Topic "Downloads ok, upload fails at 4096, smaller files upload ok"
I'm going nuts... please, please help.
WinScp 3.81 on Windows XP. Connecting to a Linux client.
1. Downloads of files from the Linux machine regardless of file size complete.
2. Uploads of files to Linux LESS THAN 4096 bytes in size complete
3. Uploads of files to Linux GREATER THAN 4096 bytes in size FAIL and disconnect the session.
Then I log back in, I am able to resume, and transfer another 4096 to make the file on the Linux server 8092. Then 4096 more, disconnect, reconnect, 4096 more, etc.
Here is the log. First I copied from Linux to Windows a few files smaller than 4096, then one that was about 800k. Those all went fine.
I then uploaded from Windows to Linux a few files smaller than 4096 bytes which sent ok, but as soon as I sent one bigger than 4096, it failed.
. 2006-06-15 12:53:41.817 --------------------------------------------------------------------------
. 2006-06-15 12:53:41.817 WinSCP Version 3.8.1 (Build 328) (OS 5.1.2600 Service Pack 2)
. 2006-06-15 12:53:41.817 Login time: Thursday, June 15, 2006 12:53:41 PM
. 2006-06-15 12:53:41.817 Session name: Ghost
. 2006-06-15 12:53:41.817 Host name: 10.0.20.7 (Port: 22)
. 2006-06-15 12:53:41.817 User name: root (Password: Yes, Key file: No)
. 2006-06-15 12:53:41.817 Transfer Protocol: SFTP (SCP)
. 2006-06-15 12:53:41.817 SSH protocol version: 2; Compression: No
. 2006-06-15 12:53:41.817 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2006-06-15 12:53:41.817 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2006-06-15 12:53:41.817 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2006-06-15 12:53:41.817 SSH Bugs: -,-,-,-,-,-,-,-
. 2006-06-15 12:53:41.817 SFTP Bugs: -,-,-
. 2006-06-15 12:53:41.817 Proxy: none
. 2006-06-15 12:53:41.817 Return code variable: Autodetect; Lookup user groups: Yes
. 2006-06-15 12:53:41.817 Shell: default, EOL: 0
. 2006-06-15 12:53:41.817 Local directory: C:\Documents and Settings\DBullard\Desktop, Remote directory: /infrastructure/archive, Update: Yes, Cache: Yes
. 2006-06-15 12:53:41.817 Cache directory changes: Yes, Permanent: Yes
. 2006-06-15 12:53:41.817 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2006-06-15 12:53:41.817 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2006-06-15 12:53:41.817 Looking up host "10.0.20.7"
. 2006-06-15 12:53:41.817 Connecting to 10.0.20.7 port 22
. 2006-06-15 12:53:42.022 Server version: SSH-1.99-OpenSSH_3.9p1
. 2006-06-15 12:53:42.022 We claim version: SSH-2.0-WinSCP_release_3.8.1
. 2006-06-15 12:53:42.022 Using SSH protocol version 2
. 2006-06-15 12:53:42.070 Doing Diffie-Hellman group exchange
. 2006-06-15 12:53:42.228 Doing Diffie-Hellman key exchange
. 2006-06-15 12:53:42.765 Host key fingerprint is:
. 2006-06-15 12:53:42.765 ssh-rsa 1024 6d:9e:b9:39:01:4d:3f:f0:ad:ec:1d:17:f4:13:30:3a
. 2006-06-15 12:53:42.765 Initialised AES-256 client->server encryption
. 2006-06-15 12:53:42.765 Initialised HMAC-SHA1 client->server MAC algorithm
. 2006-06-15 12:53:42.765 Initialised AES-256 server->client encryption
. 2006-06-15 12:53:42.765 Initialised HMAC-SHA1 server->client MAC algorithm
! 2006-06-15 12:53:42.908 Using username "root".
. 2006-06-15 12:53:42.955 Session password prompt (root@10.0.20.7's password: )
. 2006-06-15 12:53:42.955 Using stored password.
! 2006-06-15 12:53:42.955 Authenticating with pre-entered password.
. 2006-06-15 12:53:42.971 Sent password
. 2006-06-15 12:53:43.034 Access granted
. 2006-06-15 12:53:43.082 Opened channel for session
. 2006-06-15 12:53:43.145 Started a shell/command
. 2006-06-15 12:53:43.145 --------------------------------------------------------------------------
. 2006-06-15 12:53:43.145 Using SFTP protocol.
. 2006-06-15 12:53:43.145 Doing startup conversation with host.
> 2006-06-15 12:53:43.145 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2006-06-15 12:53:43.192 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2006-06-15 12:53:43.192 SFTP version 3 negotiated.
. 2006-06-15 12:53:43.192 We believe the server has signed timestamps bug
. 2006-06-15 12:53:43.192 We will use UTF-8 strings for status messages only
. 2006-06-15 12:53:43.192 Limiting packet size to OpenSSH limit of 262148 bytes
. 2006-06-15 12:53:43.208 Changing directory to "/infrastructure/archive".
. 2006-06-15 12:53:43.208 Getting real path for '/infrastructure/archive'
> 2006-06-15 12:53:43.208 Type: SSH_FXP_REALPATH, Size: 32, Number: 16
< 2006-06-15 12:53:43.255 Type: SSH_FXP_NAME, Size: 67, Number: 16
. 2006-06-15 12:53:43.255 Real path is '/infrastructure/archive'
. 2006-06-15 12:53:43.255 Trying to open directory "/infrastructure/archive".
> 2006-06-15 12:53:43.255 Type: SSH_FXP_LSTAT, Size: 32, Number: 263
< 2006-06-15 12:53:43.287 Type: SSH_FXP_ATTRS, Size: 37, Number: 263
. 2006-06-15 12:53:43.287 Getting current directory name.
. 2006-06-15 12:53:43.287 Listing directory "/infrastructure/archive".
> 2006-06-15 12:53:43.287 Type: SSH_FXP_OPENDIR, Size: 32, Number: 523
< 2006-06-15 12:53:43.334 Type: SSH_FXP_HANDLE, Size: 13, Number: 523
> 2006-06-15 12:53:43.334 Type: SSH_FXP_READDIR, Size: 13, Number: 780
< 2006-06-15 12:53:43.556 Type: SSH_FXP_NAME, Size: 3372, Number: 780
> 2006-06-15 12:53:43.556 Type: SSH_FXP_READDIR, Size: 13, Number: 1036
. 2006-06-15 12:53:43.556 Reading symlink ".#rc.mysqld".
> 2006-06-15 12:53:43.556 Type: SSH_FXP_READLINK, Size: 44, Number: 1299
> 2006-06-15 12:53:43.556 Type: SSH_FXP_STAT, Size: 44, Number: 1553
< 2006-06-15 12:53:43.603 Type: SSH_FXP_STATUS, Size: 28, Number: 1036
. 2006-06-15 12:53:43.603 Storing reserved response
< 2006-06-15 12:53:43.651 Type: SSH_FXP_NAME, Size: 105, Number: 1299
< 2006-06-15 12:53:43.809 Type: SSH_FXP_STATUS, Size: 29, Number: 1553
< 2006-06-15 12:53:43.809 Status/error code: 2, Message: 1553, Server: No such file, Language:
* 2006-06-15 12:53:43.809 (ECommand) Error reading symlink '.#rc.mysqld'.
* 2006-06-15 12:53:43.809 No such file or directory.
* 2006-06-15 12:53:43.809 Error code: 2
* 2006-06-15 12:53:43.809 Error message from server: No such file
* 2006-06-15 12:53:43.809 Request code: 17
< 2006-06-15 12:53:43.809 Status/error code: 1
> 2006-06-15 12:53:43.809 Type: SSH_FXP_CLOSE, Size: 13, Number: 1796
. 2006-06-15 12:53:43.809 Startup conversation with host finished.
. 2006-06-15 12:53:45.153 Detected incoming data while idle
* 2006-06-15 12:54:06.577 (EAbort) Operation aborted
. 2006-06-15 12:54:15.383 File: "/infrastructure/archive/rc.tomcat"
. 2006-06-15 12:54:15.399 Copying "/infrastructure/archive/rc.tomcat" to local directory started.
. 2006-06-15 12:54:15.399 Binary transfer mode selected.
. 2006-06-15 12:54:15.399 Opening remote file.
> 2006-06-15 12:54:15.399 Type: SSH_FXP_OPEN, Size: 50, Number: 2051
< 2006-06-15 12:54:15.399 Type: SSH_FXP_STATUS, Size: 24, Number: 1796
. 2006-06-15 12:54:15.399 Discarding reserved response
< 2006-06-15 12:54:15.446 Type: SSH_FXP_HANDLE, Size: 13, Number: 2051
> 2006-06-15 12:54:15.446 Type: SSH_FXP_FSTAT, Size: 13, Number: 2312
> 2006-06-15 12:54:15.446 Type: SSH_FXP_READ, Size: 25, Number: 2565
< 2006-06-15 12:54:15.494 Type: SSH_FXP_ATTRS, Size: 37, Number: 2312
. 2006-06-15 12:54:15.494 Storing reserved response
< 2006-06-15 12:54:15.620 Status/error code: 1
. 2006-06-15 12:54:15.620 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2006-06-15 12:54:15.620 Type: SSH_FXP_CLOSE, Size: 13, Number: 3076
. 2006-06-15 12:54:16.142 Detected incoming data while idle
. 2006-06-15 12:54:21.518 File: "/infrastructure/archive/rc.mysqld"
. 2006-06-15 12:54:21.518 Copying "/infrastructure/archive/rc.mysqld" to local directory started.
. 2006-06-15 12:54:21.518 Binary transfer mode selected.
. 2006-06-15 12:54:21.518 Opening remote file.
> 2006-06-15 12:54:21.518 Type: SSH_FXP_OPEN, Size: 50, Number: 3331
< 2006-06-15 12:54:21.518 Type: SSH_FXP_STATUS, Size: 24, Number: 3076
. 2006-06-15 12:54:21.518 Discarding reserved response
< 2006-06-15 12:54:21.565 Type: SSH_FXP_HANDLE, Size: 13, Number: 3331
> 2006-06-15 12:54:21.565 Type: SSH_FXP_FSTAT, Size: 13, Number: 3592
> 2006-06-15 12:54:21.565 Type: SSH_FXP_READ, Size: 25, Number: 3845
< 2006-06-15 12:54:21.613 Type: SSH_FXP_ATTRS, Size: 37, Number: 3592
. 2006-06-15 12:54:21.613 Storing reserved response
< 2006-06-15 12:54:21.739 Status/error code: 1
. 2006-06-15 12:54:21.739 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2006-06-15 12:54:21.739 Type: SSH_FXP_CLOSE, Size: 13, Number: 4356
. 2006-06-15 12:54:22.213 Detected incoming data while idle
. 2006-06-15 12:54:26.498 File: "/infrastructure/archive/apache-tomcat-5.5.12-deployer.tar.gz"
. 2006-06-15 12:54:26.498 Copying "/infrastructure/archive/apache-tomcat-5.5.12-deployer.tar.gz" to local directory started.
. 2006-06-15 12:54:26.498 Binary transfer mode selected.
. 2006-06-15 12:54:26.498 Checking existence of partially transfered file.
. 2006-06-15 12:54:26.498 Opening remote file.
> 2006-06-15 12:54:26.498 Type: SSH_FXP_OPEN, Size: 77, Number: 4611
< 2006-06-15 12:54:26.498 Type: SSH_FXP_STATUS, Size: 24, Number: 4356
. 2006-06-15 12:54:26.498 Discarding reserved response
< 2006-06-15 12:54:26.546 Type: SSH_FXP_HANDLE, Size: 13, Number: 4611
> 2006-06-15 12:54:26.546 Type: SSH_FXP_FSTAT, Size: 13, Number: 4872
> 2006-06-15 12:54:26.546 Type: SSH_FXP_READ, Size: 25, Number: 5125
. 2006-06-15 12:54:26.593 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2006-06-15 12:54:26.593 Type: SSH_FXP_ATTRS, Size: 37, Number: 4872
. 2006-06-15 12:54:26.593 Storing reserved response
. 2006-06-15 12:54:27.937 Detected incoming data while idle
. 2006-06-15 12:54:34.135 Detected incoming data while idle
. 2006-06-15 12:54:36.190 Detected incoming data while idle
< 2006-06-15 12:54:38.562 Status/error code: 1
. 2006-06-15 12:54:38.562 67 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2006-06-15 12:54:38.562 Type: SSH_FXP_CLOSE, Size: 13, Number: 14596
< 2006-06-15 12:54:38.562 Type: SSH_FXP_STATUS, Size: 28, Number: 13829
< 2006-06-15 12:54:38.609 Type: SSH_FXP_STATUS, Size: 28, Number: 14085
< 2006-06-15 12:54:38.641 Type: SSH_FXP_STATUS, Size: 28, Number: 14341
. 2006-06-15 12:54:38.941 Detected incoming data while idle
. 2006-06-15 12:55:17.441 Copying 1 files/directories to remote directory "/infrastructure/archive/"
. 2006-06-15 12:55:17.441 PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2006-06-15 12:55:17.441 TM: M; ClAr: No; ExclM(No):
. 2006-06-15 12:55:17.441 AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2006-06-15 12:55:17.441 File: "C:\Documents and Settings\DBullard\Desktop\dumpdb.pl"
. 2006-06-15 12:55:17.457 Copying "C:\Documents and Settings\DBullard\Desktop\dumpdb.pl" to remote directory started.
. 2006-06-15 12:55:17.457 Ascii transfer mode selected.
. 2006-06-15 12:55:17.457 Opening remote file.
> 2006-06-15 12:55:17.457 Type: SSH_FXP_OPEN, Size: 58, Number: 14851
< 2006-06-15 12:55:17.457 Type: SSH_FXP_STATUS, Size: 24, Number: 14596
. 2006-06-15 12:55:17.457 Discarding reserved response
< 2006-06-15 12:55:17.504 Type: SSH_FXP_HANDLE, Size: 13, Number: 14851
> 2006-06-15 12:55:17.504 Type: SSH_FXP_WRITE, Size: 538, Number: 15366
. 2006-06-15 12:55:17.647 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2006-06-15 12:55:17.647 Type: SSH_FXP_CLOSE, Size: 13, Number: 15620
> 2006-06-15 12:55:17.647 Type: SSH_FXP_SETSTAT, Size: 54, Number: 15113
< 2006-06-15 12:55:17.694 Type: SSH_FXP_STATUS, Size: 24, Number: 15620
< 2006-06-15 12:55:17.694 Status/error code: 0
< 2006-06-15 12:55:17.741 Type: SSH_FXP_STATUS, Size: 24, Number: 15113
< 2006-06-15 12:55:17.741 Status/error code: 0
. 2006-06-15 12:55:17.741 Listing directory "/infrastructure/archive".
