Topic "Time wrong in dir listing"
Canviper
Hi just want say great program but
if i copy files from a remote nt4 system running cygwin
and openssh the file times on the local side are 1 hour later than the nt4 side
if i copy the file back the same file back to a different dir on the remote side it goes back to the original time ie the timestamp is correct not one hour ahead
can this be fixed ???
it is very hard to sync directories with the timestamps off by one hour
thanks
I'll try to fix this in next release.
