53:55.187 20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,31,30,32,34,20,4D,61,72,20,31,37,
< 2006-05-19 21:53:55.187 20,30,30,3A,35,36,20,2E,6D,65,74,61,63,69,74,79,00,00,00,0F,00,00,00,00,00,
< 2006-05-19 21:53:55.187 00,04,00,00,00,00,00,00,00,00,00,00,00,41,C0,44,5F,BE,0E,44,1A,4F,99,00,00,
< 2006-05-19 21:53:55.187 00,0D,2E,49,43,45,61,75,74,68,6F,72,69,74,79,00,00,00,45,2D,72,77,2D,2D,2D,
< 2006-05-19 21:53:55.187 2D,2D,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,
< 2006-05-19 21:53:55.187 20,20,20,20,20,20,20,31,31,37,33,20,4D,61,79,20,20,32,20,31,34,3A,35,33,20,
< 2006-05-19 21:53:55.187 2E,49,43,45,61,75,74,68,6F,72,69,74,79,00,00,00,0F,00,00,00,00,00,00,04,95,
< 2006-05-19 21:53:55.187 00,00,00,00,00,00,00,00,00,00,81,80,44,6E,48,8E,44,57,AA,9F,00,00,00,09,2E,
< 2006-05-19 21:53:55.187 6E,61,75,74,69,6C,75,73,00,00,00,41,64,72,77,78,72,2D,78,72,2D,78,20,20,20,
< 2006-05-19 21:53:55.187 20,33,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,
< 2006-05-19 21:53:55.187 31,30,32,34,20,4D,61,72,20,31,37,20,30,30,3A,35,36,20,2E,6E,61,75,74,69,6C,
< 2006-05-19 21:53:55.187 75,73,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,
< 2006-05-19 21:53:55.187 ED,44,6D,9D,2D,44,1A,4F,9A,00,00,00,04,2E,77,33,6D,00,00,00,3C,64,72,77,78,
< 2006-05-19 21:53:55.187 20,20,20,20,20,20,20,20,20,31,30,32,34,20,4D,61,72,20,31,37,20,30,31,3A,30,
< 2006-05-19 21:53:55.187 30,20,2E,77,33,6D,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,
< 2006-05-19 21:53:55.187 00,00,00,41,C0,44,5F,BE,0E,44,1A,50,62,00,00,00,11,2E,67,74,6B,72,63,2D,31,
< 2006-05-19 21:53:55.187 2E,32,2D,67,6E,6F,6D,65,32,00,00,00,49,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,
< 2006-05-19 21:53:55.187 20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,
< 2006-05-19 21:53:55.187 20,20,20,38,31,20,4D,61,72,20,31,37,20,30,30,3A,35,36,20,2E,67,74,6B,72,63,
< 2006-05-19 21:53:55.187 2D,31,2E,32,2D,67,6E,6F,6D,65,32,00,00,00,0F,00,00,00,00,00,00,00,51,00,00,
< 2006-05-19 21:53:55.187 00,00,00,00,00,00,00,00,81,A4,44,6E,48,72,44,1A,4F,97,00,00,00,07,44,65,73,
< 2006-05-19 21:53:55.187 6B,74,6F,70,00,00,00,3F,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,33,20,72,
< 2006-05-19 21:53:55.187 20,4D,61,79,20,20,38,20,31,37,3A,35,31,20,44,65,73,6B,74,6F,70,00,00,00,0F,
< 2006-05-19 21:53:55.187 00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,ED,44,6E,61,87,44,
< 2006-05-19 21:53:55.187 5F,BD,68,00,00,00,06,2E,67,6E,6F,6D,65,00,00,00,3E,64,72,77,78,72,2D,78,72,
< 2006-05-19 21:53:55.187 2D,78,20,20,20,20,33,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,
< 2006-05-19 21:53:55.187 20,20,20,20,20,31,30,32,34,20,4D,61,72,20,31,37,20,30,30,3A,35,36,20,2E,67,
< 2006-05-19 21:53:55.187 6E,6F,6D,65,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,
< 2006-05-19 21:53:55.187 00,41,ED,44,6D,9D,2D,44,1A,4F,9A,00,00,00,0E,2E,72,65,63,65,6E,74,6C,79,2D,
< 2006-05-19 21:53:55.187 75,73,65,64,00,00,00,46,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,72,
< 2006-05-19 21:53:55.187 6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,39,32,34,30,
< 2006-05-19 21:53:55.187 20,4D,61,79,20,31,39,20,31,38,3A,33,37,20,2E,72,65,63,65,6E,74,6C,79,2D,75,
< 2006-05-19 21:53:55.187 73,65,64,00,00,00,0F,00,00,00,00,00,00,24,18,00,00,00,00,00,00,00,00,00,00,
< 2006-05-19 21:53:55.187 81,80,44,6E,48,91,44,6E,48,90,00,00,00,08,2E,6D,6F,7A,69,6C,6C,61,00,00,00,
< 2006-05-19 21:53:55.187 40,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,35,20,72,6F,6F,74,20,20,20,20,
< 2006-05-19 21:53:55.187 20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,31,30,32,34,20,4D,61,72,20,32,34,
< 2006-05-19 21:53:55.187 20,31,37,3A,31,39,20,2E,6D,6F,7A,69,6C,6C,61,00,00,00,0F,00,00,00,00,00,00,
< 2006-05-19 21:53:55.187 04,00,00,00,00,00,00,00,00,00,00,00,41,C0,44,5F,BE,0E,44,24,70,86,00,00,00,
< 2006-05-19 21:53:55.187 04,2E,73,73,68,00,00,00,3C,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,32,20,
< 2006-05-19 21:53:55.187 72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,31,30,32,
< 2006-05-19 21:53:55.187 34,20,4D,61,72,20,31,37,20,30,32,3A,32,32,20,2E,73,73,68,00,00,00,0F,00,00,
< 2006-05-19 21:53:55.187 00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,C0,44,5F,BE,0E,44,1A,63,
< 2006-05-19 21:53:55.187 AE,00,00,00,08,2E,6C,65,73,73,68,73,74,00,00,00,40,2D,72,77,2D,2D,2D,2D,2D,
< 2006-05-19 21:53:55.187 20,20,20,20,20,20,20,33,35,20,4D,61,79,20,31,39,20,31,38,3A,35,30,20,2E,6C,