> 2006-06-15 12:55:17.741 Type: SSH_FXP_OPENDIR, Size: 32, Number: 15883
< 2006-06-15 12:55:17.805 Type: SSH_FXP_HANDLE, Size: 13, Number: 15883
> 2006-06-15 12:55:17.805 Type: SSH_FXP_READDIR, Size: 13, Number: 16140
< 2006-06-15 12:55:17.931 Type: SSH_FXP_NAME, Size: 3486, Number: 16140
> 2006-06-15 12:55:17.931 Type: SSH_FXP_READDIR, Size: 13, Number: 16396
. 2006-06-15 12:55:17.931 Reading symlink ".#rc.mysqld".
> 2006-06-15 12:55:17.931 Type: SSH_FXP_READLINK, Size: 44, Number: 16659
> 2006-06-15 12:55:17.931 Type: SSH_FXP_STAT, Size: 44, Number: 16913
< 2006-06-15 12:55:17.979 Type: SSH_FXP_STATUS, Size: 28, Number: 16396
. 2006-06-15 12:55:17.979 Storing reserved response
< 2006-06-15 12:55:18.026 Type: SSH_FXP_NAME, Size: 105, Number: 16659
< 2006-06-15 12:55:18.168 Type: SSH_FXP_STATUS, Size: 29, Number: 16913
< 2006-06-15 12:55:18.168 Status/error code: 2, Message: 16913, Server: No such file, Language:
* 2006-06-15 12:55:18.168 (ECommand) Error reading symlink '.#rc.mysqld'.
* 2006-06-15 12:55:18.168 No such file or directory.
* 2006-06-15 12:55:18.168 Error code: 2
* 2006-06-15 12:55:18.168 Error message from server: No such file
* 2006-06-15 12:55:18.168 Request code: 17
< 2006-06-15 12:55:18.168 Status/error code: 1
> 2006-06-15 12:55:18.168 Type: SSH_FXP_CLOSE, Size: 13, Number: 17156
. 2006-06-15 12:55:18.326 Detected incoming data while idle
. 2006-06-15 12:55:25.267 Copying 1 files/directories to remote directory "/infrastructure/archive/"
. 2006-06-15 12:55:25.267 PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2006-06-15 12:55:25.267 TM: M; ClAr: No; ExclM(No):
. 2006-06-15 12:55:25.267 AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2006-06-15 12:55:25.267 File: "C:\Documents and Settings\DBullard\Desktop\building a server.txt"
. 2006-06-15 12:55:25.267 Copying "C:\Documents and Settings\DBullard\Desktop\building a server.txt" to remote directory started.
. 2006-06-15 12:55:25.267 Ascii transfer mode selected.
. 2006-06-15 12:55:25.267 Opening remote file.
> 2006-06-15 12:55:25.267 Type: SSH_FXP_OPEN, Size: 70, Number: 17411
< 2006-06-15 12:55:25.267 Type: SSH_FXP_STATUS, Size: 24, Number: 17156
. 2006-06-15 12:55:25.267 Discarding reserved response
< 2006-06-15 12:55:25.346 Type: SSH_FXP_HANDLE, Size: 13, Number: 17411
> 2006-06-15 12:55:25.346 Type: SSH_FXP_WRITE, Size: 175, Number: 17926
. 2006-06-15 12:55:25.410 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2006-06-15 12:55:25.410 Type: SSH_FXP_CLOSE, Size: 13, Number: 18180
> 2006-06-15 12:55:25.410 Type: SSH_FXP_SETSTAT, Size: 66, Number: 17673
< 2006-06-15 12:55:25.457 Type: SSH_FXP_STATUS, Size: 24, Number: 18180
< 2006-06-15 12:55:25.457 Status/error code: 0
< 2006-06-15 12:55:25.520 Type: SSH_FXP_STATUS, Size: 24, Number: 17673
< 2006-06-15 12:55:25.520 Status/error code: 0
. 2006-06-15 12:55:25.520 Listing directory "/infrastructure/archive".
> 2006-06-15 12:55:25.520 Type: SSH_FXP_OPENDIR, Size: 32, Number: 18443
< 2006-06-15 12:55:25.568 Type: SSH_FXP_HANDLE, Size: 13, Number: 18443
> 2006-06-15 12:55:25.568 Type: SSH_FXP_READDIR, Size: 13, Number: 18700
< 2006-06-15 12:55:25.694 Type: SSH_FXP_NAME, Size: 3624, Number: 18700
> 2006-06-15 12:55:25.694 Type: SSH_FXP_READDIR, Size: 13, Number: 18956
. 2006-06-15 12:55:25.694 Reading symlink ".#rc.mysqld".
> 2006-06-15 12:55:25.694 Type: SSH_FXP_READLINK, Size: 44, Number: 19219
> 2006-06-15 12:55:25.694 Type: SSH_FXP_STAT, Size: 44, Number: 19473
< 2006-06-15 12:55:25.742 Type: SSH_FXP_STATUS, Size: 28, Number: 18956
. 2006-06-15 12:55:25.742 Storing reserved response
< 2006-06-15 12:55:25.789 Type: SSH_FXP_NAME, Size: 105, Number: 19219
< 2006-06-15 12:55:26.026 Type: SSH_FXP_STATUS, Size: 29, Number: 19473
< 2006-06-15 12:55:26.026 Status/error code: 2, Message: 19473, Server: No such file, Language:
* 2006-06-15 12:55:26.026 (ECommand) Error reading symlink '.#rc.mysqld'.
* 2006-06-15 12:55:26.026 No such file or directory.
* 2006-06-15 12:55:26.026 Error code: 2
* 2006-06-15 12:55:26.026 Error message from server: No such file
* 2006-06-15 12:55:26.026 Request code: 17
< 2006-06-15 12:55:26.026 Status/error code: 1
> 2006-06-15 12:55:26.026 Type: SSH_FXP_CLOSE, Size: 13, Number: 19716
. 2006-06-15 12:55:26.184 Detected incoming data while idle
. 2006-06-15 12:55:33.995 Copying 1 files/directories to remote directory "/infrastructure/archive/"
. 2006-06-15 12:55:33.995 PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2006-06-15 12:55:33.995 TM: M; ClAr: No; ExclM(No):
. 2006-06-15 12:55:33.995 AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2006-06-15 12:55:33.995 File: "C:\Documents and Settings\DBullard\Desktop\crt.log"
. 2006-06-15 12:55:33.995 Copying "C:\Documents and Settings\DBullard\Desktop\crt.log" to remote directory started.
. 2006-06-15 12:55:33.995 Binary transfer mode selected.
. 2006-06-15 12:55:33.995 Opening remote file.
> 2006-06-15 12:55:33.995 Type: SSH_FXP_OPEN, Size: 56, Number: 19971
< 2006-06-15 12:55:33.995 Type: SSH_FXP_STATUS, Size: 24, Number: 19716
. 2006-06-15 12:55:33.995 Discarding reserved response
< 2006-06-15 12:55:34.058 Type: SSH_FXP_HANDLE, Size: 13, Number: 19971
> 2006-06-15 12:55:34.058 Type: SSH_FXP_WRITE, Size: 158, Number: 20486
. 2006-06-15 12:55:34.106 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2006-06-15 12:55:34.106 Type: SSH_FXP_CLOSE, Size: 13, Number: 20740
> 2006-06-15 12:55:34.106 Type: SSH_FXP_SETSTAT, Size: 52, Number: 20233
< 2006-06-15 12:55:34.153 Type: SSH_FXP_STATUS, Size: 24, Number: 20740
< 2006-06-15 12:55:34.153 Status/error code: 0
< 2006-06-15 12:55:34.201 Type: SSH_FXP_STATUS, Size: 24, Number: 20233
< 2006-06-15 12:55:34.201 Status/error code: 0
. 2006-06-15 12:55:34.201 Listing directory "/infrastructure/archive".
> 2006-06-15 12:55:34.201 Type: SSH_FXP_OPENDIR, Size: 32, Number: 21003
< 2006-06-15 12:55:34.248 Type: SSH_FXP_HANDLE, Size: 13, Number: 21003
> 2006-06-15 12:55:34.248 Type: SSH_FXP_READDIR, Size: 13, Number: 21260
< 2006-06-15 12:55:34.359 Type: SSH_FXP_NAME, Size: 3734, Number: 21260
> 2006-06-15 12:55:34.359 Type: SSH_FXP_READDIR, Size: 13, Number: 21516
. 2006-06-15 12:55:34.359 Reading symlink ".#rc.mysqld".
> 2006-06-15 12:55:34.359 Type: SSH_FXP_READLINK, Size: 44, Number: 21779
> 2006-06-15 12:55:34.359 Type: SSH_FXP_STAT, Size: 44, Number: 22033
< 2006-06-15 12:55:34.406 Type: SSH_FXP_STATUS, Size: 28, Number: 21516
. 2006-06-15 12:55:34.406 Storing reserved response
< 2006-06-15 12:55:34.453 Type: SSH_FXP_NAME, Size: 105, Number: 21779
< 2006-06-15 12:55:34.675 Type: SSH_FXP_STATUS, Size: 29, Number: 22033
< 2006-06-15 12:55:34.675 Status/error code: 2, Message: 22033, Server: No such file, Language:
* 2006-06-15 12:55:34.675 (ECommand) Error reading symlink '.#rc.mysqld'.
* 2006-06-15 12:55:34.675 No such file or directory.
* 2006-06-15 12:55:34.675 Error code: 2
* 2006-06-15 12:55:34.675 Error message from server: No such file
* 2006-06-15 12:55:34.675 Request code: 17
< 2006-06-15 12:55:34.675 Status/error code: 1
> 2006-06-15 12:55:34.675 Type: SSH_FXP_CLOSE, Size: 13, Number: 22276
. 2006-06-15 12:55:34.833 Detected incoming data while idle
. 2006-06-15 12:55:42.232 Copying 1 files/directories to remote directory "/infrastructure/archive/"
. 2006-06-15 12:55:42.232 PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2006-06-15 12:55:42.232 TM: M; ClAr: No; ExclM(No):
. 2006-06-15 12:55:42.232 AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2006-06-15 12:55:42.232 File: "C:\Documents and Settings\DBullard\Desktop\diffs.doc"
. 2006-06-15 12:55:42.232 Copying "C:\Documents and Settings\DBullard\Desktop\diffs.doc" to remote directory started.
. 2006-06-15 12:55:42.232 Binary transfer mode selected.
. 2006-06-15 12:55:42.232 Opening remote file.
> 2006-06-15 12:55:42.232 Type: SSH_FXP_OPEN, Size: 58, Number: 22531
< 2006-06-15 12:55:42.232 Type: SSH_FXP_STATUS, Size: 24, Number: 22276
. 2006-06-15 12:55:42.232 Discarding reserved response
< 2006-06-15 12:55:42.280 Type: SSH_FXP_HANDLE, Size: 13, Number: 22531
> 2006-06-15 12:55:42.280 Type: SSH_FXP_WRITE, Size: 4121, Number: 23046
. 2006-06-15 12:56:14.928 Detected incoming data while idle
. 2006-06-15 12:56:14.928 Network error: Connection reset by peer
Here is a log with DEBUG 2 level settings...
. 2006-06-15 13:21:42.239 --------------------------------------------------------------------------
. 2006-06-15 13:21:42.239 WinSCP Version 3.8.1 (Build 328) (OS 5.1.2600 Service Pack 2)
. 2006-06-15 13:21:42.239 Login time: Thursday, June 15, 2006 1:21:42 PM
. 2006-06-15 13:21:42.239 Session name: Ghost
. 2006-06-15 13:21:42.239 Host name: 10.0.20.7 (Port: 22)
. 2006-06-15 13:21:42.239 User name: root (Password: Yes, Key file: No)
. 2006-06-15 13:21:42.239 Transfer Protocol: SFTP (SCP)
. 2006-06-15 13:21:42.239 SSH protocol version: 2; Compression: No
. 2006-06-15 13:21:42.239 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2006-06-15 13:21:42.239 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2006-06-15 13:21:42.239 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2006-06-15 13:21:42.239 SSH Bugs: -,-,-,-,-,-,-,-
. 2006-06-15 13:21:42.239 SFTP Bugs: -,-,-
. 2006-06-15 13:21:42.239 Proxy: none
. 2006-06-15 13:21:42.239 Return code variable: Autodetect; Lookup user groups: Yes
. 2006-06-15 13:21:42.239 Shell: default, EOL: 0
. 2006-06-15 13:21:42.239 Local directory: C:\Documents and Settings\DBullard\Desktop, Remote directory: /infrastructure/archive, Update: Yes, Cache: Yes
. 2006-06-15 13:21:42.239 Cache directory changes: Yes, Permanent: Yes
. 2006-06-15 13:21:42.239 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2006-06-15 13:21:42.239 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2006-06-15 13:21:42.239 Looking up host "10.0.20.7"
. 2006-06-15 13:21:42.239 Connecting to 10.0.20.7 port 22
. 2006-06-15 13:21:42.396 Waiting for the server to continue with the initialisation
. 2006-06-15 13:21:42.396 Looking for incoming data
. 2006-06-15 13:21:42.443 Select result is 1
. 2006-06-15 13:21:42.443 Server version: SSH-1.99-OpenSSH_3.9p1
. 2006-06-15 13:21:42.443 We claim version: SSH-2.0-WinSCP_release_3.8.1
. 2006-06-15 13:21:42.443 Using SSH protocol version 2
. 2006-06-15 13:21:42.443 Waiting for the server to continue with the initialisation
. 2006-06-15 13:21:42.443 Looking for incoming data
. 2006-06-15 13:21:42.490 Select result is 1
. 2006-06-15 13:21:42.490 Doing Diffie-Hellman group exchange
. 2006-06-15 13:21:42.490 Waiting for the server to continue with the initialisation
. 2006-06-15 13:21:42.490 Looking for incoming data
. 2006-06-15 13:21:42.647 Select result is 1
. 2006-06-15 13:21:42.647 Doing Diffie-Hellman key exchange
. 2006-06-15 13:21:42.850 Waiting for the server to continue with the initialisation
. 2006-06-15 13:21:42.850 Looking for incoming data
. 2006-06-15 13:21:42.960 Select result is 1
. 2006-06-15 13:21:43.195 Host key fingerprint is:
. 2006-06-15 13:21:43.195 ssh-rsa 1024 6d:9e:b9:39:01:4d:3f:f0:ad:ec:1d:17:f4:13:30:3a
. 2006-06-15 13:21:43.195 Initialised AES-256 client->server encryption
. 2006-06-15 13:21:43.195 Initialised HMAC-SHA1 client->server MAC algorithm
. 2006-06-15 13:21:43.195 Initialised AES-256 server->client encryption
. 2006-06-15 13:21:43.195 Initialised HMAC-SHA1 server->client MAC algorithm
. 2006-06-15 13:21:43.195 Waiting for the server to continue with the initialisation
. 2006-06-15 13:21:43.195 Looking for incoming data
. 2006-06-15 13:21:43.320 Select result is 1
! 2006-06-15 13:21:43.320 Using username "root".
