Topic "WinSCP connects then gone"
I have the newest version, 3.76 did the same. I can connect to my site but when connected the login screen goes away and the application is gone. it is running in the task manager but no screen shows. Anyone else having this problem. I uninstalled and re-installed and same problem. Anyone have a suggestion. thanks.
Do you use 3.8.1? Can you remove your configuration and try again?
Can you explain how to "remove my configuration"? Thanks.
The easiest way to run WinSCP with default configuration is to provide it path to non-existing INI file. Like:
winscp3.exe /ini=nonexisting.ini
