Topic "Use return/enter to copy files"
bgoldnyxnet
On my previous machine, I was running an older version of WinSCP, and I had it configured so that the return/enter key would initiate a copy.
I have moved my work to a new machine and installed WinSCP 3.7.4, and I haven't found a way to set it up so this works. Instead, return (or double-click) tries to open the file using whichever program is configured to handle that filetype. This is almost never what I want to do.
I tried switching to F5, but that always brings up a confirm dialog.
Can I please have back the ability to copy a file from the local to remote host (or vice versa) with a single keystroke? Preferably "enter"? Is this ability hidden somewhere that I'm not aware of?
In case it's not obvious, I'm using the two-pane "Norton Commander" interface.
See option Operation to perform on double-click.
bgoldnyxnet
prikryl wrote:
Thanks. It's located in a different spot in WinSCP 3.7.4 - the "Environment" tab, but I found it and now have the behavior I want.