< 2006-05-19 21:53:55.187 65,73,73,68,73,74,00,00,00,0F,00,00,00,00,00,00,00,23,00,00,00,00,00,00,00,
< 2006-05-19 21:53:55.187 00,00,00,81,80,44,6E,4B,45,44,6E,4B,C7,00,00,00,0A,2E,65,76,6F,6C,75,74,69,
< 2006-05-19 21:53:55.187 6F,6E,00,00,00,42,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,37,20,72,6F,6F,
< 2006-05-19 21:53:55.187 74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,31,30,32,34,20,4D,
< 2006-05-19 21:53:55.187 61,72,20,31,37,20,30,32,3A,35,33,20,2E,65,76,6F,6C,75,74,69,6F,6E,00,00,00,
< 2006-05-19 21:53:55.187 0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,ED,44,6D,9D,2E,
< 2006-05-19 21:53:55.187 44,1A,6A,EF,00,00,00,04,2E,76,6E,63,00,00,00,3C,64,72,77,78,72,2D,78,72,2D,
< 2006-05-19 21:53:55.187 78,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,
< 2006-05-19 21:53:55.187 20,20,20,20,31,30,32,34,20,4D,61,72,20,31,37,20,30,33,3A,30,36,20,2E,76,6E,
< 2006-05-19 21:53:55.187 63,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,ED,
< 2006-05-19 21:53:55.187 44,6D,9D,2E,44,1A,6E,01,00,00,00,0B,2E,74,68,75,6D,62,6E,61,69,6C,73,00,00,
< 2006-05-19 21:53:55.187 00,43,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,33,20,72,6F,6F,74,20,20,20,
< 2006-05-19 21:53:55.187 20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,31,30,32,34,20,4D,61,72,20,31,
< 2006-05-19 21:53:55.187 37,20,30,34,3A,30,39,20,2E,74,68,75,6D,62,6E,61,69,6C,73,00,00,00,0F,00,00,
< 2006-05-19 21:53:55.187 00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,C0,44,5F,BE,0E,44,1A,7C,
< 2006-05-19 21:53:55.187 B6,00,00,00,07,2E,73,63,72,65,65,6D,00,00,00,3F,64,72,77,78,2D,2D,2D,2D,2D,
< 2006-05-19 21:53:55.187 2D,20,20,20,20,34,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,
< 2006-05-19 21:53:55.187 20,20,20,20,31,30,32,34,20,4D,61,72,20,31,37,20,30,34,3A,33,31,20,2E,73,63,
< 2006-05-19 21:53:55.187 72,65,65,6D,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,
< 2006-05-19 21:53:55.187 00,41,C0,44,5F,BE,0E,44,1A,81,D8,00,00,00,03,2E,71,74,00,00,00,3B,64,72,77,
< 2006-05-19 21:53:55.187 78,72,2D,78,72,2D,78,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,
< 2006-05-19 21:53:55.187 74,20,20,20,20,20,20,20,20,20,31,30,32,34,20,4D,61,72,20,31,37,20,30,34,3A,
< 2006-05-19 21:53:55.187 33,31,20,2E,71,74,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,
< 2006-05-19 21:53:55.187 00,00,00,41,ED,44,6D,9D,2E,44,1A,82,03,00,00,00,04,2E,6B,64,65,00,00,00,3C,
< 2006-05-19 21:53:55.187 64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,33,20,72,6F,6F,74,20,20,20,20,20,
< 2006-05-19 21:53:55.187 72,6F,6F,74,20,20,20,20,20,20,20,20,20,31,30,32,34,20,4D,61,72,20,31,37,20,
< 2006-05-19 21:53:55.187 30,34,3A,33,31,20,2E,6B,64,65,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,
< 2006-05-19 21:53:55.187 00,00,00,00,00,00,00,41,C0,44,5F,BE,0E,44,1A,82,04,00,00,00,16,49,53,50,43,
< 2006-05-19 21:53:55.187 6F,6E,66,69,67,2D,32,2E,32,2E,30,2E,74,61,72,2E,67,7A,00,00,00,4E,2D,72,77,
< 2006-05-19 21:53:55.187 2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,
< 2006-05-19 21:53:55.187 74,20,20,20,20,20,32,35,38,31,33,30,34,34,20,4D,61,72,20,31,38,20,32,31,3A,
< 2006-05-19 21:53:55.187 32,37,20,49,53,50,43,6F,6E,66,69,67,2D,32,2E,32,2E,30,2E,74,61,72,2E,67,7A,
< 2006-05-19 21:53:55.187 00,00,00,0F,00,00,00,00,01,89,E0,34,00,00,00,00,00,00,00,00,00,00,81,A4,44,
< 2006-05-19 21:53:55.187 1C,C2,37,44,1C,C1,8B,00,00,00,05,2E,67,61,69,6D,00,00,00,3D,64,72,77,78,2D,
< 2006-05-19 21:53:55.187 2D,2D,2D,2D,2D,20,20,20,20,35,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,
< 2006-05-19 21:53:55.187 20,20,20,20,20,20,20,20,31,30,32,34,20,4D,61,79,20,20,32,20,31,35,3A,31,37,
< 2006-05-19 21:53:55.187 20,2E,67,61,69,6D,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,
< 2006-05-19 21:53:55.187 00,00,00,41,C0,44,5F,BE,0E,44,57,B0,48,00,00,00,06,2E,54,72,61,73,68,00,00,
< 2006-05-19 21:53:55.187 00,3E,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,34,20,72,6F,6F,74,20,20,20,
< 2006-05-19 21:53:55.187 20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,31,30,32,34,20,4D,61,79,20,20,
< 2006-05-19 21:53:55.187 38,20,31,37,3A,35,31,20,2E,54,72,61,73,68,00,00,00,0F,00,00,00,00,00,00,04,
< 2006-05-19 21:53:55.187 00,00,00,00,00,00,00,00,00,00,00,41,C0,44,5F,BE,0E,44,5F,BD,68,00,00,00,05,
< 2006-05-19 21:53:55.187 2E,6D,63,6F,70,00,00,00,3D,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,33,20,