. 2006-06-15 13:21:43.320 Waiting for the server to continue with the initialisation
. 2006-06-15 13:21:43.320 Looking for incoming data
. 2006-06-15 13:21:43.367 Select result is 1
. 2006-06-15 13:21:43.367 Session password prompt (root@10.0.20.7's password: )
. 2006-06-15 13:21:43.367 Using stored password.
! 2006-06-15 13:21:43.367 Authenticating with pre-entered password.
. 2006-06-15 13:21:43.367 Sent password
. 2006-06-15 13:21:43.367 Waiting for the server to continue with the initialisation
. 2006-06-15 13:21:43.367 Looking for incoming data
. 2006-06-15 13:21:43.445 Select result is 1
. 2006-06-15 13:21:43.445 Access granted
. 2006-06-15 13:21:43.445 Waiting for the server to continue with the initialisation
. 2006-06-15 13:21:43.445 Looking for incoming data
. 2006-06-15 13:21:43.477 Select result is 1
. 2006-06-15 13:21:43.477 Opened channel for session
. 2006-06-15 13:21:43.477 Waiting for the server to continue with the initialisation
. 2006-06-15 13:21:43.477 Looking for incoming data
. 2006-06-15 13:21:43.524 Select result is 1
. 2006-06-15 13:21:43.524 Started a shell/command
. 2006-06-15 13:21:43.524 --------------------------------------------------------------------------
. 2006-06-15 13:21:43.524 Using SFTP protocol.
. 2006-06-15 13:21:43.524 Doing startup conversation with host.
> 2006-06-15 13:21:43.539 Type: SSH_FXP_INIT, Size: 5, Number: -1
> 2006-06-15 13:21:43.539 01,00,00,00,05,
. 2006-06-15 13:21:43.539 Sent 9 bytes
. 2006-06-15 13:21:43.539 There are 0 bytes remaining in the send buffer
. 2006-06-15 13:21:43.539 Waiting for another 4 bytes
. 2006-06-15 13:21:43.539 Looking for incoming data
. 2006-06-15 13:21:43.571 Select result is 1
. 2006-06-15 13:21:43.571 Received 4 bytes
. 2006-06-15 13:21:43.571 Received 5 bytes
< 2006-06-15 13:21:43.571 Type: SSH_FXP_VERSION, Size: 5, Number: -1
< 2006-06-15 13:21:43.571 02,00,00,00,03,
. 2006-06-15 13:21:43.571 SFTP version 3 negotiated.
. 2006-06-15 13:21:43.571 We believe the server has signed timestamps bug
. 2006-06-15 13:21:43.571 We will use UTF-8 strings for status messages only
. 2006-06-15 13:21:43.571 Limiting packet size to OpenSSH limit of 262148 bytes
. 2006-06-15 13:21:43.586 Changing directory to "/infrastructure/archive".
. 2006-06-15 13:21:43.586 Getting real path for '/infrastructure/archive'
> 2006-06-15 13:21:43.586 Type: SSH_FXP_REALPATH, Size: 32, Number: 16
> 2006-06-15 13:21:43.586 10,00,00,00,10,00,00,00,17,2F,69,6E,66,72,61,73,74,72,75,63,74,75,72,65,2F,
> 2006-06-15 13:21:43.586 61,72,63,68,69,76,65,
. 2006-06-15 13:21:43.586 Sent 36 bytes
. 2006-06-15 13:21:43.586 There are 0 bytes remaining in the send buffer
. 2006-06-15 13:21:43.586 Waiting for another 4 bytes
. 2006-06-15 13:21:43.586 Looking for incoming data
. 2006-06-15 13:21:43.633 Select result is 1
. 2006-06-15 13:21:43.633 Received 4 bytes
. 2006-06-15 13:21:43.633 Received 67 bytes
< 2006-06-15 13:21:43.633 Type: SSH_FXP_NAME, Size: 67, Number: 16
< 2006-06-15 13:21:43.633 68,00,00,00,10,00,00,00,01,00,00,00,17,2F,69,6E,66,72,61,73,74,72,75,63,74,
< 2006-06-15 13:21:43.633 75,72,65,2F,61,72,63,68,69,76,65,00,00,00,17,2F,69,6E,66,72,61,73,74,72,75,
< 2006-06-15 13:21:43.633 63,74,75,72,65,2F,61,72,63,68,69,76,65,00,00,00,00,
. 2006-06-15 13:21:43.633 Real path is '/infrastructure/archive'
. 2006-06-15 13:21:43.633 Trying to open directory "/infrastructure/archive".
> 2006-06-15 13:21:43.633 Type: SSH_FXP_LSTAT, Size: 32, Number: 263
> 2006-06-15 13:21:43.633 07,00,00,01,07,00,00,00,17,2F,69,6E,66,72,61,73,74,72,75,63,74,75,72,65,2F,
> 2006-06-15 13:21:43.633 61,72,63,68,69,76,65,
. 2006-06-15 13:21:43.633 Sent 36 bytes
. 2006-06-15 13:21:43.633 There are 0 bytes remaining in the send buffer
. 2006-06-15 13:21:43.633 Waiting for another 4 bytes
. 2006-06-15 13:21:43.633 Looking for incoming data
. 2006-06-15 13:21:43.680 Select result is 1
. 2006-06-15 13:21:43.680 Received 4 bytes
. 2006-06-15 13:21:43.680 Received 37 bytes
< 2006-06-15 13:21:43.680 Type: SSH_FXP_ATTRS, Size: 37, Number: 263
< 2006-06-15 13:21:43.680 69,00,00,01,07,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,
< 2006-06-15 13:21:43.680 00,00,41,ED,44,91,94,C7,44,91,94,C6,
. 2006-06-15 13:21:43.680 Getting current directory name.
. 2006-06-15 13:21:43.680 Listing directory "/infrastructure/archive".
> 2006-06-15 13:21:43.680 Type: SSH_FXP_OPENDIR, Size: 32, Number: 523
> 2006-06-15 13:21:43.680 0B,00,00,02,0B,00,00,00,17,2F,69,6E,66,72,61,73,74,72,75,63,74,75,72,65,2F,
> 2006-06-15 13:21:43.680 61,72,63,68,69,76,65,
. 2006-06-15 13:21:43.680 Sent 36 bytes
. 2006-06-15 13:21:43.680 There are 0 bytes remaining in the send buffer
. 2006-06-15 13:21:43.680 Waiting for another 4 bytes
. 2006-06-15 13:21:43.680 Looking for incoming data
. 2006-06-15 13:21:43.727 Select result is 1
. 2006-06-15 13:21:43.727 Received 4 bytes
. 2006-06-15 13:21:43.727 Received 13 bytes
< 2006-06-15 13:21:43.727 Type: SSH_FXP_HANDLE, Size: 13, Number: 523
< 2006-06-15 13:21:43.727 66,00,00,02,0B,00,00,00,04,00,00,00,00,
> 2006-06-15 13:21:43.727 Type: SSH_FXP_READDIR, Size: 13, Number: 780
> 2006-06-15 13:21:43.727 0C,00,00,03,0C,00,00,00,04,00,00,00,00,
. 2006-06-15 13:21:43.727 Sent 17 bytes
. 2006-06-15 13:21:43.727 There are 0 bytes remaining in the send buffer
. 2006-06-15 13:21:43.727 Waiting for another 4 bytes
. 2006-06-15 13:21:43.727 Looking for incoming data
. 2006-06-15 13:21:43.806 Select result is 1
. 2006-06-15 13:21:43.806 Waiting for another 4 bytes
. 2006-06-15 13:21:43.806 Looking for incoming data
. 2006-06-15 13:21:43.884 Select result is 1
. 2006-06-15 13:21:43.884 Waiting for another 4 bytes
. 2006-06-15 13:21:43.884 Looking for incoming data
. 2006-06-15 13:21:43.931 Select result is 1
. 2006-06-15 13:21:43.931 Received 4 bytes
. 2006-06-15 13:21:43.931 Received 3372 bytes
< 2006-06-15 13:21:43.931 Type: SSH_FXP_NAME, Size: 3372, Number: 780
< 2006-06-15 13:21:43.947 68,00,00,03,0C,00,00,00,19,00,00,00,21,61,70,61,63,68,65,2D,74,6F,6D,63,61,
< 2006-06-15 13:21:43.947 74,2D,35,2E,35,2E,31,32,2D,61,64,6D,69,6E,2E,74,61,72,2E,67,7A,00,00,00,59,
< 2006-06-15 13:21:43.947 2D,72,77,78,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,
< 2006-06-15 13:21:43.947 72,6F,6F,74,20,20,20,20,20,20,32,33,31,36,35,39,39,20,4E,6F,76,20,20,32,20,
< 2006-06-15 13:21:43.947 20,32,30,30,35,20,61,70,61,63,68,65,2D,74,6F,6D,63,61,74,2D,35,2E,35,2E,31,
< 2006-06-15 13:21:43.947 32,2D,61,64,6D,69,6E,2E,74,61,72,2E,67,7A,00,00,00,0F,00,00,00,00,00,23,59,
< 2006-06-15 13:21:43.947 37,00,00,00,00,00,00,00,00,00,00,81,E4,43,C6,C8,5D,43,69,13,67,00,00,00,06,
< 2006-06-15 13:21:43.947 6D,79,2E,63,6E,66,00,00,00,3E,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,
< 2006-06-15 13:21:43.947 20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,33,
< 2006-06-15 13:21:43.947 36,30,20,4E,6F,76,20,20,34,20,20,32,30,30,35,20,6D,79,2E,63,6E,66,00,00,00,
< 2006-06-15 13:21:43.947 0F,00,00,00,00,00,00,01,68,00,00,00,00,00,00,00,00,00,00,81,A4,44,90,2F,D4,
< 2006-06-15 13:21:43.947 43,6B,79,80,00,00,00,1F,61,70,61,63,68,65,2D,74,6F,6D,63,61,74,2D,35,2E,35,
< 2006-06-15 13:21:43.947 2E,31,32,2D,73,72,63,2E,74,61,72,2E,67,7A,00,00,00,57,2D,72,77,78,72,2D,2D,
< 2006-06-15 13:21:43.947 72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,
< 2006-06-15 13:21:43.947 20,20,20,34,32,33,39,34,35,32,20,4E,6F,76,20,20,32,20,20,32,30,30,35,20,61,
< 2006-06-15 13:21:43.947 70,61,63,68,65,2D,74,6F,6D,63,61,74,2D,35,2E,35,2E,31,32,2D,73,72,63,2E,74,
< 2006-06-15 13:21:43.947 61,72,2E,67,7A,00,00,00,0F,00,00,00,00,00,40,B0,5C,00,00,00,00,00,00,00,00,
< 2006-06-15 13:21:43.947 00,00,81,E4,44,90,2F,9A,43,69,60,1C,00,00,00,12,6D,79,73,71,6C,2D,34,2E,31,
< 2006-06-15 13:21:43.947 2E,37,2E,74,61,72,2E,67,7A,00,00,00,4A,2D,72,77,78,72,2D,2D,72,2D,2D,20,20,
< 2006-06-15 13:21:43.947 20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,31,39,38,
< 2006-06-15 13:21:43.947 34,39,30,34,36,20,44,65,63,20,31,35,20,31,30,3A,35,39,20,6D,79,73,71,6C,2D,
< 2006-06-15 13:21:43.947 34,2E,31,2E,37,2E,74,61,72,2E,67,7A,00,00,00,0F,00,00,00,00,01,2E,DF,56,00,
< 2006-06-15 13:21:43.947 00,00,00,00,00,00,00,00,00,81,E4,43,C6,C8,5D,43,A1,92,CC,00,00,00,0B,2E,23,
< 2006-06-15 13:21:43.947 72,63,2E,6D,79,73,71,6C,64,00,00,00,43,6C,72,77,78,72,77,78,72,77,78,20,20,
< 2006-06-15 13:21:43.947 20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,
< 2006-06-15 13:21:43.947 20,20,20,34,32,20,4A,61,6E,20,31,32,20,31,36,3A,32,31,20,2E,23,72,63,2E,6D,
< 2006-06-15 13:21:43.947 79,73,71,6C,64,00,00,00,0F,00,00,00,00,00,00,00,2A,00,00,00,00,00,00,00,00,
< 2006-06-15 13:21:43.947 00,00,A1,FF,44,91,94,C7,43,C6,C8,62,00,00,00,13,68,74,74,70,64,2D,32,2E,30,
< 2006-06-15 13:21:43.947 2E,35,35,2E,74,61,72,2E,67,7A,00,00,00,4B,2D,72,77,78,72,2D,2D,72,2D,2D,20,
< 2006-06-15 13:21:43.947 20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,36,
< 2006-06-15 13:21:43.947 31,30,34,35,30,33,20,4E,6F,76,20,20,32,20,20,32,30,30,35,20,68,74,74,70,64,
< 2006-06-15 13:21:43.947 2D,32,2E,30,2E,35,35,2E,74,61,72,2E,67,7A,00,00,00,0F,00,00,00,00,00,5D,25,
< 2006-06-15 13:21:43.947 B7,00,00,00,00,00,00,00,00,00,00,81,E4,44,90,2F,91,43,69,10,DF,00,00,00,09,
< 2006-06-15 13:21:43.947 72,63,2E,74,6F,6D,63,61,74,00,00,00,41,2D,72,77,78,72,2D,78,72,2D,78,20,20,
< 2006-06-15 13:21:43.947 20,31,33,33,36,20,4E,6F,76,20,20,32,20,20,32,30,30,35,20,72,63,2E,74,6F,6D,
< 2006-06-15 13:21:43.947 63,61,74,00,00,00,0F,00,00,00,00,00,00,05,38,00,00,00,00,00,00,00,00,00,00,
< 2006-06-15 13:21:43.947 81,ED,44,91,8F,11,43,69,68,FB,00,00,00,12,63,75,72,6C,2D,37,2E,31,34,2E,31,
< 2006-06-15 13:21:43.947 2E,74,61,72,2E,67,7A,00,00,00,4A,2D,72,77,78,72,2D,2D,72,2D,2D,20,20,20,20,
< 2006-06-15 13:21:43.947 31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,31,37,32,31,
