Topic "error checking for application updates"
ket000
I get following message, when trying Help -> Check for Updates. I connect to internet using proxy and it is set correctly under Preferences - Updates -> Connection -> Use Proxy server
Error
Error checking for application updates.
OK
However if i use the Update icon on the toolbar, I get
Information
You have the latest version.
OK Help
There's some connection problem. The button on toolbar shows cached results.