< 2006-05-19 21:53:55.187 34,20,4D,61,72,20,31,37,20,30,34,3A,33,31,20,2E,6D,63,6F,70,00,00,00,0F,00,
< 2006-05-19 21:53:55.187 00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,ED,44,6D,9D,2E,44,1A,
< 2006-05-19 21:53:55.187 82,0F,00,00,00,05,2E,78,69,6E,65,00,00,00,3D,64,72,77,78,72,2D,78,72,2D,78,
< 2006-05-19 21:53:55.187 20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,
< 2006-05-19 21:53:55.187 20,20,20,31,30,32,34,20,4D,61,72,20,31,39,20,31,35,3A,34,38,20,2E,78,69,6E,
< 2006-05-19 21:53:55.187 65,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,ED,
< 2006-05-19 21:53:55.187 44,6D,9D,2E,44,1D,C3,AB,00,00,00,04,2E,64,69,61,00,00,00,3C,64,72,77,78,72,
< 2006-05-19 21:53:55.187 2D,78,72,2D,78,20,20,20,20,35,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,
< 2006-05-19 21:53:55.187 20,20,20,20,20,20,20,20,31,30,32,34,20,41,70,72,20,20,34,20,31,38,3A,32,34,
< 2006-05-19 21:53:55.187 20,2E,64,69,61,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,
< 2006-05-19 21:53:55.187 00,00,41,ED,44,6D,9D,2E,44,32,F2,13,00,00,00,07,2E,6D,63,6F,70,72,63,00,00,
< 2006-05-19 21:53:55.187 00,3F,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,
< 2006-05-19 21:53:55.187 20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,20,33,31,20,4D,61,72,20,31,
< 2006-05-19 21:53:55.187 37,20,30,34,3A,33,31,20,2E,6D,63,6F,70,72,63,00,00,00,0F,00,00,00,00,00,00,
< 2006-05-19 21:53:55.187 00,1F,00,00,00,00,00,00,00,00,00,00,81,80,44,6E,48,72,44,1A,82,0F,00,00,00,
< 2006-05-19 21:53:55.187 0D,2E,78,73,63,72,65,65,6E,73,61,76,65,72,00,00,00,45,2D,72,77,2D,72,2D,2D,
< 2006-05-19 21:53:55.187 72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,
< 2006-05-19 21:53:55.187 20,20,20,20,20,31,31,34,33,32,20,4D,61,79,20,20,32,20,31,35,3A,32,32,20,2E,
< 2006-05-19 21:53:55.187 78,73,63,72,65,65,6E,73,61,76,65,72,00,00,00,0F,00,00,00,00,00,00,2C,A8,00,
< 2006-05-19 21:53:55.187 00,00,00,00,00,00,00,00,00,81,A4,44,6E,48,72,44,57,B1,5D,00,00,00,1A,2E,67,
< 2006-05-19 21:53:55.187 6E,6F,6D,65,2D,73,79,73,74,65,6D,2D,6D,6F,6E,69,74,6F,72,2E,72,6F,6F,74,00,
< 2006-05-19 21:53:55.187 00,00,52,73,72,77,78,72,2D,78,72,2D,78,20,20,20,20,31,20,72,6F,6F,74,20,20,
< 2006-05-19 21:53:55.187 20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,20,20,30,20,4D,61,72,20,
< 2006-05-19 21:53:55.187 31,37,20,31,35,3A,30,31,20,2E,67,6E,6F,6D,65,2D,73,79,73,74,65,6D,2D,6D,6F,
< 2006-05-19 21:53:55.187 6E,69,74,6F,72,2E,72,6F,6F,74,00,00,00,0F,00,00,00,00,00,00,00,00,00,00,00,
< 2006-05-19 21:53:55.187 00,00,00,00,00,00,00,C1,ED,44,1B,15,AA,44,1B,15,AA,00,00,00,15,66,69,72,65,
< 2006-05-19 21:53:55.187 68,6F,6C,2D,31,2E,31,39,31,2E,74,61,72,2E,62,7A,32,00,00,00,4D,2D,72,77,2D,
< 2006-05-19 21:53:55.187 72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,
< 2006-05-19 21:53:55.187 20,20,20,20,20,20,20,31,30,35,36,32,33,20,4D,61,72,20,32,30,20,30,32,3A,34,
< 2006-05-19 21:53:55.187 30,20,66,69,72,65,68,6F,6C,2D,31,2E,31,39,31,2E,74,61,72,2E,62,7A,32,00,00,
< 2006-05-19 21:53:55.187 00,0F,00,00,00,00,00,01,9C,97,00,00,00,00,00,00,00,00,00,00,81,A4,44,1E,5C,
< 2006-05-19 21:53:55.187 55,44,1E,5C,55,00,00,00,15,66,69,72,65,68,6F,6C,2D,32,2E,31,39,31,2E,74,61,
< 2006-05-19 21:53:55.187 72,2E,62,7A,32,00,00,00,4D,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,
< 2006-05-19 21:53:55.187 72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,31,30,35,36,32,
< 2006-05-19 21:53:55.187 33,20,4D,61,72,20,32,30,20,30,32,3A,34,31,20,66,69,72,65,68,6F,6C,2D,32,2E,
< 2006-05-19 21:53:55.187 31,39,31,2E,74,61,72,2E,62,7A,32,00,00,00,0F,00,00,00,00,00,01,9C,97,00,00,
< 2006-05-19 21:53:55.187 00,00,00,00,00,00,00,00,81,A4,44,1E,5C,A7,44,1E,5C,A7,00,00,00,09,2E,41,62,
< 2006-05-19 21:53:55.187 69,53,75,69,74,65,00,00,00,41,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,32,
< 2006-05-19 21:53:55.187 20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,31,30,
< 2006-05-19 21:53:55.187 32,34,20,4D,61,72,20,32,39,20,30,32,3A,31,33,20,2E,41,62,69,53,75,69,74,65,
< 2006-05-19 21:53:55.187 00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,C0,44,
< 2006-05-19 21:53:55.187 5F,BE,0E,44,2A,33,7E,00,00,00,05,2E,77,69,6E,65,00,00,00,3D,64,72,77,78,72,
< 2006-05-19 21:53:55.187 2D,78,72,2D,78,20,20,20,20,34,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,
< 2006-05-19 21:53:55.187 20,20,20,20,20,20,20,20,31,30,32,34,20,4D,61,72,20,32,31,20,31,39,3A,34,33,
< 2006-05-19 21:53:55.187 20,2E,77,69,6E,65,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,