< 2006-06-15 13:21:43.947 35,35,38,20,4E,6F,76,20,20,32,20,20,32,30,30,35,20,63,75,72,6C,2D,37,2E,31,
< 2006-06-15 13:21:43.947 34,2E,31,2E,74,61,72,2E,67,7A,00,00,00,0F,00,00,00,00,00,1A,44,D6,00,00,00,
< 2006-06-15 13:21:43.947 00,00,00,00,00,00,00,81,E4,44,8F,25,A9,43,69,6A,BB,00,00,00,20,6A,64,6B,2D,
< 2006-06-15 13:21:43.947 31,5F,35,5F,30,5F,30,35,2D,6E,62,2D,34,5F,31,2D,6C,69,6E,75,78,2D,6D,6C,2E,
< 2006-06-15 13:21:43.947 62,69,6E,00,00,00,59,2D,72,77,78,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,
< 2006-06-15 13:21:43.947 6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,31,32,36,34,32,33,36,32,39,
< 2006-06-15 13:21:43.947 20,4E,6F,76,20,20,34,20,20,32,30,30,35,20,6A,64,6B,2D,31,5F,35,5F,30,5F,30,
< 2006-06-15 13:21:43.947 35,2D,6E,62,2D,34,5F,31,2D,6C,69,6E,75,78,2D,6D,6C,2E,62,69,6E,00,00,00,0F,
< 2006-06-15 13:21:43.947 00,00,00,00,07,89,12,4D,00,00,00,00,00,00,00,00,00,00,81,E4,44,91,80,19,43,
< 2006-06-15 13:21:43.947 6B,8B,D5,00,00,00,13,6D,79,73,71,6C,2D,35,2E,30,2E,31,36,2E,74,61,72,2E,67,
< 2006-06-15 13:21:43.947 7A,00,00,00,4B,2D,72,77,78,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,
< 2006-06-15 13:21:43.947 20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,31,39,30,33,31,36,37,30,20,4E,6F,
< 2006-06-15 13:21:43.947 76,20,32,37,20,20,32,30,30,35,20,6D,79,73,71,6C,2D,35,2E,30,2E,31,36,2E,74,
< 2006-06-15 13:21:43.947 61,72,2E,67,7A,00,00,00,0F,00,00,00,00,01,22,66,76,00,00,00,00,00,00,00,00,
< 2006-06-15 13:21:43.947 00,00,81,E4,44,90,2F,D2,43,8A,2D,E4,00,00,00,24,61,70,61,63,68,65,2D,74,6F,
< 2006-06-15 13:21:43.947 6D,63,61,74,2D,35,2E,35,2E,31,32,2D,64,65,70,6C,6F,79,65,72,2E,74,61,72,2E,
< 2006-06-15 13:21:43.947 67,7A,00,00,00,5C,2D,72,77,78,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,
< 2006-06-15 13:21:43.947 74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,38,33,35,36,35,39,20,4E,
< 2006-06-15 13:21:43.947 6F,76,20,20,32,20,20,32,30,30,35,20,61,70,61,63,68,65,2D,74,6F,6D,63,61,74,
< 2006-06-15 13:21:43.947 2D,35,2E,35,2E,31,32,2D,64,65,70,6C,6F,79,65,72,2E,74,61,72,2E,67,7A,00,00,
< 2006-06-15 13:21:43.947 00,0F,00,00,00,00,00,0C,C0,4B,00,00,00,00,00,00,00,00,00,00,81,E4,44,91,8F,
< 2006-06-15 13:21:43.947 28,43,69,13,6F,00,00,00,09,72,63,2E,6D,79,73,71,6C,64,00,00,00,41,2D,72,77,
< 2006-06-15 13:21:43.947 78,72,2D,78,72,2D,78,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,
< 2006-06-15 13:21:43.947 74,20,20,20,20,20,20,20,20,20,31,39,39,30,20,4E,6F,76,20,20,34,20,20,32,30,
< 2006-06-15 13:21:43.947 30,35,20,72,63,2E,6D,79,73,71,6C,64,00,00,00,0F,00,00,00,00,00,00,07,C6,00,
< 2006-06-15 13:21:43.947 00,00,00,00,00,00,00,00,00,81,ED,44,91,8F,17,43,6B,79,E9,00,00,00,1B,61,70,
< 2006-06-15 13:21:43.947 61,63,68,65,2D,61,6E,74,2D,31,2E,36,2E,32,2D,62,69,6E,2E,74,61,72,2E,67,7A,
< 2006-06-15 13:21:43.947 00,00,00,53,2D,72,77,78,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,
< 2006-06-15 13:21:43.947 20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,37,39,33,31,31,37,39,20,4E,6F,76,
< 2006-06-15 13:21:43.947 20,20,32,20,20,32,30,30,35,20,61,70,61,63,68,65,2D,61,6E,74,2D,31,2E,36,2E,
< 2006-06-15 13:21:43.947 32,2D,62,69,6E,2E,74,61,72,2E,67,7A,00,00,00,0F,00,00,00,00,00,79,05,2B,00,
< 2006-06-15 13:21:43.947 00,00,00,00,00,00,00,00,00,81,E4,44,90,2F,80,43,69,5D,80,00,00,00,1D,6A,32,
< 2006-06-15 13:21:43.947 73,64,6B,2D,31,2E,34,2E,32,2D,30,32,2D,6C,69,6E,75,78,2D,69,35,38,36,2E,62,
< 2006-06-15 13:21:43.947 69,6E,00,00,00,55,2D,72,77,78,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,
< 2006-06-15 13:21:43.947 74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,33,34,33,36,31,34,37,39,20,4E,
< 2006-06-15 13:21:43.947 6F,76,20,20,32,20,20,32,30,30,35,20,6A,32,73,64,6B,2D,31,2E,34,2E,32,2D,30,
< 2006-06-15 13:21:43.947 32,2D,6C,69,6E,75,78,2D,69,35,38,36,2E,62,69,6E,00,00,00,0F,00,00,00,00,02,
< 2006-06-15 13:21:43.947 0C,50,87,00,00,00,00,00,00,00,00,00,00,81,E4,44,90,2F,7F,43,69,1A,39,00,00,
< 2006-06-15 13:21:43.947 00,10,70,68,70,2D,34,2E,34,2E,31,2E,74,61,72,2E,67,7A,00,00,00,48,2D,72,77,
< 2006-06-15 13:21:43.947 78,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,
< 2006-06-15 13:21:43.947 74,20,20,20,20,20,20,35,31,31,30,34,35,38,20,4E,6F,76,20,20,32,20,20,32,30,
< 2006-06-15 13:21:43.947 30,35,20,70,68,70,2D,34,2E,34,2E,31,2E,74,61,72,2E,67,7A,00,00,00,0F,00,00,
< 2006-06-15 13:21:43.947 00,00,00,4D,FA,BA,00,00,00,00,00,00,00,00,00,00,81,E4,44,8F,25,A4,43,69,14,
< 2006-06-15 13:21:43.947 0D,00,00,00,29,4E,65,74,42,65,61,6E,73,49,44,45,2D,72,65,6C,65,61,73,65,33,
< 2006-06-15 13:21:43.947 35,31,2D,6C,69,6E,75,78,2E,62,69,6E,2E,66,69,6C,65,70,61,72,74,00,00,00,61,
< 2006-06-15 13:21:43.947 2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,
< 2006-06-15 13:21:43.947 72,6F,6F,74,20,20,20,20,20,20,20,20,37,33,37,32,38,20,4A,75,6E,20,31,35,20,
< 2006-06-15 13:21:43.947 31,33,3A,31,31,20,4E,65,74,42,65,61,6E,73,49,44,45,2D,72,65,6C,65,61,73,65,
< 2006-06-15 13:21:43.947 33,35,31,2D,6C,69,6E,75,78,2E,62,69,6E,2E,66,69,6C,65,70,61,72,74,00,00,00,
< 2006-06-15 13:21:43.947 0F,00,00,00,00,00,01,20,00,00,00,00,00,00,00,00,00,00,00,81,A4,44,91,7D,29,
< 2006-06-15 13:21:43.947 44,91,94,CF,00,00,00,1B,61,70,61,63,68,65,2D,74,6F,6D,63,61,74,2D,35,2E,35,
< 2006-06-15 13:21:43.947 2E,31,32,2E,74,61,72,2E,67,7A,00,00,00,53,2D,72,77,78,72,2D,2D,72,2D,2D,20,
< 2006-06-15 13:21:43.947 20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,35,
< 2006-06-15 13:21:43.947 39,32,34,32,31,34,20,4E,6F,76,20,20,32,20,20,32,30,30,35,20,61,70,61,63,68,
< 2006-06-15 13:21:43.947 65,2D,74,6F,6D,63,61,74,2D,35,2E,35,2E,31,32,2E,74,61,72,2E,67,7A,00,00,00,
< 2006-06-15 13:21:43.947 0F,00,00,00,00,00,5A,65,76,00,00,00,00,00,00,00,00,00,00,81,E4,43,C6,C8,5D,
< 2006-06-15 13:21:43.947 43,69,13,A7,00,00,00,0A,72,63,2E,6D,79,73,71,6C,64,7E,00,00,00,42,2D,72,77,
< 2006-06-15 13:21:43.947 74,20,20,20,20,20,20,20,20,20,32,30,32,35,20,4E,6F,76,20,20,32,20,20,32,30,
< 2006-06-15 13:21:43.947 30,35,20,72,63,2E,6D,79,73,71,6C,64,7E,00,00,00,0F,00,00,00,00,00,00,07,E9,
< 2006-06-15 13:21:43.947 00,00,00,00,00,00,00,00,00,00,81,ED,43,C6,C8,5D,43,69,34,5E,00,00,00,01,2E,
< 2006-06-15 13:21:43.947 00,00,00,39,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,32,20,72,6F,6F,74,20,
< 2006-06-15 13:21:43.947 20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,34,30,39,36,20,4A,75,6E,
< 2006-06-15 13:21:43.947 20,31,35,20,31,33,3A,31,31,20,2E,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,
< 2006-06-15 13:21:43.947 00,00,00,00,00,00,00,00,41,ED,44,91,95,7B,44,91,94,C6,00,00,00,11,72,63,2E,
< 2006-06-15 13:21:43.947 73,63,72,69,70,74,2D,61,70,61,63,68,65,32,00,00,00,49,2D,72,77,2D,72,2D,2D,
< 2006-06-15 13:21:43.947 20,20,20,20,20,20,32,31,32,36,20,4E,6F,76,20,20,32,20,20,32,30,30,35,20,72,
< 2006-06-15 13:21:43.947 63,2E,73,63,72,69,70,74,2D,61,70,61,63,68,65,32,00,00,00,0F,00,00,00,00,00,
< 2006-06-15 13:21:43.947 00,08,4E,00,00,00,00,00,00,00,00,00,00,81,A4,44,90,2F,93,43,69,34,65,00,00,
< 2006-06-15 13:21:43.947 00,13,6D,79,73,71,6C,2D,35,2E,30,2E,31,35,2E,74,61,72,2E,67,7A,00,00,00,4B,
< 2006-06-15 13:21:43.947 72,6F,6F,74,20,20,20,20,20,31,38,38,31,33,30,36,35,20,4E,6F,76,20,20,32,20,
< 2006-06-15 13:21:43.947 20,32,30,30,35,20,6D,79,73,71,6C,2D,35,2E,30,2E,31,35,2E,74,61,72,2E,67,7A,
< 2006-06-15 13:21:43.947 00,00,00,0F,00,00,00,00,01,1F,10,89,00,00,00,00,00,00,00,00,00,00,81,E4,43,
< 2006-06-15 13:21:43.947 C6,C8,5D,43,69,1B,C0,00,00,00,13,6D,79,73,71,6C,2D,34,2E,30,2E,32,35,2E,74,
< 2006-06-15 13:21:43.947 61,72,2E,67,7A,00,00,00,4B,2D,72,77,78,72,2D,2D,72,2D,2D,20,20,20,20,31,20,
< 2006-06-15 13:21:43.947 72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,31,31,31,35,39,32,38,
< 2006-06-15 13:21:43.947 38,20,44,65,63,20,31,35,20,31,31,3A,30,37,20,6D,79,73,71,6C,2D,34,2E,30,2E,
< 2006-06-15 13:21:43.947 32,35,2E,74,61,72,2E,67,7A,00,00,00,0F,00,00,00,00,00,AA,46,F8,00,00,00,00,
< 2006-06-15 13:21:43.947 00,00,00,00,00,00,81,E4,44,8F,26,08,43,A1,94,BD,00,00,00,02,2E,2E,00,00,00,
< 2006-06-15 13:21:43.947 3A,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,35,20,72,6F,6F,74,20,20,20,20,
< 2006-06-15 13:21:43.947 20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,34,30,39,36,20,4E,6F,76,20,20,32,
< 2006-06-15 13:21:43.947 20,20,32,30,30,35,20,2E,2E,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,
< 2006-06-15 13:21:43.947 00,00,00,00,00,00,41,ED,44,91,7F,7F,43,69,10,ED,00,00,00,15,6F,70,65,6E,73,
< 2006-06-15 13:21:43.947 73,6C,2D,30,2E,39,2E,38,61,2E,74,61,72,2E,67,7A,00,00,00,4D,2D,72,77,78,72,
< 2006-06-15 13:21:43.947 2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,
< 2006-06-15 13:21:43.947 20,20,20,20,20,33,32,37,31,34,33,35,20,4E,6F,76,20,20,32,20,20,32,30,30,35,
< 2006-06-15 13:21:43.947 20,6F,70,65,6E,73,73,6C,2D,30,2E,39,2E,38,61,2E,74,61,72,2E,67,7A,00,00,00,
< 2006-06-15 13:21:43.947 0F,00,00,00,00,00,31,EB,0B,00,00,00,00,00,00,00,00,00,00,81,E4,44,90,2F,8D,
< 2006-06-15 13:21:43.947 43,69,26,C4,00,00,00,0B,23,72,63,2E,6D,79,73,71,6C,64,23,00,00,00,43,2D,72,
< 2006-06-15 13:21:43.947 77,78,72,2D,78,72,2D,78,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,
< 2006-06-15 13:21:43.947 6F,74,20,20,20,20,20,20,20,20,20,31,39,39,30,20,4E,6F,76,20,20,34,20,20,32,
< 2006-06-15 13:21:43.947 30,30,35,20,23,72,63,2E,6D,79,73,71,6C,64,23,00,00,00,0F,00,00,00,00,00,00,
< 2006-06-15 13:21:43.947 07,C6,00,00,00,00,00,00,00,00,00,00,81,ED,43,C6,C8,5D,43,6B,7A,A9,
> 2006-06-15 13:21:43.947 Type: SSH_FXP_READDIR, Size: 13, Number: 1036
> 2006-06-15 13:21:43.947 0C,00,00,04,0C,00,00,00,04,00,00,00,00,
. 2006-06-15 13:21:43.947 Sent 17 bytes
. 2006-06-15 13:21:43.947 There are 0 bytes remaining in the send buffer
. 2006-06-15 13:21:43.947 Reading symlink ".#rc.mysqld".
