Topic "Unable to open script.txt"
Hi, im using WinSCP3 in command mode. For an automated updaterun i create a script file. The loging onto the server works fine, but then the error message occurs: can't open xyz.txt (While xyz.txt is my script file)
C:\Programme\WinSCP3\WinSCP3.exe user@host.de /console /script=xyz.txt
xyz.txt is in C:\Programme\WinSCP3\
If you do not provide full path, then the path (or file name) it relative to current working directory. And it may not be the directory, where WinSCP is installed. Try to provide full part.
HI Martin,
unfortunatly that does not work. i've tried to vary the entry:
/script=c:\programme\winscp3\example.txt
answer unkown command "xxx(x=strange special charakters)"
or
/script="c:\programme\winscp3\example.txt"
or
/script=programme\winscp3\example.txt
answer cannot open programme\winscp3\example.txt
saved the txt-file in the session stored working directory
/script=example.txt
answer cannot open example.txt
Do you have any other ideas?
udo
QSS
If you saved the file as "example.txt" then windows will add another .txt to that file name. Therefore the file name is actually example.txt.txt
In DOS mode do a DIR on the directory where your script is to see its "true" name.
I would suspect that you have saved the script file in Unicode encoding. Haven't you?
Hm interesting, i know about this doubeling but this maschine has still win nt 4 as os
and this is an effect under win xp...
Yes i've saved the script.txt as unicode - but do so or not makes no effect
udo
Can you email me the script?
1) The file had leading byte-order-mask of UTF-16 Unicode encoding. WinSCP does not support Unicode encodings.
2) Even if it does, the file had not correctly encoded line endings. It looked like if you have saved the file in UTF-16 and then opened it in another editor does does not support UTF-16 and saved it again. Or smething similar.
