Topic "Portable WinSCP/PuTTY"
AnonymousCoward
I want to know a way to make WinSCP and PuTTY completely and totally portable...i.e. creating ZERO files on the local computer, and only in the folder I place them in on a USB key, including relative paths instead of full paths in the WinSCP ini file. Also, all of the .rnd files need to stop being created in documents and settings, recognized host hashes, etc...
Thank you ahead of time.
I'll try to assemble some manual for that.
AnonymousCoward
Wow. Thanks. That would be fantastic.
Please follow here.
AnonymousCoward
prikryl wrote:
Please follow here.
Thank you for the guide. WinSCP is nice. Smile
Does PuTTY have a similar mode for the putty.rnd?
hi,
for a portable version of putty google for portaPutty . works great...
-ak