< 2006-05-19 21:53:55.187 00,00,00,41,ED,44,6D,9D,2E,44,20,9D,99,00,00,00,09,2E,69,6E,6B,73,63,61,70,
< 2006-05-19 21:53:55.187 65,00,00,00,41,64,72,77,78,72,2D,78,2D,2D,2D,20,20,20,20,32,20,72,6F,6F,74,
< 2006-05-19 21:53:55.187 20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,31,30,32,34,20,41,70,
< 2006-05-19 21:53:55.187 72,20,20,34,20,31,38,3A,32,32,20,2E,69,6E,6B,73,63,61,70,65,00,00,00,0F,00,
< 2006-05-19 21:53:55.187 00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,E8,44,5F,BE,0E,44,32,
< 2006-05-19 21:53:55.187 F1,90,00,00,00,0E,2E,66,6F,6E,74,73,2E,63,61,63,68,65,2D,31,00,00,00,46,2D,
< 2006-05-19 21:53:55.187 72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,
< 2006-05-19 21:53:55.187 6F,6F,74,20,20,20,20,20,20,20,20,31,32,36,38,33,20,4D,61,72,20,32,31,20,31,
< 2006-05-19 21:53:55.187 39,3A,33,36,20,2E,66,6F,6E,74,73,2E,63,61,63,68,65,2D,31,00,00,00,0F,00,00,
< 2006-05-19 21:53:55.187 00,00,00,00,31,8B,00,00,00,00,00,00,00,00,00,00,81,A4,44,6E,48,8F,44,20,9B,
< 2006-05-19 21:53:55.187 F3,00,00,00,09,2E,67,69,6D,70,2D,32,2E,32,00,00,00,41,64,72,77,78,72,2D,78,
< 2006-05-19 21:53:55.187 72,2D,78,20,20,20,32,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,
< 2006-05-19 21:53:55.187 20,20,20,20,20,20,31,30,32,34,20,4D,61,79,20,20,32,20,31,35,3A,31,32,20,2E,
< 2006-05-19 21:53:55.187 67,69,6D,70,2D,32,2E,32,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,
< 2006-05-19 21:53:55.187 00,00,00,00,00,41,ED,44,6D,9D,2E,44,57,AF,22,00,00,00,18,2E,71,75,69,74,65,
< 2006-05-19 21:53:55.187 69,6E,73,61,6E,65,5F,67,69,6D,70,5F,70,6C,75,67,69,6E,00,00,00,50,64,72,77,
< 2006-05-19 21:53:55.187 74,20,20,20,20,20,20,20,20,20,31,30,32,34,20,41,70,72,20,20,34,20,31,38,3A,
< 2006-05-19 21:53:55.187 32,34,20,2E,71,75,69,74,65,69,6E,73,61,6E,65,5F,67,69,6D,70,5F,70,6C,75,67,
< 2006-05-19 21:53:55.187 69,6E,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,
< 2006-05-19 21:53:55.187 ED,44,6D,9D,2E,44,32,F2,28,00,00,00,09,64,74,6F,70,31,2E,67,69,66,00,00,00,
< 2006-05-19 21:53:55.187 41,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,
< 2006-05-19 21:53:55.187 20,72,6F,6F,74,20,20,20,20,20,20,20,20,38,33,37,39,31,20,41,70,72,20,20,34,
< 2006-05-19 21:53:55.187 20,31,38,3A,33,32,20,64,74,6F,70,31,2E,67,69,66,00,00,00,0F,00,00,00,00,00,
< 2006-05-19 21:53:55.187 01,47,4F,00,00,00,00,00,00,00,00,00,00,81,A4,44,6E,5F,A0,44,32,F4,14,00,00,
< 2006-05-19 21:53:55.187 00,0B,2E,6D,61,63,72,6F,6D,65,64,69,61,00,00,00,43,64,72,77,78,2D,2D,2D,2D,
< 2006-05-19 21:53:55.187 2D,2D,20,20,20,20,33,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,
< 2006-05-19 21:53:55.187 20,20,20,20,20,31,30,32,34,20,41,70,72,20,31,38,20,31,38,3A,30,30,20,2E,6D,
< 2006-05-19 21:53:55.187 61,63,72,6F,6D,65,64,69,61,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,
< 2006-05-19 21:53:55.187 00,00,00,00,00,00,41,C0,44,5F,BE,0E,44,45,61,6C,00,00,00,11,73,65,72,76,65,
< 2006-05-19 21:53:55.187 72,20,77,70,61,70,65,72,2E,70,6E,67,00,00,00,49,2D,72,77,2D,72,2D,2D,72,2D,
< 2006-05-19 21:53:55.187 2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,
< 2006-05-19 21:53:55.187 20,32,33,36,34,30,32,34,20,4D,61,79,20,20,32,20,31,35,3A,31,32,20,73,65,72,
< 2006-05-19 21:53:55.187 76,65,72,20,77,70,61,70,65,72,2E,70,6E,67,00,00,00,0F,00,00,00,00,00,24,12,
< 2006-05-19 21:53:55.187 78,00,00,00,00,00,00,00,00,00,00,81,A4,44,6E,5F,BD,44,57,AF,1E,
> 2006-05-19 21:53:55.187 Type: SSH_FXP_READDIR, Size: 13, Number: 780
> 2006-05-19 21:53:55.187 0C,00,00,03,0C,00,00,00,04,00,00,00,00,
. 2006-05-19 21:53:55.187 Sent 17 bytes
. 2006-05-19 21:53:55.187 There are 0 bytes remaining in the send buffer
. 2006-05-19 21:53:55.187 Waiting for another 4 bytes
. 2006-05-19 21:53:55.187 Looking for incoming data
. 2006-05-19 21:53:55.187 Select result is 1
. 2006-05-19 21:53:55.187 Received 4 bytes
. 2006-05-19 21:53:55.187 Received 28 bytes
< 2006-05-19 21:53:55.187 Type: SSH_FXP_STATUS, Size: 28, Number: 780
< 2006-05-19 21:53:55.203 65,00,00,03,0C,00,00,00,01,00,00,00,0B,45,6E,64,20,6F,66,20,66,69,6C,65,00,
< 2006-05-19 21:53:55.203 00,00,00,
< 2006-05-19 21:53:55.203 Status/error code: 1
> 2006-05-19 21:53:55.203 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
> 2006-05-19 21:53:55.203 04,00,00,04,04,00,00,00,04,00,00,00,00,
. 2006-05-19 21:53:55.203 Sent 17 bytes
. 2006-05-19 21:53:55.203 There are 0 bytes remaining in the send buffer
. 2006-05-19 21:53:55.203 Startup conversation with host finished.
