Topic "U3 Version of WinSCP?"
Muckypaws
Do you have plans to make the software U3 compatible?
I have no idea what needs to be done to make it U3 compatible.
michael wihsboeck
it's not very hard. It is more or less only a special package format with some configuration to run the app direct from U3 compatible stick, see http://www.u3.com
Greetings,
Michael
Thanks! I'll check it.
JL
I would definitely be interested as well. U3 is blowing up and i think there will be more and more demand.
Tijntjethf
I'm very interested to! Smile
kene
me too
Mat
I wonder if this ever got developed.
It's implemented already. Just waiting for the certification...
WinSCP U3 package is available already.
Tomm
Love it!!! One request for the next version:
Allow the path to the PuTTY executable to be a U3 package!!
Thanks for the U3 port!
It's not easy to do as PuTTY binary is stored in U3 archive. Unless you run it at least once directly, it gets not extracted.
My understanding is (and that's is *very* limited Wink ), is the up3 file is just a .ZIP file with the extension changed. Could you not do an in-memory extraction? Or would this be too cumbersome/expensive (ram-wise)?
But, if no, then not.
Thanks for responding!!
Tomm
But there's too much logic associated with the ZIP file, specified by included manifest file (how to restore/save settings etc.).
tenest
what about allowing the path to the putty executable be a relative path?
May be I miss something, but I do not see how this could help.
QuantumNet
I am not certain of all portable versions of putty but http://www.u3community.com/viewtopic.php?p=4064&sid=6c9bf0e68b7806737b0faf112b64956e
this version that we use extracts the putty.exe to the U3_DEVICE_EXEC_PATH when it is installed.
so if you could please incorporate this feature thank you.
It has been already... You can use environment variables in path to PuTTY.
