Topic "Question on how the ftp term code works."
cdlvj
Ahoy,
At the end of the transmission, what command is used to set the filename with filepart to the name in the ftp command.
Is it move, copy or just rename.
I have an issue on large file transfers where it was timing out at the very end. The timeout was at default of 60 secs which I reset to a higher amount.
If the last procedure is taking a long time on the remote, then that would explain the abort.
Dekuji Vam.
Just rename.