. 2006-05-19 21:53:55.828 Session upkeep
. 2006-05-19 21:53:55.828 Select result is 1
. 2006-05-19 21:53:55.828 Detected incoming data while idle
. 2006-05-19 21:53:56.328 Session upkeep
. 2006-05-19 21:53:56.328 Select result is 0
. 2006-05-19 21:53:56.828 Session upkeep
. 2006-05-19 21:53:56.828 Select result is 0
. 2006-05-19 21:53:57.328 Session upkeep
. 2006-05-19 21:53:57.328 Select result is 0
. 2006-05-19 21:53:57.828 Session upkeep
. 2006-05-19 21:53:57.828 Select result is 0
. 2006-05-19 21:53:58.328 Session upkeep
. 2006-05-19 21:53:58.328 Select result is 0
. 2006-05-19 21:53:58.828 Session upkeep
. 2006-05-19 21:53:58.828 Select result is 0
. 2006-05-19 21:53:59.328 Session upkeep
. 2006-05-19 21:53:59.328 Select result is 0
. 2006-05-19 21:53:59.828 Session upkeep
. 2006-05-19 21:53:59.828 Select result is 0
. 2006-05-19 21:54:00.328 Session upkeep
. 2006-05-19 21:54:00.406 Select result is 0
. 2006-05-19 21:54:00.828 Session upkeep
. 2006-05-19 21:54:00.828 Select result is 0
. 2006-05-19 21:54:01.328 Session upkeep
. 2006-05-19 21:54:01.328 Select result is 0
. 2006-05-19 21:54:01.828 Session upkeep
. 2006-05-19 21:54:01.828 Select result is 0
. 2006-05-19 21:54:02.328 Session upkeep
. 2006-05-19 21:54:02.328 Select result is 0
. 2006-05-19 21:54:02.828 Session upkeep
. 2006-05-19 21:54:02.828 Select result is 0
. 2006-05-19 21:54:03.328 Session upkeep
. 2006-05-19 21:54:03.328 Select result is 0
. 2006-05-19 21:54:03.828 Session upkeep
. 2006-05-19 21:54:03.828 Select result is 0
. 2006-05-19 21:54:04.328 Session upkeep
. 2006-05-19 21:54:04.328 Select result is 0
. 2006-05-19 21:54:04.828 Session upkeep
. 2006-05-19 21:54:04.828 Select result is 0
. 2006-05-19 21:54:05.328 Session upkeep
. 2006-05-19 21:54:05.328 Select result is 0
. 2006-05-19 21:54:05.828 Session upkeep
. 2006-05-19 21:54:05.828 Select result is 0
. 2006-05-19 21:54:06.328 Session upkeep
. 2006-05-19 21:54:06.328 Select result is 0
. 2006-05-19 21:54:06.828 Session upkeep
. 2006-05-19 21:54:06.828 Select result is 0
. 2006-05-19 21:54:07.328 Session upkeep
. 2006-05-19 21:54:07.328 Select result is 0
. 2006-05-19 21:54:07.828 Session upkeep
. 2006-05-19 21:54:07.828 Select result is 0
. 2006-05-19 21:54:08.328 Session upkeep
. 2006-05-19 21:54:08.328 Select result is 0
. 2006-05-19 21:54:08.828 Session upkeep
. 2006-05-19 21:54:08.828 Select result is 0
. 2006-05-19 21:54:09.328 Session upkeep
. 2006-05-19 21:54:09.328 Select result is 0
. 2006-05-19 21:54:09.828 Session upkeep
. 2006-05-19 21:54:09.828 Select result is 0
. 2006-05-19 21:54:10.328 Session upkeep
. 2006-05-19 21:54:10.328 Select result is 0
. 2006-05-19 21:54:10.828 Session upkeep
. 2006-05-19 21:54:10.828 Select result is 0
. 2006-05-19 21:54:11.328 Session upkeep
. 2006-05-19 21:54:11.328 Select result is 0
. 2006-05-19 21:54:11.828 Session upkeep
. 2006-05-19 21:54:11.828 Select result is 0
. 2006-05-19 21:54:12.328 Session upkeep
. 2006-05-19 21:54:12.328 Select result is 0
. 2006-05-19 21:54:12.828 Session upkeep
. 2006-05-19 21:54:12.828 Select result is 0
. 2006-05-19 21:54:13.328 Session upkeep
. 2006-05-19 21:54:13.328 Select result is 0
. 2006-05-19 21:54:13.828 Session upkeep
. 2006-05-19 21:54:13.828 Select result is 0
. 2006-05-19 21:54:14.328 Session upkeep
. 2006-05-19 21:54:14.328 Select result is 0
. 2006-05-19 21:54:14.828 Session upkeep
. 2006-05-19 21:54:14.828 Select result is 0
. 2006-05-19 21:54:15.328 Session upkeep
. 2006-05-19 21:54:15.328 Select result is 0
. 2006-05-19 21:54:15.828 Session upkeep
. 2006-05-19 21:54:15.828 Select result is 0
. 2006-05-19 21:54:16.328 Session upkeep
. 2006-05-19 21:54:16.328 Select result is 0
. 2006-05-19 21:54:16.828 Session upkeep
. 2006-05-19 21:54:16.828 Select result is 0
. 2006-05-19 21:54:17.328 Session upkeep
. 2006-05-19 21:54:17.328 Select result is 0
. 2006-05-19 21:54:17.828 Session upkeep
. 2006-05-19 21:54:17.828 Select result is 0
. 2006-05-19 21:54:18.328 Session upkeep
. 2006-05-19 21:54:18.328 Select result is 0
. 2006-05-19 21:54:18.828 Session upkeep
. 2006-05-19 21:54:18.828 Select result is 0
. 2006-05-19 21:54:19.328 Session upkeep
. 2006-05-19 21:54:19.328 Select result is 0
. 2006-05-19 21:54:19.828 Session upkeep
. 2006-05-19 21:54:19.828 Select result is 0
. 2006-05-19 21:54:20.328 Session upkeep
. 2006-05-19 21:54:20.328 Select result is 0
. 2006-05-19 21:54:20.828 Session upkeep
. 2006-05-19 21:54:20.828 Select result is 0
. 2006-05-19 21:54:21.328 Session upkeep
. 2006-05-19 21:54:21.328 Select result is 0
. 2006-05-19 21:54:21.828 Session upkeep
. 2006-05-19 21:54:21.828 Select result is 0
. 2006-05-19 21:54:22.328 Session upkeep
. 2006-05-19 21:54:22.328 Select result is 0
. 2006-05-19 21:54:22.828 Session upkeep
. 2006-05-19 21:54:22.828 Select result is 0
. 2006-05-19 21:54:23.328 Session upkeep
. 2006-05-19 21:54:23.328 Select result is 0
. 2006-05-19 21:54:23.828 Session upkeep
. 2006-05-19 21:54:23.828 Select result is 0
. 2006-05-19 21:54:24.328 Session upkeep
. 2006-05-19 21:54:24.328 Select result is 0
. 2006-05-19 21:54:24.828 Session upkeep
. 2006-05-19 21:54:24.828 Select result is 0
. 2006-05-19 21:54:25.328 Session upkeep
. 2006-05-19 21:54:25.328 Select result is 0
. 2006-05-19 21:54:25.828 Session upkeep
