Topic "RFE: change timestamp on remote server"
jfeldt
Hi -
is it possible to add the feature to change the timestamp for:
- create date
- modified date
- last access date
on remote and local unit ?
Would be a great feature.
By now I need several tools for this.
Kind regards
Joerg
For remote side, you can create a custom command for this. And then you can synchronize timestamps of local files, if that's what you need.
jfeldt
Hi -
thanks for answering that fast - was out moment. Embarassed
Can you give me probably some hints how this script needs to look like in order to also have this recursivley? (But only if this is a "zero time" for you)
Thanks in advance and kind regards
Joerg
You cannot do this with script.