> 2006-06-15 13:21:43.947 Type: SSH_FXP_READLINK, Size: 44, Number: 1299
> 2006-06-15 13:21:43.947 13,00,00,05,13,00,00,00,23,2F,69,6E,66,72,61,73,74,72,75,63,74,75,72,65,2F,
> 2006-06-15 13:21:43.947 61,72,63,68,69,76,65,2F,2E,23,72,63,2E,6D,79,73,71,6C,64,
. 2006-06-15 13:21:43.947 Sent 48 bytes
> 2006-06-15 13:21:43.947 Type: SSH_FXP_STAT, Size: 44, Number: 1553
> 2006-06-15 13:21:43.947 11,00,00,06,11,00,00,00,23,2F,69,6E,66,72,61,73,74,72,75,63,74,75,72,65,2F,
. 2006-06-15 13:21:43.947 Waiting for another 4 bytes
. 2006-06-15 13:21:43.947 Looking for incoming data
. 2006-06-15 13:21:43.994 Select result is 1
. 2006-06-15 13:21:43.994 Received 4 bytes
. 2006-06-15 13:21:43.994 Received 28 bytes
< 2006-06-15 13:21:43.994 Type: SSH_FXP_STATUS, Size: 28, Number: 1036
< 2006-06-15 13:21:43.994 65,00,00,04,0C,00,00,00,01,00,00,00,0B,45,6E,64,20,6F,66,20,66,69,6C,65,00,
< 2006-06-15 13:21:43.994 00,00,00,
. 2006-06-15 13:21:43.994 Storing reserved response
. 2006-06-15 13:21:43.994 Waiting for another 4 bytes
. 2006-06-15 13:21:43.994 Looking for incoming data
. 2006-06-15 13:21:44.041 Select result is 1
. 2006-06-15 13:21:44.041 Received 4 bytes
. 2006-06-15 13:21:44.041 Received 105 bytes
< 2006-06-15 13:21:44.041 Type: SSH_FXP_NAME, Size: 105, Number: 1299
< 2006-06-15 13:21:44.041 68,00,00,05,13,00,00,00,01,00,00,00,2A,72,6F,6F,74,40,77,69,74,63,68,2E,70,
< 2006-06-15 13:21:44.041 72,69,6E,74,76,69,73,69,6F,6E,2E,63,6F,6D,2E,33,39,35,34,3A,31,31,33,31,30,
< 2006-06-15 13:21:44.041 35,34,34,34,31,00,00,00,2A,72,6F,6F,74,40,77,69,74,63,68,2E,70,72,69,6E,74,
< 2006-06-15 13:21:44.041 76,69,73,69,6F,6E,2E,63,6F,6D,2E,33,39,35,34,3A,31,31,33,31,30,35,34,34,34,
< 2006-06-15 13:21:44.041 31,00,00,00,00,
. 2006-06-15 13:21:44.041 Waiting for another 4 bytes
. 2006-06-15 13:21:44.041 Looking for incoming data
. 2006-06-15 13:21:44.197 Select result is 1
. 2006-06-15 13:21:44.197 Received 4 bytes
. 2006-06-15 13:21:44.197 Received 29 bytes
< 2006-06-15 13:21:44.197 Type: SSH_FXP_STATUS, Size: 29, Number: 1553
< 2006-06-15 13:21:44.197 65,00,00,06,11,00,00,00,02,00,00,00,0C,4E,6F,20,73,75,63,68,20,66,69,6C,65,
< 2006-06-15 13:21:44.197 00,00,00,00,
< 2006-06-15 13:21:44.197 Status/error code: 2, Message: 1553, Server: No such file, Language:
* 2006-06-15 13:21:44.197 (ECommand) Error reading symlink '.#rc.mysqld'.
* 2006-06-15 13:21:44.197 No such file or directory.
* 2006-06-15 13:21:44.197 Error code: 2
* 2006-06-15 13:21:44.197 Error message from server: No such file
* 2006-06-15 13:21:44.197 Request code: 17
< 2006-06-15 13:21:44.197 Status/error code: 1
> 2006-06-15 13:21:44.197 Type: SSH_FXP_CLOSE, Size: 13, Number: 1796
> 2006-06-15 13:21:44.197 04,00,00,07,04,00,00,00,04,00,00,00,00,
. 2006-06-15 13:21:44.197 Sent 17 bytes
. 2006-06-15 13:21:44.197 There are 0 bytes remaining in the send buffer
. 2006-06-15 13:21:44.197 Startup conversation with host finished.
. 2006-06-15 13:21:45.654 Session upkeep
. 2006-06-15 13:21:45.654 Select result is 1
. 2006-06-15 13:21:45.654 Detected incoming data while idle
. 2006-06-15 13:21:46.046 Session upkeep
. 2006-06-15 13:21:46.046 Select result is 0
. 2006-06-15 13:21:46.547 Session upkeep
. 2006-06-15 13:21:46.547 Select result is 0
. 2006-06-15 13:21:47.048 Session upkeep
. 2006-06-15 13:21:47.048 Select result is 0
. 2006-06-15 13:21:47.549 Session upkeep
. 2006-06-15 13:21:47.549 Select result is 0
. 2006-06-15 13:21:48.051 Session upkeep
. 2006-06-15 13:21:48.051 Select result is 0
. 2006-06-15 13:21:48.552 Session upkeep
. 2006-06-15 13:21:48.552 Select result is 0
. 2006-06-15 13:21:49.053 Session upkeep
. 2006-06-15 13:21:49.053 Select result is 0
. 2006-06-15 13:21:49.555 Session upkeep
. 2006-06-15 13:21:49.555 Select result is 0
. 2006-06-15 13:21:50.056 Session upkeep
. 2006-06-15 13:21:50.056 Select result is 0
. 2006-06-15 13:21:50.557 Session upkeep
. 2006-06-15 13:21:50.557 Select result is 0
. 2006-06-15 13:21:51.058 Session upkeep
. 2006-06-15 13:21:51.058 Select result is 0
. 2006-06-15 13:21:51.560 Session upkeep
. 2006-06-15 13:21:51.560 Select result is 0
. 2006-06-15 13:21:52.061 Session upkeep
. 2006-06-15 13:21:52.061 Select result is 0
. 2006-06-15 13:21:52.562 Session upkeep
. 2006-06-15 13:21:52.562 Select result is 0
. 2006-06-15 13:21:53.063 Session upkeep
. 2006-06-15 13:21:53.063 Select result is 0
. 2006-06-15 13:21:53.565 Session upkeep
. 2006-06-15 13:21:53.565 Select result is 0
. 2006-06-15 13:21:54.066 Session upkeep
. 2006-06-15 13:21:54.066 Select result is 0
. 2006-06-15 13:21:54.567 Session upkeep
. 2006-06-15 13:21:54.567 Select result is 0
. 2006-06-15 13:21:55.068 Session upkeep
. 2006-06-15 13:21:55.068 Select result is 0
. 2006-06-15 13:21:55.570 Session upkeep
. 2006-06-15 13:21:55.570 Select result is 0
. 2006-06-15 13:21:56.071 Session upkeep
. 2006-06-15 13:21:56.071 Select result is 0
. 2006-06-15 13:21:56.572 Session upkeep
. 2006-06-15 13:21:56.572 Select result is 0
. 2006-06-15 13:21:57.073 Session upkeep
. 2006-06-15 13:21:57.073 Select result is 0
. 2006-06-15 13:21:57.575 Session upkeep
. 2006-06-15 13:21:57.575 Select result is 0
. 2006-06-15 13:21:58.076 Session upkeep
. 2006-06-15 13:21:58.076 Select result is 0
. 2006-06-15 13:21:58.577 Session upkeep
. 2006-06-15 13:21:58.577 Select result is 0
. 2006-06-15 13:21:59.078 Session upkeep
. 2006-06-15 13:21:59.078 Select result is 0
. 2006-06-15 13:21:59.580 Session upkeep
. 2006-06-15 13:21:59.580 Select result is 0
. 2006-06-15 13:22:00.081 Session upkeep
. 2006-06-15 13:22:00.081 Select result is 0
. 2006-06-15 13:22:00.582 Session upkeep
. 2006-06-15 13:22:00.582 Select result is 0
. 2006-06-15 13:22:01.083 Session upkeep
. 2006-06-15 13:22:01.083 Select result is 0
. 2006-06-15 13:22:01.585 Session upkeep
. 2006-06-15 13:22:01.585 Select result is 0
. 2006-06-15 13:22:02.086 Session upkeep
. 2006-06-15 13:22:02.086 Select result is 0
. 2006-06-15 13:22:02.587 Session upkeep
. 2006-06-15 13:22:02.587 Select result is 0
. 2006-06-15 13:22:03.088 Session upkeep
. 2006-06-15 13:22:03.088 Select result is 0
. 2006-06-15 13:22:03.590 Session upkeep
. 2006-06-15 13:22:03.590 Select result is 0
. 2006-06-15 13:22:04.091 Session upkeep
. 2006-06-15 13:22:04.091 Select result is 0
. 2006-06-15 13:22:04.592 Session upkeep
. 2006-06-15 13:22:04.592 Select result is 0
. 2006-06-15 13:22:05.094 Session upkeep
. 2006-06-15 13:22:05.094 Select result is 0
. 2006-06-15 13:22:05.595 Session upkeep
. 2006-06-15 13:22:05.595 Select result is 0
. 2006-06-15 13:22:06.096 Session upkeep
. 2006-06-15 13:22:06.096 Select result is 0
. 2006-06-15 13:22:06.597 Session upkeep
. 2006-06-15 13:22:06.597 Select result is 0
. 2006-06-15 13:22:07.099 Session upkeep
. 2006-06-15 13:22:07.099 Select result is 0
. 2006-06-15 13:22:07.600 Session upkeep
. 2006-06-15 13:22:07.615 Select result is 0
. 2006-06-15 13:22:08.101 Session upkeep
. 2006-06-15 13:22:08.101 Select result is 0
. 2006-06-15 13:22:08.602 Session upkeep
. 2006-06-15 13:22:08.602 Select result is 0
. 2006-06-15 13:22:09.104 Session upkeep
. 2006-06-15 13:22:09.104 Select result is 0
. 2006-06-15 13:22:09.605 Session upkeep
. 2006-06-15 13:22:09.605 Select result is 0
. 2006-06-15 13:22:10.106 Session upkeep
. 2006-06-15 13:22:10.106 Select result is 0
. 2006-06-15 13:22:10.607 Session upkeep
. 2006-06-15 13:22:10.607 Select result is 0
. 2006-06-15 13:22:11.109 Session upkeep
. 2006-06-15 13:22:11.109 Select result is 0
. 2006-06-15 13:22:11.610 Session upkeep
. 2006-06-15 13:22:11.610 Select result is 0
. 2006-06-15 13:22:12.111 Session upkeep
. 2006-06-15 13:22:12.111 Select result is 0
. 2006-06-15 13:22:12.612 Session upkeep
. 2006-06-15 13:22:12.612 Select result is 0
. 2006-06-15 13:22:13.114 Session upkeep
. 2006-06-15 13:22:13.114 Select result is 0
. 2006-06-15 13:22:13.615 Session upkeep
. 2006-06-15 13:22:13.615 Select result is 0
. 2006-06-15 13:22:14.116 Session upkeep
. 2006-06-15 13:22:14.116 Select result is 0
. 2006-06-15 13:22:14.617 Session upkeep
. 2006-06-15 13:22:14.617 Select result is 0
. 2006-06-15 13:22:15.119 Session upkeep
. 2006-06-15 13:22:15.119 Select result is 0
. 2006-06-15 13:22:15.620 Session upkeep
. 2006-06-15 13:22:15.620 Select result is 0
. 2006-06-15 13:22:16.466 Session upkeep
. 2006-06-15 13:22:16.466 Select result is 0
. 2006-06-15 13:22:16.857 Session upkeep
. 2006-06-15 13:22:16.857 Select result is 0
. 2006-06-15 13:22:17.124 Session upkeep
. 2006-06-15 13:22:17.124 Select result is 0
. 2006-06-15 13:22:17.625 Session upkeep
. 2006-06-15 13:22:17.625 Select result is 0
. 2006-06-15 13:22:18.126 Session upkeep
. 2006-06-15 13:22:18.126 Select result is 0
. 2006-06-15 13:22:18.627 Session upkeep
. 2006-06-15 13:22:18.627 Select result is 0
. 2006-06-15 13:22:19.129 Session upkeep
. 2006-06-15 13:22:19.129 Select result is 0
. 2006-06-15 13:22:19.630 Session upkeep
. 2006-06-15 13:22:19.646 Select result is 0
. 2006-06-15 13:22:20.131 Session upkeep
. 2006-06-15 13:22:20.131 Select result is 0
. 2006-06-15 13:22:20.632 Session upkeep
. 2006-06-15 13:22:20.632 Select result is 0
. 2006-06-15 13:22:21.134 Session upkeep
. 2006-06-15 13:22:21.134 Select result is 0
. 2006-06-15 13:22:21.635 Session upkeep
. 2006-06-15 13:22:21.635 Select result is 0
. 2006-06-15 13:22:22.136 Session upkeep
. 2006-06-15 13:22:22.136 Select result is 0
. 2006-06-15 13:22:22.638 Session upkeep
. 2006-06-15 13:22:22.638 Select result is 0
. 2006-06-15 13:22:23.139 Session upkeep
. 2006-06-15 13:22:23.139 Select result is 0
. 2006-06-15 13:22:23.640 Session upkeep
. 2006-06-15 13:22:23.640 Select result is 0
. 2006-06-15 13:22:24.141 Session upkeep
. 2006-06-15 13:22:24.141 Select result is 0
. 2006-06-15 13:22:24.643 Session upkeep
. 2006-06-15 13:22:24.643 Select result is 0
. 2006-06-15 13:22:25.144 Session upkeep
. 2006-06-15 13:22:25.144 Select result is 0
. 2006-06-15 13:22:25.645 Session upkeep
. 2006-06-15 13:22:25.645 Select result is 0
. 2006-06-15 13:22:26.146 Session upkeep