. 2006-05-19 21:54:25.828 Select result is 0
. 2006-05-19 21:54:26.328 Session upkeep
. 2006-05-19 21:54:26.328 Select result is 0
. 2006-05-19 21:54:26.828 Session upkeep
. 2006-05-19 21:54:26.828 Select result is 0
. 2006-05-19 21:54:27.328 Session upkeep
. 2006-05-19 21:54:27.328 Select result is 0
. 2006-05-19 21:54:27.828 Session upkeep
. 2006-05-19 21:54:27.828 Select result is 0
. 2006-05-19 21:54:28.328 Session upkeep
. 2006-05-19 21:54:28.328 Select result is 0
. 2006-05-19 21:54:28.828 Session upkeep
. 2006-05-19 21:54:28.828 Select result is 0
. 2006-05-19 21:54:29.328 Session upkeep
. 2006-05-19 21:54:29.328 Select result is 0
. 2006-05-19 21:54:29.828 Session upkeep
. 2006-05-19 21:54:29.828 Select result is 0
. 2006-05-19 21:54:30.328 Session upkeep
. 2006-05-19 21:54:30.328 Select result is 0
. 2006-05-19 21:54:30.828 Session upkeep
. 2006-05-19 21:54:30.828 Select result is 0
. 2006-05-19 21:54:31.328 Session upkeep
. 2006-05-19 21:54:31.328 Select result is 0
. 2006-05-19 21:54:31.828 Session upkeep
. 2006-05-19 21:54:31.828 Select result is 0
. 2006-05-19 21:54:32.328 Session upkeep
. 2006-05-19 21:54:32.328 Select result is 0
. 2006-05-19 21:54:32.828 Session upkeep
. 2006-05-19 21:54:32.828 Select result is 0
. 2006-05-19 21:54:33.328 Session upkeep
. 2006-05-19 21:54:33.328 Select result is 0
. 2006-05-19 21:54:33.828 Session upkeep
. 2006-05-19 21:54:33.828 Select result is 0
. 2006-05-19 21:54:34.328 Session upkeep
. 2006-05-19 21:54:34.328 Select result is 0
. 2006-05-19 21:54:34.828 Session upkeep
. 2006-05-19 21:54:34.828 Select result is 0
. 2006-05-19 21:54:35.328 Session upkeep
. 2006-05-19 21:54:35.328 Select result is 0
. 2006-05-19 21:54:35.828 Session upkeep
. 2006-05-19 21:54:35.828 Select result is 0
. 2006-05-19 21:54:36.328 Session upkeep
. 2006-05-19 21:54:36.328 Select result is 0
. 2006-05-19 21:54:36.828 Session upkeep
. 2006-05-19 21:54:36.828 Select result is 0
. 2006-05-19 21:54:37.328 Session upkeep
. 2006-05-19 21:54:37.328 Select result is 0
. 2006-05-19 21:54:37.828 Session upkeep
. 2006-05-19 21:54:37.828 Select result is 0
. 2006-05-19 21:54:38.328 Session upkeep
. 2006-05-19 21:54:38.328 Select result is 0
. 2006-05-19 21:54:38.828 Session upkeep
. 2006-05-19 21:54:38.828 Select result is 0
. 2006-05-19 21:54:39.328 Session upkeep
. 2006-05-19 21:54:39.328 Select result is 0
. 2006-05-19 21:54:39.828 Session upkeep
. 2006-05-19 21:54:39.828 Select result is 0
. 2006-05-19 21:54:40.328 Session upkeep
. 2006-05-19 21:54:40.328 Select result is 0
. 2006-05-19 21:54:40.828 Session upkeep
. 2006-05-19 21:54:40.828 Select result is 0
. 2006-05-19 21:54:41.328 Session upkeep
. 2006-05-19 21:54:41.328 Select result is 0
. 2006-05-19 21:54:41.484 Cached directory change via "/" to "/".
. 2006-05-19 21:54:41.484 Getting current directory name.
. 2006-05-19 21:54:41.484 Listing directory "/".
> 2006-05-19 21:54:41.484 Type: SSH_FXP_OPENDIR, Size: 10, Number: 1291
> 2006-05-19 21:54:41.484 0B,00,00,05,0B,00,00,00,01,2F,
. 2006-05-19 21:54:41.484 Sent 14 bytes
. 2006-05-19 21:54:41.484 There are 0 bytes remaining in the send buffer
. 2006-05-19 21:54:41.484 Received 4 bytes
. 2006-05-19 21:54:41.484 Received 24 bytes
< 2006-05-19 21:54:41.484 Type: SSH_FXP_STATUS, Size: 24, Number: 1028
< 2006-05-19 21:54:41.484 65,00,00,04,04,00,00,00,00,00,00,00,07,53,75,63,63,65,73,73,00,00,00,00,
. 2006-05-19 21:54:41.484 Discarding reserved response
. 2006-05-19 21:54:41.484 Waiting for another 4 bytes
. 2006-05-19 21:54:41.484 Looking for incoming data
. 2006-05-19 21:54:41.500 Select result is 1
. 2006-05-19 21:54:41.500 Received 4 bytes
. 2006-05-19 21:54:41.500 Received 13 bytes
< 2006-05-19 21:54:41.500 Type: SSH_FXP_HANDLE, Size: 13, Number: 1291
< 2006-05-19 21:54:41.500 66,00,00,05,0B,00,00,00,04,00,00,00,00,
> 2006-05-19 21:54:41.500 Type: SSH_FXP_READDIR, Size: 13, Number: 1548
> 2006-05-19 21:54:41.500 0C,00,00,06,0C,00,00,00,04,00,00,00,00,
. 2006-05-19 21:54:41.500 Sent 17 bytes
. 2006-05-19 21:54:41.500 There are 0 bytes remaining in the send buffer
. 2006-05-19 21:54:41.500 Waiting for another 4 bytes
. 2006-05-19 21:54:41.500 Looking for incoming data
. 2006-05-19 21:54:41.500 Received 3277 bytes
< 2006-05-19 21:54:41.500 Type: SSH_FXP_NAME, Size: 3277, Number: 1548
< 2006-05-19 21:54:41.515 68,00,00,06,0C,00,00,00,1F,00,00,00,01,2E,00,00,00,39,64,72,77,78,72,2D,78,
< 2006-05-19 21:54:41.515 72,2D,78,20,20,20,32,33,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,
< 2006-05-19 21:54:41.515 20,20,20,20,20,20,31,30,32,34,20,4D,61,79,20,31,39,20,31,39,3A,30,30,20,2E,
< 2006-05-19 21:54:41.515 00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,ED,44,
< 2006-05-19 21:54:41.515 6E,76,E4,44,6E,4D,F4,00,00,00,02,2E,2E,00,00,00,3A,64,72,77,78,72,2D,78,72,
< 2006-05-19 21:54:41.515 2D,78,20,20,20,32,33,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,
< 2006-05-19 21:54:41.515 20,20,20,20,20,31,30,32,34,20,4D,61,79,20,31,39,20,31,39,3A,30,30,20,2E,2E,
< 2006-05-19 21:54:41.515 6E,76,E4,44,6E,4D,F4,00,00,00,0A,6C,6F,73,74,2B,66,6F,75,6E,64,00,00,00,42,
< 2006-05-19 21:54:41.515 64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,
< 2006-05-19 21:54:41.515 72,6F,6F,74,20,20,20,20,20,20,20,20,31,32,32,38,38,20,4D,61,72,20,31,36,20,
