Topic "WinSCP 3.81 + Cisco equipment"
glc650
Anyone ever use WinSCP with Cisco hardware? I can't get WinSCP 3.81 to work with my Cisco 871 router. WinSCP authenticates and displays the router's login banner, but that's as far as I get. WinSCP cannot start a session. NOTE: I can connect to the router (from the same PC that WinSCP is installed on) just fine via Putty and SSH.
TIA>
-g.
Please post a log file.
glc650
Where's the log file kept? I'm using the standalone version.
-g.
You need to turn on logging. Please check documentation.
glc650
Ok, here's the log...
. 2006-06-08 13:29:16.796 --------------------------------------------------------------------------
. 2006-06-08 13:29:16.796 WinSCP Version 3.8.1 (Build 328) (OS 5.0.2195 Service Pack 4)
. 2006-06-08 13:29:16.796 Login time: Thursday, June 08, 2006 1:29:16 PM
. 2006-06-08 13:29:16.796 Session name: admin@10.0.0.254
. 2006-06-08 13:29:16.796 Host name: 10.0.0.254 (Port: 22)
. 2006-06-08 13:29:16.796 User name: admin (Password: Yes, Key file: No)
. 2006-06-08 13:29:16.796 Transfer Protocol: SCP
. 2006-06-08 13:29:16.796 SSH protocol version: 2; Compression: No
. 2006-06-08 13:29:16.796 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2006-06-08 13:29:16.796 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2006-06-08 13:29:16.796 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2006-06-08 13:29:16.796 SSH Bugs: -,-,-,-,-,-,-,-
. 2006-06-08 13:29:16.796 SFTP Bugs: -,-,-
. 2006-06-08 13:29:16.796 Proxy: none
. 2006-06-08 13:29:16.796 Return code variable: Autodetect; Lookup user groups: Yes
. 2006-06-08 13:29:16.796 Shell: default, EOL: 0
. 2006-06-08 13:29:16.796 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2006-06-08 13:29:16.796 Cache directory changes: Yes, Permanent: Yes
. 2006-06-08 13:29:16.796 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2006-06-08 13:29:16.796 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2006-06-08 13:29:16.796 Looking up host "10.0.0.254"
. 2006-06-08 13:29:16.796 Connecting to 10.0.0.254 port 22
. 2006-06-08 13:29:16.812 Waiting for the server to continue with the initialisation
. 2006-06-08 13:29:16.812 Looking for incoming data
. 2006-06-08 13:29:16.812 Select result is 1
. 2006-06-08 13:29:16.812 Server version: SSH-2.0-Cisco-1.25
. 2006-06-08 13:29:16.812 We believe remote version has SSH-1 ignore bug
. 2006-06-08 13:29:16.812 We believe remote version needs a plain SSH-1 password
. 2006-06-08 13:29:16.812 We believe remote version can't handle SSH-1 RSA authentication
. 2006-06-08 13:29:16.812 We claim version: SSH-2.0-WinSCP_release_3.8.1
. 2006-06-08 13:29:16.812 Using SSH protocol version 2
. 2006-06-08 13:29:16.812 Using Diffie-Hellman with standard group "group1"
. 2006-06-08 13:29:16.812 Doing Diffie-Hellman key exchange
. 2006-06-08 13:29:16.859 Waiting for the server to continue with the initialisation
. 2006-06-08 13:29:16.859 Looking for incoming data
. 2006-06-08 13:29:17.843 Select result is 1
. 2006-06-08 13:29:17.843 Waiting for the server to continue with the initialisation
. 2006-06-08 13:29:17.843 Looking for incoming data
. 2006-06-08 13:29:17.890 Asking user:
. 2006-06-08 13:29:17.890 The server's host key was not found in the cache. You have no guarantee that the server is the computer you think it is.
. 2006-06-08 13:29:17.890 The server's rsa2 key fingerprint is:
. 2006-06-08 13:29:17.890 ssh-rsa 2048 85:3f:e9:c8:66:05:2d:c7:37:97:dd:ea:50:9c:8f:cd
. 2006-06-08 13:29:17.890 If you trust this host, press Yes. To connect without adding host key to the cache, press No. To abandon the connection press Cancel.