. 2006-06-15 13:22:26.146 Select result is 0
. 2006-06-15 13:22:26.648 Session upkeep
. 2006-06-15 13:22:26.648 Select result is 0
. 2006-06-15 13:22:27.149 Session upkeep
. 2006-06-15 13:22:27.149 Select result is 0
. 2006-06-15 13:22:27.650 Session upkeep
. 2006-06-15 13:22:27.650 Select result is 0
. 2006-06-15 13:22:28.151 Session upkeep
. 2006-06-15 13:22:28.151 Select result is 0
. 2006-06-15 13:22:28.653 Session upkeep
. 2006-06-15 13:22:28.653 Select result is 0
. 2006-06-15 13:22:29.154 Session upkeep
. 2006-06-15 13:22:29.154 Select result is 0
. 2006-06-15 13:22:29.655 Session upkeep
. 2006-06-15 13:22:29.655 Select result is 0
. 2006-06-15 13:22:30.156 Session upkeep
. 2006-06-15 13:22:30.156 Select result is 0
. 2006-06-15 13:22:30.658 Session upkeep
. 2006-06-15 13:22:30.658 Select result is 0
. 2006-06-15 13:22:31.175 Session upkeep
. 2006-06-15 13:22:31.175 Select result is 0
. 2006-06-15 13:22:31.660 Session upkeep
. 2006-06-15 13:22:31.660 Select result is 0
. 2006-06-15 13:22:32.161 Session upkeep
. 2006-06-15 13:22:32.161 Select result is 0
. 2006-06-15 13:22:32.663 Session upkeep
. 2006-06-15 13:22:32.663 Select result is 0
. 2006-06-15 13:22:33.164 Session upkeep
. 2006-06-15 13:22:33.164 Select result is 0
. 2006-06-15 13:22:33.665 Session upkeep
. 2006-06-15 13:22:33.665 Select result is 0
. 2006-06-15 13:22:34.166 Session upkeep
. 2006-06-15 13:22:34.166 Select result is 0
. 2006-06-15 13:22:34.668 Session upkeep
. 2006-06-15 13:22:34.668 Select result is 0
. 2006-06-15 13:22:35.169 Session upkeep
. 2006-06-15 13:22:35.169 Select result is 0
. 2006-06-15 13:22:35.670 Session upkeep
. 2006-06-15 13:22:35.670 Select result is 0
. 2006-06-15 13:22:36.171 Session upkeep
. 2006-06-15 13:22:36.171 Select result is 0
. 2006-06-15 13:22:36.673 Session upkeep
. 2006-06-15 13:22:36.673 Select result is 0
. 2006-06-15 13:22:37.174 Session upkeep
. 2006-06-15 13:22:37.174 Select result is 0
. 2006-06-15 13:22:37.675 Session upkeep
. 2006-06-15 13:22:37.675 Select result is 0
. 2006-06-15 13:22:38.177 Session upkeep
. 2006-06-15 13:22:38.177 Select result is 0
. 2006-06-15 13:22:38.678 Session upkeep
. 2006-06-15 13:22:38.678 Select result is 0
. 2006-06-15 13:22:39.179 Session upkeep
. 2006-06-15 13:22:39.179 Select result is 0
. 2006-06-15 13:22:39.680 Session upkeep
. 2006-06-15 13:22:39.680 Select result is 0
. 2006-06-15 13:22:40.182 Session upkeep
. 2006-06-15 13:22:40.182 Select result is 0
. 2006-06-15 13:22:40.683 Session upkeep
. 2006-06-15 13:22:40.683 Select result is 0
. 2006-06-15 13:22:41.184 Session upkeep
. 2006-06-15 13:22:41.184 Select result is 0
. 2006-06-15 13:22:41.685 Session upkeep
. 2006-06-15 13:22:41.685 Select result is 0
. 2006-06-15 13:22:42.187 Session upkeep
. 2006-06-15 13:22:42.187 Select result is 0
. 2006-06-15 13:22:42.688 Session upkeep
. 2006-06-15 13:22:42.688 Select result is 0
. 2006-06-15 13:22:43.189 Session upkeep
. 2006-06-15 13:22:43.189 Select result is 0
. 2006-06-15 13:22:43.690 Session upkeep
. 2006-06-15 13:22:43.690 Select result is 0
. 2006-06-15 13:22:44.192 Session upkeep
. 2006-06-15 13:22:44.192 Select result is 0
. 2006-06-15 13:22:44.693 Session upkeep
. 2006-06-15 13:22:44.693 Select result is 0
. 2006-06-15 13:22:45.194 Session upkeep
. 2006-06-15 13:22:45.194 Select result is 0
. 2006-06-15 13:22:45.695 Session upkeep
. 2006-06-15 13:22:45.695 Select result is 0
. 2006-06-15 13:22:46.197 Session upkeep
. 2006-06-15 13:22:46.197 Select result is 0
. 2006-06-15 13:22:46.698 Session upkeep
. 2006-06-15 13:22:46.698 Select result is 0
. 2006-06-15 13:22:47.199 Session upkeep
. 2006-06-15 13:22:47.199 Select result is 0
. 2006-06-15 13:22:47.700 Session upkeep
. 2006-06-15 13:22:47.700 Select result is 0
. 2006-06-15 13:22:48.202 Session upkeep
. 2006-06-15 13:22:48.202 Select result is 0
. 2006-06-15 13:22:48.703 Session upkeep
. 2006-06-15 13:22:48.703 Select result is 0
. 2006-06-15 13:22:49.204 Session upkeep
. 2006-06-15 13:22:49.204 Select result is 0
. 2006-06-15 13:22:49.705 Session upkeep
. 2006-06-15 13:22:49.705 Select result is 0
. 2006-06-15 13:22:50.207 Session upkeep
. 2006-06-15 13:22:50.207 Select result is 0
. 2006-06-15 13:22:50.708 Session upkeep
. 2006-06-15 13:22:50.708 Select result is 0
. 2006-06-15 13:22:51.209 Session upkeep
. 2006-06-15 13:22:51.209 Select result is 0
. 2006-06-15 13:22:51.710 Session upkeep
. 2006-06-15 13:22:51.710 Select result is 0
. 2006-06-15 13:22:52.212 Session upkeep
. 2006-06-15 13:22:52.212 Select result is 0
. 2006-06-15 13:22:53.105 Session upkeep
. 2006-06-15 13:22:53.105 Select result is 0
. 2006-06-15 13:22:53.214 Session upkeep
. 2006-06-15 13:22:53.214 Select result is 0
. 2006-06-15 13:22:53.715 Session upkeep
. 2006-06-15 13:22:53.715 Select result is 0
. 2006-06-15 13:22:54.217 Session upkeep
. 2006-06-15 13:22:54.217 Select result is 0
. 2006-06-15 13:22:54.718 Session upkeep
. 2006-06-15 13:22:54.718 Select result is 0
. 2006-06-15 13:22:55.219 Session upkeep
. 2006-06-15 13:22:55.219 Select result is 0
. 2006-06-15 13:22:55.721 Session upkeep
. 2006-06-15 13:22:55.721 Select result is 0
. 2006-06-15 13:22:56.222 Session upkeep
. 2006-06-15 13:22:56.222 Select result is 0
. 2006-06-15 13:22:56.723 Session upkeep
. 2006-06-15 13:22:56.723 Select result is 0
. 2006-06-15 13:22:57.224 Session upkeep
. 2006-06-15 13:22:57.224 Select result is 0
. 2006-06-15 13:22:57.726 Session upkeep
. 2006-06-15 13:22:57.726 Select result is 0
. 2006-06-15 13:22:58.227 Session upkeep
. 2006-06-15 13:22:58.227 Select result is 0
. 2006-06-15 13:22:58.728 Session upkeep
. 2006-06-15 13:22:58.728 Select result is 0
. 2006-06-15 13:22:59.229 Session upkeep
. 2006-06-15 13:22:59.229 Select result is 0
. 2006-06-15 13:22:59.731 Session upkeep
. 2006-06-15 13:22:59.731 Select result is 0
. 2006-06-15 13:23:00.232 Session upkeep
. 2006-06-15 13:23:00.232 Select result is 0
. 2006-06-15 13:23:00.733 Session upkeep
. 2006-06-15 13:23:00.733 Select result is 0
. 2006-06-15 13:23:01.234 Session upkeep
. 2006-06-15 13:23:01.234 Select result is 0
. 2006-06-15 13:23:01.736 Session upkeep
. 2006-06-15 13:23:01.736 Select result is 0
. 2006-06-15 13:23:02.237 Session upkeep
. 2006-06-15 13:23:02.237 Select result is 0
. 2006-06-15 13:23:02.738 Session upkeep
. 2006-06-15 13:23:02.738 Select result is 0
. 2006-06-15 13:23:03.239 Session upkeep
. 2006-06-15 13:23:03.239 Select result is 0
. 2006-06-15 13:23:03.741 Session upkeep
. 2006-06-15 13:23:03.741 Select result is 0
. 2006-06-15 13:23:04.242 Session upkeep
. 2006-06-15 13:23:04.242 Select result is 0
. 2006-06-15 13:23:04.743 Session upkeep
. 2006-06-15 13:23:04.743 Select result is 0
. 2006-06-15 13:23:05.244 Session upkeep
. 2006-06-15 13:23:05.244 Select result is 0
. 2006-06-15 13:23:05.746 Session upkeep
. 2006-06-15 13:23:05.746 Select result is 0
. 2006-06-15 13:23:06.247 Session upkeep
. 2006-06-15 13:23:06.247 Select result is 0
. 2006-06-15 13:23:06.748 Session upkeep
. 2006-06-15 13:23:06.748 Select result is 0
. 2006-06-15 13:23:07.249 Session upkeep
. 2006-06-15 13:23:07.249 Select result is 0
. 2006-06-15 13:23:07.751 Session upkeep
. 2006-06-15 13:23:07.751 Select result is 0
. 2006-06-15 13:23:08.252 Session upkeep
. 2006-06-15 13:23:08.252 Select result is 0
. 2006-06-15 13:23:08.753 Session upkeep
. 2006-06-15 13:23:08.753 Select result is 0
. 2006-06-15 13:23:09.254 Session upkeep
. 2006-06-15 13:23:09.254 Select result is 0
. 2006-06-15 13:23:09.756 Session upkeep
. 2006-06-15 13:23:09.756 Select result is 0
. 2006-06-15 13:23:10.257 Session upkeep
. 2006-06-15 13:23:10.257 Select result is 0
. 2006-06-15 13:23:10.758 Session upkeep
. 2006-06-15 13:23:10.758 Select result is 0
. 2006-06-15 13:23:11.260 Session upkeep
. 2006-06-15 13:23:11.260 Select result is 0
. 2006-06-15 13:23:11.761 Session upkeep
. 2006-06-15 13:23:11.761 Select result is 0
. 2006-06-15 13:23:12.262 Session upkeep
. 2006-06-15 13:23:12.262 Select result is 0
. 2006-06-15 13:23:12.763 Session upkeep
. 2006-06-15 13:23:12.763 Select result is 0
. 2006-06-15 13:23:13.265 Session upkeep
. 2006-06-15 13:23:13.265 Select result is 0
. 2006-06-15 13:23:13.766 Session upkeep
. 2006-06-15 13:23:13.766 Select result is 0
. 2006-06-15 13:23:14.267 Session upkeep
. 2006-06-15 13:23:14.267 Select result is 0
. 2006-06-15 13:23:14.768 Session upkeep
. 2006-06-15 13:23:14.768 Select result is 0
. 2006-06-15 13:23:15.270 Session upkeep
. 2006-06-15 13:23:15.270 Select result is 0
. 2006-06-15 13:23:15.771 Session upkeep
. 2006-06-15 13:23:15.771 Select result is 0
. 2006-06-15 13:23:16.272 Session upkeep
. 2006-06-15 13:23:16.272 Select result is 0
. 2006-06-15 13:23:16.773 Session upkeep
. 2006-06-15 13:23:16.773 Select result is 0
. 2006-06-15 13:23:17.275 Session upkeep
. 2006-06-15 13:23:17.275 Select result is 0
. 2006-06-15 13:23:17.776 Session upkeep
. 2006-06-15 13:23:17.776 Select result is 0
. 2006-06-15 13:23:18.277 Session upkeep
. 2006-06-15 13:23:18.277 Select result is 0
. 2006-06-15 13:23:18.778 Session upkeep
. 2006-06-15 13:23:18.778 Select result is 0
. 2006-06-15 13:23:19.280 Session upkeep
. 2006-06-15 13:23:19.280 Select result is 0
. 2006-06-15 13:23:19.781 Session upkeep
. 2006-06-15 13:23:19.781 Select result is 0
. 2006-06-15 13:23:20.282 Session upkeep
. 2006-06-15 13:23:20.282 Select result is 0
. 2006-06-15 13:23:20.783 Session upkeep
. 2006-06-15 13:23:20.783 Select result is 0
. 2006-06-15 13:23:21.285 Session upkeep
. 2006-06-15 13:23:21.285 Select result is 0
. 2006-06-15 13:23:21.786 Session upkeep
. 2006-06-15 13:23:21.786 Select result is 0
. 2006-06-15 13:23:22.287 Session upkeep
. 2006-06-15 13:23:22.287 Select result is 0
. 2006-06-15 13:23:22.788 Session upkeep
. 2006-06-15 13:23:22.788 Select result is 0
. 2006-06-15 13:23:23.290 Session upkeep
. 2006-06-15 13:23:23.290 Select result is 0
. 2006-06-15 13:23:23.791 Session upkeep
. 2006-06-15 13:23:23.791 Select result is 0
. 2006-06-15 13:23:24.292 Session upkeep