< 2006-05-19 21:54:41.515 31,31,3A,35,38,20,6C,6F,73,74,2B,66,6F,75,6E,64,00,00,00,0F,00,00,00,00,00,
< 2006-05-19 21:54:41.515 00,30,00,00,00,00,00,00,00,00,00,00,00,41,ED,44,6D,9D,42,44,19,99,31,00,00,
< 2006-05-19 21:54:41.515 00,04,68,6F,6D,65,00,00,00,3C,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,35,
< 2006-05-19 21:54:41.515 20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,34,30,
< 2006-05-19 21:54:41.515 39,36,20,4D,61,72,20,31,39,20,30,33,3A,30,33,20,68,6F,6D,65,00,00,00,0F,00,
< 2006-05-19 21:54:41.515 00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,ED,44,6D,9C,FE,44,1D,
< 2006-05-19 21:54:41.515 10,69,00,00,00,03,74,6D,70,00,00,00,3B,64,72,77,78,72,77,78,72,77,74,20,20,
< 2006-05-19 21:54:41.515 20,31,30,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,
< 2006-05-19 21:54:41.515 20,33,30,37,32,20,4D,61,79,20,31,39,20,31,38,3A,35,30,20,74,6D,70,00,00,00,
< 2006-05-19 21:54:41.515 0F,00,00,00,00,00,00,0C,00,00,00,00,00,00,00,00,00,00,00,43,FF,44,6E,48,8D,
< 2006-05-19 21:54:41.515 44,6E,4B,C7,00,00,00,03,75,73,72,00,00,00,3B,64,72,77,78,72,2D,78,72,2D,78,
< 2006-05-19 21:54:41.515 20,20,20,31,34,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,
< 2006-05-19 21:54:41.515 20,20,20,34,30,39,36,20,4D,61,72,20,31,37,20,30,34,3A,30,39,20,75,73,72,00,
< 2006-05-19 21:54:41.515 00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,ED,44,6D,
< 2006-05-19 21:54:41.515 9D,07,44,1A,7C,D5,00,00,00,03,76,61,72,00,00,00,3B,64,72,77,78,72,2D,78,72,
< 2006-05-19 21:54:41.515 2D,78,20,20,20,31,38,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,
< 2006-05-19 21:54:41.515 20,20,20,20,20,34,30,39,36,20,4D,61,72,20,31,39,20,31,34,3A,34,33,20,76,61,
< 2006-05-19 21:54:41.515 72,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,ED,
< 2006-05-19 21:54:41.515 44,6E,75,41,44,1D,B4,69,00,00,00,03,65,74,63,00,00,00,3B,64,72,77,78,72,2D,
< 2006-05-19 21:54:41.515 78,72,2D,78,20,20,31,30,33,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,
< 2006-05-19 21:54:41.515 20,20,20,20,20,20,20,34,30,39,36,20,4D,61,79,20,20,38,20,31,36,3A,33,38,20,
< 2006-05-19 21:54:41.515 65,74,63,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,
< 2006-05-19 21:54:41.531 41,ED,44,6E,48,7D,44,5F,AC,4A,00,00,00,05,6D,65,64,69,61,00,00,00,3D,64,72,
< 2006-05-19 21:54:41.531 77,78,72,2D,78,72,2D,78,20,20,20,20,35,20,72,6F,6F,74,20,20,20,20,20,72,6F,
< 2006-05-19 21:54:41.531 6F,74,20,20,20,20,20,20,20,20,20,31,30,32,34,20,4D,61,79,20,20,38,20,31,36,
< 2006-05-19 21:54:41.531 3A,33,38,20,6D,65,64,69,61,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,
< 2006-05-19 21:54:41.531 00,00,00,00,00,00,41,ED,44,5F,AC,1A,44,5F,AC,4A,00,00,00,05,63,64,72,6F,6D,
< 2006-05-19 21:54:41.531 00,00,00,3D,6C,72,77,78,72,77,78,72,77,78,20,20,20,20,31,20,72,6F,6F,74,20,
< 2006-05-19 21:54:41.531 20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,20,31,31,20,4D,61,72,
< 2006-05-19 21:54:41.531 20,31,36,20,31,31,3A,35,39,20,63,64,72,6F,6D,00,00,00,0F,00,00,00,00,00,00,
< 2006-05-19 21:54:41.531 00,0B,00,00,00,00,00,00,00,00,00,00,A1,FF,44,6E,75,3E,44,19,99,8D,00,00,00,
< 2006-05-19 21:54:41.531 0A,69,6E,69,74,72,64,2E,69,6D,67,00,00,00,42,6C,72,77,78,72,77,78,72,77,78,
< 2006-05-19 21:54:41.531 20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,
< 2006-05-19 21:54:41.531 20,20,20,20,20,32,38,20,4D,61,72,20,31,36,20,31,32,3A,30,35,20,69,6E,69,74,
< 2006-05-19 21:54:41.531 72,64,2E,69,6D,67,00,00,00,0F,00,00,00,00,00,00,00,1C,00,00,00,00,00,00,00,
< 2006-05-19 21:54:41.531 00,00,00,A1,FF,44,6E,75,3E,44,19,9A,E3,00,00,00,03,62,69,6E,00,00,00,3B,64,
< 2006-05-19 21:54:41.531 72,77,78,72,2D,78,72,2D,78,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,
< 2006-05-19 21:54:41.531 6F,6F,74,20,20,20,20,20,20,20,20,20,32,30,34,38,20,4D,61,72,20,32,31,20,31,
< 2006-05-19 21:54:41.531 39,3A,33,33,20,62,69,6E,00,00,00,0F,00,00,00,00,00,00,08,00,00,00,00,00,00,
< 2006-05-19 21:54:41.531 00,00,00,00,00,41,ED,44,6D,9D,2B,44,20,9B,54,00,00,00,04,62,6F,6F,74,00,00,
< 2006-05-19 21:54:41.531 00,3C,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,33,20,72,6F,6F,74,20,20,20,
< 2006-05-19 21:54:41.531 20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,31,30,32,34,20,4D,61,72,20,31,
< 2006-05-19 21:54:41.531 36,20,31,32,3A,34,39,20,62,6F,6F,74,00,00,00,0F,00,00,00,00,00,00,04,00,00,
< 2006-05-19 21:54:41.531 00,00,00,00,00,00,00,00,00,41,ED,44,6D,9D,2B,44,19,A5,2A,00,00,00,03,64,65,
< 2006-05-19 21:54:41.531 76,00,00,00,3B,64,72,77,78,72,2D,78,72,2D,78,20,20,20,31,34,20,72,6F,6F,74,
< 2006-05-19 21:54:41.531 20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,31,33,33,30,30,20,4D,61,
< 2006-05-19 21:54:41.531 79,20,31,34,20,30,36,3A,34,37,20,64,65,76,00,00,00,0F,00,00,00,00,00,00,33,
< 2006-05-19 21:54:41.531 F4,00,00,00,00,00,00,00,00,00,00,41,ED,44,5B,89,80,44,67,0A,A6,00,00,00,03,
< 2006-05-19 21:54:41.531 6C,69,62,00,00,00,3B,64,72,77,78,72,2D,78,72,2D,78,20,20,20,31,33,20,72,6F,
< 2006-05-19 21:54:41.531 6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,34,30,39,36,20,
< 2006-05-19 21:54:41.531 4D,61,72,20,32,31,20,31,39,3A,33,33,20,6C,69,62,00,00,00,0F,00,00,00,00,00,
< 2006-05-19 21:54:41.531 00,10,00,00,00,00,00,00,00,00,00,00,00,41,ED,44,6D,9D,2B,44,20,9B,5E,00,00,