. 2006-06-08 13:29:17.890 Continue connecting and add host key to the cache? ()
. 2006-06-08 13:29:19.453 Host key fingerprint is:
. 2006-06-08 13:29:19.453 ssh-rsa 2048 85:3f:e9:c8:66:05:2d:c7:37:97:dd:ea:50:9c:8f:cd
. 2006-06-08 13:29:19.453 Initialised AES-256 client->server encryption
. 2006-06-08 13:29:19.453 Initialised HMAC-SHA1 client->server MAC algorithm
. 2006-06-08 13:29:19.453 Waiting for the server to continue with the initialisation
. 2006-06-08 13:29:19.453 Looking for incoming data
. 2006-06-08 13:29:19.453 Select result is 1
. 2006-06-08 13:29:19.453 Initialised AES-256 server->client encryption
. 2006-06-08 13:29:19.453 Initialised HMAC-SHA1 server->client MAC algorithm
. 2006-06-08 13:29:19.656 Select result is 1
! 2006-06-08 13:29:19.656 Using username "admin".
. 2006-06-08 13:29:19.656 Waiting for the server to continue with the initialisation
. 2006-06-08 13:29:19.656 Looking for incoming data
! 2006-06-08 13:29:19.656 CC
! 2006-06-08 13:29:19.656 -----------------------------------------------------------------------
! 2006-06-08 13:29:19.656 Authorized access only!
! 2006-06-08 13:29:19.656 This system is the property of GLC.
! 2006-06-08 13:29:19.656 Disconnect IMMEDIATELY if you are not an authorized user!
. 2006-06-08 13:29:21.562 Waiting for the server to continue with the initialisation
. 2006-06-08 13:29:21.562 Looking for incoming data
. 2006-06-08 13:29:21.562 Select result is 1
. 2006-06-08 13:29:21.562 Session password prompt (admin@10.0.0.254's password: )
. 2006-06-08 13:29:21.562 Using stored password.
! 2006-06-08 13:29:21.562 Authenticating with pre-entered password.
. 2006-06-08 13:29:21.562 Sent password
. 2006-06-08 13:29:21.578 Select result is 1
. 2006-06-08 13:29:21.578 Access granted
. 2006-06-08 13:29:21.578 Waiting for the server to continue with the initialisation
. 2006-06-08 13:29:21.578 Looking for incoming data
. 2006-06-08 13:29:21.578 Opened channel for session
. 2006-06-08 13:29:21.578 Started a shell/command
. 2006-06-08 13:29:21.578 --------------------------------------------------------------------------
. 2006-06-08 13:29:21.578 Using SCP protocol.
. 2006-06-08 13:29:21.578 Doing startup conversation with host.
. 2006-06-08 13:29:21.578 Skipping host startup message (if any).
. 2006-06-08 13:29:21.578 Sent 36 bytes
. 2006-06-08 13:29:21.578 There are 0 bytes remaining in the send buffer
. 2006-06-08 13:29:21.578 Sent 1 bytes
> 2006-06-08 13:29:21.578 echo "WinSCP: this is end-of-file:0"
. 2006-06-08 13:29:21.578 Waiting for another 1 bytes
. 2006-06-08 13:29:21.578 Received 1 bytes
< 2006-06-08 13:29:21.578
. 2006-06-08 13:29:21.578 Received 7 bytes
. 2006-06-08 13:29:21.593 Received 1 bytes
. 2006-06-08 13:29:21.593 Waiting for another 1 bytes
. 2006-06-08 13:29:21.593 Looking for incoming data
. 2006-06-08 13:29:21.593 Select result is 1
. 2006-06-08 13:29:21.609 Select result is 1
. 2006-06-08 13:29:21.609 Received 1 bytes
. 2006-06-08 13:29:21.609 Waiting for another 1 bytes
. 2006-06-08 13:29:21.609 Looking for incoming data
. 2006-06-08 13:29:21.625 Received 1 bytes
. 2006-06-08 13:29:21.625 Waiting for another 1 bytes
. 2006-06-08 13:29:21.625 Looking for incoming data
. 2006-06-08 13:29:21.625 Select result is 1
< 2006-06-08 13:29:21.625 router>echo "WinSCP: this is end-of-file:0"
. 2006-06-08 13:29:21.625 Received 10 bytes
< 2006-06-08 13:29:21.625         ^
. 2006-06-08 13:29:21.625 Received 41 bytes
< 2006-06-08 13:29:21.625 % Invalid input detected at '^' marker.
