Topic "HELP: Where can i change font size"
in winscp are the letters too small (Norton style), where can i change font size.
I checked preferences, faq and forum but i dont found any options and/or tips.
i even checked registry (searched for font) without results.
thx for your awnsers
bye
johnarcher
It is not possible. Can you send me a screenshot? What is your resolution?
did you received my E-mail with the screenshots?
cu
johnarcher
Give me a EMail adress and I'll send you a JPG.
I did, I'm trying to find some solution.
bye
johnarcher
I played around in the Windows settings and found that a way to change font sizes. Go to Start, Settings, Control Panel, Display, Appearance tab, Item pulldown, ToolTip. Changing the ToolTip font made my WinSCP display come up the way I like it(Can't stand Times New Roman font). Wink
Anonymous Donor
Anonymous Donor
Hi Anonymous Donor,
that is a nice idea. But, when i tested it, there were
no changes in scp. Sad
Maybe different Windows? I've got Win98!
For all that thanks.
__________
johnarcher
bye
johnarcher
Anonymous Donor
Above solution worked for me Laughing , I use Chinese Windows XP, and default ToolTip font is SongTi, very bad look used in WinSCP.