. 2006-06-15 13:23:24.292 Select result is 0
. 2006-06-15 13:23:24.793 Session upkeep
. 2006-06-15 13:23:24.793 Select result is 0
. 2006-06-15 13:23:25.295 Session upkeep
. 2006-06-15 13:23:25.295 Select result is 0
. 2006-06-15 13:23:25.796 Session upkeep
. 2006-06-15 13:23:25.796 Select result is 0
. 2006-06-15 13:23:26.297 Session upkeep
. 2006-06-15 13:23:26.297 Select result is 0
. 2006-06-15 13:23:26.799 Session upkeep
. 2006-06-15 13:23:26.799 Select result is 0
. 2006-06-15 13:23:27.300 Session upkeep
. 2006-06-15 13:23:27.300 Select result is 0
. 2006-06-15 13:23:27.801 Session upkeep
. 2006-06-15 13:23:27.801 Select result is 0
. 2006-06-15 13:23:28.302 Session upkeep
. 2006-06-15 13:23:28.302 Select result is 0
. 2006-06-15 13:23:28.804 Session upkeep
. 2006-06-15 13:23:28.804 Select result is 0
. 2006-06-15 13:23:29.305 Session upkeep
. 2006-06-15 13:23:29.305 Select result is 0
. 2006-06-15 13:23:29.806 Session upkeep
. 2006-06-15 13:23:29.806 Select result is 0
. 2006-06-15 13:23:30.307 Session upkeep
. 2006-06-15 13:23:30.307 Select result is 0
. 2006-06-15 13:23:30.809 Session upkeep
. 2006-06-15 13:23:30.809 Select result is 0
. 2006-06-15 13:23:31.310 Session upkeep
. 2006-06-15 13:23:31.310 Select result is 0
. 2006-06-15 13:23:31.811 Session upkeep
. 2006-06-15 13:23:31.811 Select result is 0
. 2006-06-15 13:23:32.312 Session upkeep
. 2006-06-15 13:23:32.312 Select result is 0
. 2006-06-15 13:23:32.814 Session upkeep
. 2006-06-15 13:23:32.814 Select result is 0
. 2006-06-15 13:23:33.315 Session upkeep
. 2006-06-15 13:23:33.315 Select result is 0
. 2006-06-15 13:23:33.816 Session upkeep
. 2006-06-15 13:23:33.816 Select result is 0
. 2006-06-15 13:23:34.317 Session upkeep
. 2006-06-15 13:23:34.317 Select result is 0
. 2006-06-15 13:23:34.819 Session upkeep
. 2006-06-15 13:23:34.819 Select result is 0
. 2006-06-15 13:23:35.320 Session upkeep
. 2006-06-15 13:23:35.320 Select result is 0
. 2006-06-15 13:23:35.821 Session upkeep
. 2006-06-15 13:23:35.821 Select result is 0
. 2006-06-15 13:23:36.322 Session upkeep
. 2006-06-15 13:23:36.322 Select result is 0
. 2006-06-15 13:23:36.824 Session upkeep
. 2006-06-15 13:23:36.824 Select result is 0
. 2006-06-15 13:23:37.325 Session upkeep
. 2006-06-15 13:23:37.325 Select result is 0
. 2006-06-15 13:23:37.826 Session upkeep
. 2006-06-15 13:23:37.826 Select result is 0
. 2006-06-15 13:23:38.327 Session upkeep
. 2006-06-15 13:23:38.327 Select result is 0
. 2006-06-15 13:23:38.829 Session upkeep
. 2006-06-15 13:23:38.829 Select result is 0
. 2006-06-15 13:23:39.330 Session upkeep
. 2006-06-15 13:23:39.330 Select result is 0
. 2006-06-15 13:23:39.831 Session upkeep
. 2006-06-15 13:23:39.831 Select result is 0
. 2006-06-15 13:23:40.332 Session upkeep
. 2006-06-15 13:23:40.332 Select result is 0
. 2006-06-15 13:23:40.834 Session upkeep
. 2006-06-15 13:23:40.834 Select result is 0
. 2006-06-15 13:23:41.335 Session upkeep
. 2006-06-15 13:23:41.335 Select result is 0
. 2006-06-15 13:23:41.836 Session upkeep
. 2006-06-15 13:23:41.836 Select result is 0
. 2006-06-15 13:23:42.337 Session upkeep
. 2006-06-15 13:23:42.337 Select result is 0
. 2006-06-15 13:23:42.839 Session upkeep
. 2006-06-15 13:23:42.839 Select result is 0
. 2006-06-15 13:23:43.340 Session upkeep
. 2006-06-15 13:23:43.340 Select result is 0
. 2006-06-15 13:23:43.841 Session upkeep
. 2006-06-15 13:23:43.841 Select result is 0
. 2006-06-15 13:23:44.343 Session upkeep
. 2006-06-15 13:23:44.343 Select result is 0
. 2006-06-15 13:23:44.844 Session upkeep
. 2006-06-15 13:23:44.844 Select result is 0
. 2006-06-15 13:23:45.345 Session upkeep
. 2006-06-15 13:23:45.345 Select result is 0
. 2006-06-15 13:23:45.846 Session upkeep
. 2006-06-15 13:23:45.846 Select result is 0
. 2006-06-15 13:23:46.348 Session upkeep
. 2006-06-15 13:23:46.348 Select result is 0
. 2006-06-15 13:23:46.849 Session upkeep
. 2006-06-15 13:23:46.849 Select result is 0
. 2006-06-15 13:23:47.350 Session upkeep
. 2006-06-15 13:23:47.350 Select result is 0
. 2006-06-15 13:23:47.851 Session upkeep
. 2006-06-15 13:23:47.851 Select result is 0
. 2006-06-15 13:23:48.353 Session upkeep
. 2006-06-15 13:23:48.353 Select result is 0
. 2006-06-15 13:23:48.854 Session upkeep
. 2006-06-15 13:23:48.854 Select result is 0
. 2006-06-15 13:23:49.355 Session upkeep
. 2006-06-15 13:23:49.355 Select result is 0
. 2006-06-15 13:23:49.856 Session upkeep
. 2006-06-15 13:23:49.856 Select result is 0
. 2006-06-15 13:23:50.358 Session upkeep
. 2006-06-15 13:23:50.358 Select result is 0
. 2006-06-15 13:23:50.859 Session upkeep
. 2006-06-15 13:23:50.859 Select result is 0
. 2006-06-15 13:23:51.360 Session upkeep
. 2006-06-15 13:23:51.360 Select result is 0
. 2006-06-15 13:23:51.861 Session upkeep
. 2006-06-15 13:23:51.861 Select result is 0
. 2006-06-15 13:23:52.363 Session upkeep
. 2006-06-15 13:23:52.363 Select result is 0
. 2006-06-15 13:23:52.864 Session upkeep
. 2006-06-15 13:23:52.864 Select result is 0
. 2006-06-15 13:23:53.365 Session upkeep
. 2006-06-15 13:23:53.365 Select result is 0
. 2006-06-15 13:23:53.866 Session upkeep
. 2006-06-15 13:23:53.866 Select result is 0
. 2006-06-15 13:23:54.368 Session upkeep
. 2006-06-15 13:23:54.368 Select result is 0
. 2006-06-15 13:23:54.869 Session upkeep
. 2006-06-15 13:23:54.869 Select result is 0
. 2006-06-15 13:23:55.370 Session upkeep
. 2006-06-15 13:23:55.370 Select result is 0
. 2006-06-15 13:23:55.871 Session upkeep
. 2006-06-15 13:23:55.871 Select result is 0
. 2006-06-15 13:23:56.373 Session upkeep
. 2006-06-15 13:23:56.373 Select result is 0
. 2006-06-15 13:23:56.874 Session upkeep
. 2006-06-15 13:23:56.874 Select result is 0
. 2006-06-15 13:23:57.375 Session upkeep
. 2006-06-15 13:23:57.375 Select result is 0
. 2006-06-15 13:23:57.876 Session upkeep
. 2006-06-15 13:23:57.876 Select result is 0
. 2006-06-15 13:23:58.378 Session upkeep
. 2006-06-15 13:23:58.378 Select result is 0
. 2006-06-15 13:23:58.879 Session upkeep
. 2006-06-15 13:23:58.879 Select result is 0
. 2006-06-15 13:23:59.380 Session upkeep
. 2006-06-15 13:23:59.380 Select result is 0
. 2006-06-15 13:23:59.882 Session upkeep
. 2006-06-15 13:23:59.882 Select result is 0
. 2006-06-15 13:24:00.383 Session upkeep
. 2006-06-15 13:24:00.383 Select result is 0
. 2006-06-15 13:24:00.884 Session upkeep
. 2006-06-15 13:24:00.884 Select result is 0
. 2006-06-15 13:24:01.385 Session upkeep
. 2006-06-15 13:24:01.385 Select result is 0
. 2006-06-15 13:24:01.887 Session upkeep
. 2006-06-15 13:24:01.887 Select result is 0
. 2006-06-15 13:24:02.388 Session upkeep
. 2006-06-15 13:24:02.388 Select result is 0
. 2006-06-15 13:24:02.889 Session upkeep
. 2006-06-15 13:24:02.889 Select result is 0
. 2006-06-15 13:24:03.390 Session upkeep
. 2006-06-15 13:24:03.390 Select result is 0
. 2006-06-15 13:24:03.892 Session upkeep
. 2006-06-15 13:24:03.892 Select result is 0
. 2006-06-15 13:24:04.393 Session upkeep
. 2006-06-15 13:24:04.393 Select result is 0
. 2006-06-15 13:24:04.894 Session upkeep
. 2006-06-15 13:24:04.894 Select result is 0
. 2006-06-15 13:24:05.395 Session upkeep
. 2006-06-15 13:24:05.395 Select result is 0
. 2006-06-15 13:24:05.897 Session upkeep
. 2006-06-15 13:24:05.897 Select result is 0
. 2006-06-15 13:24:06.398 Session upkeep
. 2006-06-15 13:24:06.398 Select result is 0
. 2006-06-15 13:24:06.899 Session upkeep
. 2006-06-15 13:24:06.899 Select result is 0
. 2006-06-15 13:24:07.400 Session upkeep
. 2006-06-15 13:24:07.400 Select result is 0
. 2006-06-15 13:24:07.902 Session upkeep
. 2006-06-15 13:24:07.902 Select result is 0
. 2006-06-15 13:24:08.403 Session upkeep
. 2006-06-15 13:24:08.403 Select result is 0
. 2006-06-15 13:24:08.904 Session upkeep
. 2006-06-15 13:24:08.904 Select result is 0
. 2006-06-15 13:24:09.405 Session upkeep
. 2006-06-15 13:24:09.405 Select result is 0
. 2006-06-15 13:24:09.907 Session upkeep
. 2006-06-15 13:24:09.907 Select result is 0
. 2006-06-15 13:24:10.408 Session upkeep
. 2006-06-15 13:24:10.408 Select result is 0
. 2006-06-15 13:24:10.909 Session upkeep
. 2006-06-15 13:24:10.909 Select result is 0
. 2006-06-15 13:24:11.410 Session upkeep
. 2006-06-15 13:24:11.410 Select result is 0
. 2006-06-15 13:24:11.912 Session upkeep
. 2006-06-15 13:24:11.912 Select result is 0
. 2006-06-15 13:24:12.413 Session upkeep
. 2006-06-15 13:24:12.413 Select result is 0
. 2006-06-15 13:24:12.914 Session upkeep
. 2006-06-15 13:24:12.914 Select result is 0
. 2006-06-15 13:24:13.415 Session upkeep
. 2006-06-15 13:24:13.415 Select result is 0
. 2006-06-15 13:24:13.917 Session upkeep
. 2006-06-15 13:24:13.917 Select result is 0
. 2006-06-15 13:24:14.418 Session upkeep
. 2006-06-15 13:24:14.418 Select result is 0
. 2006-06-15 13:24:14.919 Session upkeep
. 2006-06-15 13:24:14.919 Select result is 0
. 2006-06-15 13:24:15.420 Session upkeep
. 2006-06-15 13:24:15.420 Select result is 0
. 2006-06-15 13:24:15.922 Session upkeep
. 2006-06-15 13:24:15.922 Select result is 0
. 2006-06-15 13:24:16.423 Session upkeep
. 2006-06-15 13:24:16.423 Select result is 0
. 2006-06-15 13:24:16.924 Session upkeep
. 2006-06-15 13:24:16.924 Select result is 0
. 2006-06-15 13:24:17.426 Session upkeep
. 2006-06-15 13:24:17.426 Select result is 0
. 2006-06-15 13:24:17.927 Session upkeep
. 2006-06-15 13:24:17.927 Select result is 0
. 2006-06-15 13:24:18.428 Session upkeep
. 2006-06-15 13:24:18.428 Select result is 0
. 2006-06-15 13:24:18.929 Session upkeep
. 2006-06-15 13:24:18.929 Select result is 0
. 2006-06-15 13:24:19.431 Session upkeep
. 2006-06-15 13:24:19.431 Select result is 0
. 2006-06-15 13:24:19.932 Session upkeep
. 2006-06-15 13:24:19.932 Select result is 0
. 2006-06-15 13:24:20.433 Session upkeep
. 2006-06-15 13:24:20.433 Select result is 0
. 2006-06-15 13:24:20.934 Session upkeep
. 2006-06-15 13:24:20.934 Select result is 0
. 2006-06-15 13:24:21.436 Session upkeep
. 2006-06-15 13:24:21.436 Select result is 0
. 2006-06-15 13:24:21.937 Session upkeep
. 2006-06-15 13:24:21.937 Select result is 0
. 2006-06-15 13:24:22.438 Session upkeep
