Topic "server unexpectedly closed connection"
Alexey K
Sorry for my english..
Client: WinSCP 3.8.2 (build 330)
Protocol: SFTP SSH-2
Interface: Norton Commander
Error: server unexpectedly closed connection
When it take place:
- last month on the one hosting (on the other hosting - that's all right)
- hosting allow to create 5 session at one time
- update version - don't anything change
- erorr appear at regular intervals (regular by the hosting timing possible) - nearly 5 minutes: if I connecting passing some time (from several second to five minutes) -> conection close -> reconnecting at once -> conection close after 5 minutes...
Log:
Quote:
. 2006-07-06 11:33:27.333 Using SFTP protocol.
. 2006-07-06 11:33:27.343 Doing startup conversation with host.
> 2006-07-06 11:33:27.343 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2006-07-06 11:33:27.393 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2006-07-06 11:33:27.393 SFTP version 3 negotiated.
. 2006-07-06 11:33:27.393 We believe the server has signed timestamps bug
. 2006-07-06 11:33:27.393 We will use UTF-8 strings for status messages only
. 2006-07-06 11:33:27.393 Limiting packet size to OpenSSH limit of 262148 bytes
. 2006-07-06 11:33:27.393 Getting current directory name.
. 2006-07-06 11:33:27.393 Getting real path for '.'
> 2006-07-06 11:33:27.393 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2006-07-06 11:33:27.433 Type: SSH_FXP_NAME, Size: 49, Number: 16
. 2006-07-06 11:33:27.433 Real path is '/home/chely2k3'
. 2006-07-06 11:33:27.433 Listing directory "/home/chely2k3".
> 2006-07-06 11:33:27.433 Type: SSH_FXP_OPENDIR, Size: 23, Number: 267
< 2006-07-06 11:33:27.463 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
> 2006-07-06 11:33:27.463 Type: SSH_FXP_READDIR, Size: 13, Number: 524
< 2006-07-06 11:33:27.533 Type: SSH_FXP_NAME, Size: 2359, Number: 524
> 2006-07-06 11:33:27.533 Type: SSH_FXP_READDIR, Size: 13, Number: 780
< 2006-07-06 11:33:27.573 Type: SSH_FXP_STATUS, Size: 28, Number: 780
< 2006-07-06 11:33:27.573 Status/error code: 1
> 2006-07-06 11:33:27.573 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
. 2006-07-06 11:33:27.573 Startup conversation with host finished.
. 2006-07-06 11:33:28.314 Detected incoming data while idle
. 2006-07-06 11:33:37.828 Sending null packet to keep session alive.
. 2006-07-06 11:33:37.828 Sending special code: 15
. 2006-07-06 11:33:47.912 Sending null packet to keep session alive.
. 2006-07-06 11:33:47.912 Sending special code: 15
. 2006-07-06 11:33:57.927 Sending null packet to keep session alive.
. 2006-07-06 11:33:57.927 Sending special code: 15
. 2006-07-06 11:34:07.941 Sending null packet to keep session alive.
. 2006-07-06 11:34:07.941 Sending special code: 15
. 2006-07-06 11:34:17.956 Sending null packet to keep session alive.
. 2006-07-06 11:34:17.956 Sending special code: 15
. 2006-07-06 11:34:27.970 Sending null packet to keep session alive.
. 2006-07-06 11:34:27.970 Sending special code: 15
. 2006-07-06 11:34:37.984 Sending null packet to keep session alive.
. 2006-07-06 11:34:37.984 Sending special code: 15
. 2006-07-06 11:34:47.999 Sending null packet to keep session alive.
. 2006-07-06 11:34:47.999 Sending special code: 15
. 2006-07-06 11:34:58.013 Sending null packet to keep session alive.
. 2006-07-06 11:34:58.013 Sending special code: 15
. 2006-07-06 11:35:06.025 Detected incoming data while idle
. 2006-07-06 11:35:06.025 Server unexpectedly closed network connection
You should better check the server, to know why it closes the connection.