. 2006-06-08 13:29:21.625 Received 2 bytes
. 2006-06-08 13:29:21.625 Received 7 bytes
. 2006-06-08 13:29:36.625 Select result is 0
. 2006-06-08 13:29:36.625 Waiting for data timed out, asking user what to do.
. 2006-06-08 13:29:36.625 Asking user:
. 2006-06-08 13:29:36.625 Host has not answered for 15 seconds.
. 2006-06-08 13:29:36.625 Wait for another 15 seconds? Pressing 'Abort' button will close session. ()
. 2006-06-08 13:29:37.125 Pooling for data in case they finally arrives
. 2006-06-08 13:29:37.125 Select result is 0
. 2006-06-08 13:29:37.625 Pooling for data in case they finally arrives
. 2006-06-08 13:29:37.625 Select result is 0
. 2006-06-08 13:29:38.125 Pooling for data in case they finally arrives
. 2006-06-08 13:29:38.125 Select result is 0
. 2006-06-08 13:29:38.625 Pooling for data in case they finally arrives
. 2006-06-08 13:29:38.625 Select result is 0
. 2006-06-08 13:29:39.125 Pooling for data in case they finally arrives
. 2006-06-08 13:29:39.125 Select result is 0
. 2006-06-08 13:29:39.625 Pooling for data in case they finally arrives
. 2006-06-08 13:29:39.625 Select result is 0
. 2006-06-08 13:29:40.125 Pooling for data in case they finally arrives
. 2006-06-08 13:29:40.125 Select result is 0
. 2006-06-08 13:29:40.625 Pooling for data in case they finally arrives
. 2006-06-08 13:29:40.625 Select result is 0
. 2006-06-08 13:29:41.125 Pooling for data in case they finally arrives
. 2006-06-08 13:29:41.125 Select result is 0
. 2006-06-08 13:29:41.625 Pooling for data in case they finally arrives
. 2006-06-08 13:29:41.625 Select result is 0
. 2006-06-08 13:29:42.125 Pooling for data in case they finally arrives
. 2006-06-08 13:29:42.125 Select result is 0
. 2006-06-08 13:29:42.625 Pooling for data in case they finally arrives
. 2006-06-08 13:29:42.625 Select result is 0
. 2006-06-08 13:29:43.125 Pooling for data in case they finally arrives
. 2006-06-08 13:29:43.125 Select result is 0
. 2006-06-08 13:29:43.625 Pooling for data in case they finally arrives
. 2006-06-08 13:29:43.625 Select result is 0
. 2006-06-08 13:29:44.125 Pooling for data in case they finally arrives
. 2006-06-08 13:29:44.125 Select result is 0
. 2006-06-08 13:29:44.625 Pooling for data in case they finally arrives
. 2006-06-08 13:29:44.625 Select result is 0
. 2006-06-08 13:29:44.703 Looking for incoming data
. 2006-06-08 13:29:59.703 Select result is 0
. 2006-06-08 13:29:59.703 Waiting for data timed out, asking user what to do.
. 2006-06-08 13:29:59.703 Asking user:
. 2006-06-08 13:29:59.703 Host has not answered for 15 seconds.
. 2006-06-08 13:29:59.703 Wait for another 15 seconds? Pressing 'Abort' button will close session. ()
. 2006-06-08 13:30:00.203 Pooling for data in case they finally arrives
. 2006-06-08 13:30:00.203 Select result is 0
. 2006-06-08 13:30:00.703 Pooling for data in case they finally arrives
. 2006-06-08 13:30:00.703 Select result is 0
. 2006-06-08 13:30:01.203 Pooling for data in case they finally arrives
. 2006-06-08 13:30:01.203 Select result is 0
. 2006-06-08 13:30:01.578 Attempt to close connection due to fatal exception:
* 2006-06-08 13:30:01.578 Terminated by user.
. 2006-06-08 13:30:01.578 Closing connection.
* 2006-06-08 13:30:01.578 (ESshFatal) Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
I'm not sure if your router is able to handle SCP protocol, the way WinSCP does. Can you try SFTP instead?
SFTP is not supported by my router.
Then I doubt I can help you. Sorry Sad
anonym
winscp will not work with Cisco switches and routers... It relies on BASH, or any type of Shell file to pull the files...
Does Cisco support SFTP?
Currently no at most platforms. Exception is IOS XR which is unavalable for most platforms.