. 2006-06-15 13:24:22.438 Select result is 0
. 2006-06-15 13:24:22.939 Session upkeep
. 2006-06-15 13:24:22.939 Select result is 0
. 2006-06-15 13:24:23.441 Session upkeep
. 2006-06-15 13:24:23.441 Select result is 0
. 2006-06-15 13:24:23.942 Session upkeep
. 2006-06-15 13:24:23.942 Select result is 0
. 2006-06-15 13:24:24.443 Session upkeep
. 2006-06-15 13:24:24.443 Select result is 0
. 2006-06-15 13:24:24.944 Session upkeep
. 2006-06-15 13:24:24.944 Select result is 0
. 2006-06-15 13:24:25.446 Session upkeep
. 2006-06-15 13:24:25.446 Select result is 0
. 2006-06-15 13:24:25.947 Session upkeep
. 2006-06-15 13:24:25.947 Select result is 0
. 2006-06-15 13:24:26.448 Session upkeep
. 2006-06-15 13:24:26.448 Select result is 0
. 2006-06-15 13:24:26.949 Session upkeep
. 2006-06-15 13:24:26.949 Select result is 0
. 2006-06-15 13:24:27.451 Session upkeep
. 2006-06-15 13:24:27.451 Select result is 0
. 2006-06-15 13:24:27.952 Session upkeep
. 2006-06-15 13:24:27.952 Select result is 0
. 2006-06-15 13:24:28.453 Session upkeep
. 2006-06-15 13:24:28.453 Select result is 0
. 2006-06-15 13:24:28.954 Session upkeep
. 2006-06-15 13:24:28.954 Select result is 0
. 2006-06-15 13:24:29.456 Session upkeep
. 2006-06-15 13:24:29.456 Select result is 0
. 2006-06-15 13:24:29.957 Session upkeep
. 2006-06-15 13:24:29.957 Select result is 0
. 2006-06-15 13:24:30.458 Session upkeep
. 2006-06-15 13:24:30.458 Select result is 0
. 2006-06-15 13:24:30.959 Session upkeep
. 2006-06-15 13:24:30.959 Select result is 0
. 2006-06-15 13:24:31.461 Session upkeep
. 2006-06-15 13:24:31.461 Select result is 0
. 2006-06-15 13:24:31.962 Session upkeep
. 2006-06-15 13:24:31.962 Select result is 0
. 2006-06-15 13:24:32.463 Session upkeep
. 2006-06-15 13:24:32.463 Select result is 0
. 2006-06-15 13:24:32.965 Session upkeep
. 2006-06-15 13:24:32.965 Select result is 0
. 2006-06-15 13:24:33.466 Session upkeep
. 2006-06-15 13:24:33.466 Select result is 0
. 2006-06-15 13:24:33.967 Session upkeep
. 2006-06-15 13:24:33.967 Select result is 0
. 2006-06-15 13:24:34.468 Session upkeep
. 2006-06-15 13:24:34.468 Select result is 0
. 2006-06-15 13:24:34.970 Session upkeep
. 2006-06-15 13:24:34.970 Select result is 0
. 2006-06-15 13:24:35.471 Session upkeep
. 2006-06-15 13:24:35.471 Select result is 0
. 2006-06-15 13:24:35.972 Session upkeep
. 2006-06-15 13:24:35.972 Select result is 0
. 2006-06-15 13:24:36.473 Session upkeep
. 2006-06-15 13:24:36.473 Select result is 0
. 2006-06-15 13:24:36.975 Session upkeep
. 2006-06-15 13:24:36.975 Select result is 0
. 2006-06-15 13:24:37.476 Session upkeep
. 2006-06-15 13:24:37.476 Select result is 0
. 2006-06-15 13:24:37.977 Session upkeep
. 2006-06-15 13:24:37.977 Select result is 0
. 2006-06-15 13:24:38.478 Session upkeep
. 2006-06-15 13:24:38.478 Select result is 0
. 2006-06-15 13:24:38.980 Session upkeep
. 2006-06-15 13:24:38.980 Select result is 0
. 2006-06-15 13:24:39.481 Session upkeep
. 2006-06-15 13:24:39.481 Select result is 0
. 2006-06-15 13:24:39.982 Session upkeep
. 2006-06-15 13:24:39.982 Select result is 0
. 2006-06-15 13:24:40.483 Session upkeep
. 2006-06-15 13:24:40.483 Select result is 0
. 2006-06-15 13:24:40.985 Session upkeep
. 2006-06-15 13:24:40.985 Select result is 0
. 2006-06-15 13:24:41.486 Session upkeep
. 2006-06-15 13:24:41.486 Select result is 0
. 2006-06-15 13:24:41.987 Session upkeep
. 2006-06-15 13:24:41.987 Select result is 0
. 2006-06-15 13:24:42.488 Session upkeep
. 2006-06-15 13:24:42.488 Select result is 0
. 2006-06-15 13:24:42.990 Session upkeep
. 2006-06-15 13:24:42.990 Select result is 0
. 2006-06-15 13:24:43.491 Session upkeep
. 2006-06-15 13:24:43.491 Select result is 0
. 2006-06-15 13:24:43.992 Session upkeep
. 2006-06-15 13:24:43.992 Select result is 0
. 2006-06-15 13:24:44.493 Session upkeep
. 2006-06-15 13:24:44.493 Select result is 0
. 2006-06-15 13:24:44.995 Session upkeep
. 2006-06-15 13:24:44.995 Select result is 0
. 2006-06-15 13:24:45.496 Session upkeep
. 2006-06-15 13:24:45.496 Select result is 0
. 2006-06-15 13:24:45.997 Session upkeep
. 2006-06-15 13:24:45.997 Select result is 0
. 2006-06-15 13:24:46.498 Session upkeep
. 2006-06-15 13:24:46.498 Select result is 0
. 2006-06-15 13:24:47.000 Session upkeep
. 2006-06-15 13:24:47.000 Select result is 0
. 2006-06-15 13:24:47.501 Session upkeep
. 2006-06-15 13:24:47.501 Select result is 0
. 2006-06-15 13:24:47.987 Session upkeep
. 2006-06-15 13:24:47.987 Select result is 0
. 2006-06-15 13:24:48.018 Session upkeep
. 2006-06-15 13:24:48.018 Select result is 0
. 2006-06-15 13:24:48.519 Session upkeep
. 2006-06-15 13:24:48.519 Select result is 0
. 2006-06-15 13:24:49.005 Session upkeep
. 2006-06-15 13:24:49.005 Select result is 0
. 2006-06-15 13:24:49.506 Session upkeep
. 2006-06-15 13:24:49.506 Select result is 0
. 2006-06-15 13:24:50.007 Session upkeep
. 2006-06-15 13:24:50.007 Select result is 0
. 2006-06-15 13:24:50.509 Session upkeep
. 2006-06-15 13:24:50.509 Select result is 0
. 2006-06-15 13:24:51.010 Session upkeep
. 2006-06-15 13:24:51.010 Select result is 0
. 2006-06-15 13:24:51.511 Session upkeep
. 2006-06-15 13:24:51.511 Select result is 0
. 2006-06-15 13:24:52.012 Session upkeep
. 2006-06-15 13:24:52.012 Select result is 0
. 2006-06-15 13:24:52.514 Session upkeep
. 2006-06-15 13:24:52.514 Select result is 0
. 2006-06-15 13:24:52.889 Copying 1 files/directories to remote directory "/infrastructure/archive/"
. 2006-06-15 13:24:52.889 PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2006-06-15 13:24:52.889 TM: M; ClAr: No; ExclM(No):
. 2006-06-15 13:24:52.889 AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2006-06-15 13:24:52.889 File: "C:\Documents and Settings\DBullard\Desktop\NetBeansIDE-release351-linux.bin"
. 2006-06-15 13:24:52.905 Copying "C:\Documents and Settings\DBullard\Desktop\NetBeansIDE-release351-linux.bin" to remote directory started.
. 2006-06-15 13:24:52.905 Binary transfer mode selected.
. 2006-06-15 13:24:52.905 Checking existence of file.
> 2006-06-15 13:24:52.905 Type: SSH_FXP_LSTAT, Size: 65, Number: 2055
> 2006-06-15 13:24:52.905 07,00,00,08,07,00,00,00,38,2F,69,6E,66,72,61,73,74,72,75,63,74,75,72,65,2F,
> 2006-06-15 13:24:52.905 61,72,63,68,69,76,65,2F,4E,65,74,42,65,61,6E,73,49,44,45,2D,72,65,6C,65,61,
> 2006-06-15 13:24:52.905 73,65,33,35,31,2D,6C,69,6E,75,78,2E,62,69,6E,
. 2006-06-15 13:24:52.905 Sent 69 bytes
. 2006-06-15 13:24:52.905 There are 0 bytes remaining in the send buffer
. 2006-06-15 13:24:52.905 Received 4 bytes
. 2006-06-15 13:24:52.905 Received 24 bytes
< 2006-06-15 13:24:52.905 Type: SSH_FXP_STATUS, Size: 24, Number: 1796
< 2006-06-15 13:24:52.905 65,00,00,07,04,00,00,00,00,00,00,00,07,53,75,63,63,65,73,73,00,00,00,00,
. 2006-06-15 13:24:52.905 Discarding reserved response
. 2006-06-15 13:24:52.905 Waiting for another 4 bytes
. 2006-06-15 13:24:52.905 Looking for incoming data
. 2006-06-15 13:24:52.952 Select result is 1
. 2006-06-15 13:24:52.952 Received 4 bytes
. 2006-06-15 13:24:52.952 Received 29 bytes
< 2006-06-15 13:24:52.952 Type: SSH_FXP_STATUS, Size: 29, Number: 2055
< 2006-06-15 13:24:52.952 65,00,00,08,07,00,00,00,02,00,00,00,0C,4E,6F,20,73,75,63,68,20,66,69,6C,65,
< 2006-06-15 13:24:52.952 00,00,00,00,
< 2006-06-15 13:24:52.952 Status/error code: 2
. 2006-06-15 13:24:52.952 Checking existence of partially transfered file.
> 2006-06-15 13:24:52.952 Type: SSH_FXP_LSTAT, Size: 74, Number: 2311
> 2006-06-15 13:24:52.952 07,00,00,09,07,00,00,00,41,2F,69,6E,66,72,61,73,74,72,75,63,74,75,72,65,2F,
> 2006-06-15 13:24:52.952 61,72,63,68,69,76,65,2F,4E,65,74,42,65,61,6E,73,49,44,45,2D,72,65,6C,65,61,
> 2006-06-15 13:24:52.952 73,65,33,35,31,2D,6C,69,6E,75,78,2E,62,69,6E,2E,66,69,6C,65,70,61,72,74,
. 2006-06-15 13:24:52.952 Sent 78 bytes
. 2006-06-15 13:24:52.952 There are 0 bytes remaining in the send buffer
. 2006-06-15 13:24:52.952 Waiting for another 4 bytes
. 2006-06-15 13:24:52.952 Looking for incoming data
. 2006-06-15 13:24:52.983 Select result is 1
. 2006-06-15 13:24:52.983 Received 4 bytes
. 2006-06-15 13:24:52.983 Received 37 bytes
< 2006-06-15 13:24:52.983 Type: SSH_FXP_ATTRS, Size: 37, Number: 2311
< 2006-06-15 13:24:52.983 69,00,00,09,07,00,00,00,0F,00,00,00,00,00,01,20,00,00,00,00,00,00,00,00,00,
< 2006-06-15 13:24:52.983 00,00,81,A4,44,91,7D,29,44,91,94,CF,
. 2006-06-15 13:24:52.983 Asking user:
. 2006-06-15 13:24:52.983 Target directory contains partially transfered file 'NetBeansIDE-release351-linux.bin'. Do you want to resume file transfer? Note: Answering 'No' would delete partially transfered file and restart transfer. ()
. 2006-06-15 13:24:53.030 Session upkeep
. 2006-06-15 13:24:53.030 Select result is 0
. 2006-06-15 13:24:53.516 Session upkeep
. 2006-06-15 13:24:53.516 Select result is 0
. 2006-06-15 13:24:53.970 Resuming file transfer.
. 2006-06-15 13:24:53.970 Opening remote file.
> 2006-06-15 13:24:53.970 Type: SSH_FXP_OPEN, Size: 90, Number: 2563
> 2006-06-15 13:24:53.970 03,00,00,0A,03,00,00,00,41,2F,69,6E,66,72,61,73,74,72,75,63,74,75,72,65,2F,
> 2006-06-15 13:24:53.970 61,72,63,68,69,76,65,2F,4E,65,74,42,65,61,6E,73,49,44,45,2D,72,65,6C,65,61,
> 2006-06-15 13:24:53.970 73,65,33,35,31,2D,6C,69,6E,75,78,2E,62,69,6E,2E,66,69,6C,65,70,61,72,74,00,
> 2006-06-15 13:24:53.970 00,00,0A,00,00,00,01,00,00,00,00,01,D7,8C,73,
. 2006-06-15 13:24:53.970 Sent 94 bytes
. 2006-06-15 13:24:53.970 There are 0 bytes remaining in the send buffer
. 2006-06-15 13:24:53.970 Waiting for another 4 bytes
. 2006-06-15 13:24:53.970 Looking for incoming data
. 2006-06-15 13:24:54.017 Select result is 1
. 2006-06-15 13:24:54.017 Received 4 bytes
. 2006-06-15 13:24:54.017 Received 13 bytes
< 2006-06-15 13:24:54.017 Type: SSH_FXP_HANDLE, Siz
Can you see anything useful in log file of the server?
I had exactly the same error. I use VMware player with debian2.6.8 on my host PC. Windowsxp is running, and I need to transfer data from windows to the vmware.
I solved the problem with install of service pack 2 for winxp.
Now it works fine!!
I hope this will help you.
best regards Josef