< 2006-05-19 21:54:41.531 00,03,6D,6E,74,00,00,00,3B,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,32,20,
< 2006-05-19 21:54:41.531 72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,31,30,32,
< 2006-05-19 21:54:41.531 34,20,46,65,62,20,20,39,20,31,33,3A,32,30,20,6D,6E,74,00,00,00,0F,00,00,00,
< 2006-05-19 21:54:41.531 00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,ED,44,6D,9D,2D,43,EB,87,E5,
< 2006-05-19 21:54:41.531 00,00,00,04,70,72,6F,63,00,00,00,3C,64,72,2D,78,72,2D,78,72,2D,78,20,20,31,
< 2006-05-19 21:54:41.531 34,39,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,
< 2006-05-19 21:54:41.531 20,20,20,30,20,4D,61,79,20,20,32,20,31,34,3A,35,31,20,70,72,6F,63,00,00,00,
< 2006-05-19 21:54:41.531 0F,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,41,6D,44,57,AA,1E,
< 2006-05-19 21:54:41.531 44,57,AA,1E,00,00,00,04,72,6F,6F,74,00,00,00,3C,64,72,77,78,72,2D,78,72,2D,
< 2006-05-19 21:54:41.531 78,20,20,20,33,33,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,
< 2006-05-19 21:54:41.531 20,20,20,20,32,30,34,38,20,4D,61,79,20,20,32,20,31,35,3A,32,32,20,72,6F,6F,
< 2006-05-19 21:54:41.531 74,00,00,00,0F,00,00,00,00,00,00,08,00,00,00,00,00,00,00,00,00,00,00,41,ED,
< 2006-05-19 21:54:41.531 44,6E,76,B6,44,57,B1,5D,00,00,00,04,73,62,69,6E,00,00,00,3C,64,72,77,78,72,
< 2006-05-19 21:54:41.531 2D,78,72,2D,78,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,
< 2006-05-19 21:54:41.531 20,20,20,20,20,20,20,20,33,30,37,32,20,4D,61,72,20,32,31,20,31,39,3A,33,33,
< 2006-05-19 21:54:41.531 20,73,62,69,6E,00,00,00,0F,00,00,00,00,00,00,0C,00,00,00,00,00,00,00,00,00,
< 2006-05-19 21:54:41.531 00,00,41,ED,44,6D,9D,2E,44,20,9B,71,00,00,00,03,73,79,73,00,00,00,3B,64,72,
< 2006-05-19 21:54:41.531 77,78,72,2D,78,72,2D,78,20,20,20,31,30,20,72,6F,6F,74,20,20,20,20,20,72,6F,
< 2006-05-19 21:54:41.531 6F,74,20,20,20,20,20,20,20,20,20,20,20,20,30,20,4D,61,79,20,20,32,20,31,34,
< 2006-05-19 21:54:41.531 3A,35,31,20,73,79,73,00,00,00,0F,00,00,00,00,00,00,00,00,00,00,00,00,00,00,
< 2006-05-19 21:54:41.531 00,00,00,00,41,ED,44,5B,89,80,44,57,AA,1F,00,00,00,03,73,72,76,00,00,00,3B,
< 2006-05-19 21:54:41.531 64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,
< 2006-05-19 21:54:41.531 72,6F,6F,74,20,20,20,20,20,20,20,20,20,31,30,32,34,20,4D,61,72,20,31,36,20,
< 2006-05-19 21:54:41.531 31,32,3A,30,32,20,73,72,76,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,
< 2006-05-19 21:54:41.531 00,00,00,00,00,00,41,ED,44,6D,9D,2E,44,19,9A,16,00,00,00,03,6F,70,74,00,00,
< 2006-05-19 21:54:41.531 00,3B,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,32,20,72,6F,6F,74,20,20,20,
< 2006-05-19 21:54:41.531 36,20,31,32,3A,30,32,20,6F,70,74,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,
< 2006-05-19 21:54:41.531 00,00,00,00,00,00,00,00,41,ED,44,6D,9D,2E,44,19,9A,16,00,00,00,06,69,6E,69,
< 2006-05-19 21:54:41.531 74,72,64,00,00,00,3E,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,32,20,72,6F,
< 2006-05-19 21:54:41.531 6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,31,30,32,34,20,
< 2006-05-19 21:54:41.531 4D,61,72,20,31,36,20,31,32,3A,30,32,20,69,6E,69,74,72,64,00,00,00,0F,00,00,
< 2006-05-19 21:54:41.531 00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,ED,44,6D,9D,2E,44,19,9A,
< 2006-05-19 21:54:41.531 16,00,00,00,07,76,6D,6C,69,6E,75,7A,00,00,00,3F,6C,72,77,78,72,77,78,72,77,
< 2006-05-19 21:54:41.531 78,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,
< 2006-05-19 21:54:41.531 20,20,20,20,20,20,32,35,20,4D,61,72,20,31,36,20,31,32,3A,30,35,20,76,6D,6C,
< 2006-05-19 21:54:41.531 69,6E,75,7A,00,00,00,0F,00,00,00,00,00,00,00,19,00,00,00,00,00,00,00,00,00,
< 2006-05-19 21:54:41.531 00,A1,FF,44,6E,75,3E,44,19,9A,E3,00,00,00,0E,2E,66,6F,6E,74,73,2E,63,61,63,
< 2006-05-19 21:54:41.531 68,65,2D,31,00,00,00,46,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,
< 2006-05-19 21:54:41.531 6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,20,20,30,
< 2006-05-19 21:54:41.531 20,4D,61,72,20,31,36,20,31,32,3A,34,35,20,2E,66,6F,6E,74,73,2E,63,61,63,68,
< 2006-05-19 21:54:41.531 65,2D,31,00,00,00,0F,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,
< 2006-05-19 21:54:41.531 81,A4,44,6E,48,78,44,19,A4,3A,00,00,00,05,6C,69,62,36,34,00,00,00,3D,64,72,
< 2006-05-19 21:54:41.531 77,78,72,2D,78,72,2D,78,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,
The log does not show any file transfer. It is possible that it was truncated because of size. Can you send it to my by email?
i copied the entire log and even matched it up- that's where it stops. it's the strangest thing; either it doesn't even log it initializing or it says it's at 1-% or such without even starting it yet..
Can I have a test account on your server?
I get the same problem. Usually I just re-drag the files and it starts over. But, it happens over and over; just stops transferring anything, without any messages. I believe its only an uploading problem.
Of several computers, I only have this problem with uploading from one; it has an nVidea IO chipset on it. The motherboard is the Abit Fatal1ty.
Where do you drag the files from? Does it happen when dragging only? Or even if you initiate the transfer otherwise?
